Random underextrusion Problem
@Frederik can you try to momentarily connect the extruder motor to the main duet3 board and see if it works that way?
@matt3o that would be no problem. i got a spare cable thats long enough
Is your bed PID tuned? Perhaps it's the cyclical heating and cooling expand contract on the bed causing the Z gap to change.
@Phaedrux it is PID Tuned to 100 degree C. The same temp I was printing. The bed is a 4mm aluminium plate with a 4mm borosilicate plate on top. I let the temperatures stabilize bevor printing perhaps 15 to 20 min. Then a g32 +g29
Taper is set to 0, so it should be applied to the hole print.I also print in a heated chamber with 70 C
I am running now the first test print on 3.3 beta + LC1
here is a m122 from main and Toolboard at the start of the print
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 1 of 40 (11 max) === RTOS === Static ram: 149784 Dynamic ram: 60720 of which 204 recycled Never used RAM 139964, free system stack 139 words Tasks: Linux(ready,119) HEAT(blocked,299) CanReceiv(blocked,861) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,16) MAIN(running,922) IDLE(ready,20) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:09:29 ago, cause: software Last software reset at 2021-01-31 18:05, reason: User, none spinning, available RAM 139964, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 48.8, current 49.4, max 49.6 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.1, under voltage events: 0 Driver 0: position 64448, ok, reads 45610, writes 0 timeouts 0, SG min/max 0/538 Driver 1: position 14935, ok, reads 45610, writes 0 timeouts 0, SG min/max 0/324 Driver 2: position 1720, standstill, reads 45610, writes 0 timeouts 0, SG min/max 0/93 Driver 3: position 0, standstill, reads 45610, writes 0 timeouts 0, SG min/max 0/111 Driver 4: position 0, standstill, reads 45610, writes 0 timeouts 0, SG min/max 0/95 Driver 5: position 0, standstill, reads 45610, writes 0 timeouts 0, SG min/max not available Date/time: 2021-01-31 18:14:39 Slowest loop: 218.06ms; fastest: 0.02ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 111ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 6027, completed moves 6009, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state 3 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.1 === GCodes === Segments left: 1 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "G1 F3000 X255.895004 Y155.307999 E0.221520" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause* is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 3220, send timeouts 0, received 3083, lost 0, longest wait 7ms for reply type 6029, peak Tx sync delay 222, free buffers 48 (min 45) === SBC interface === State: 4, failed transfers: 0 Last transfer: 1ms ago RX/TX seq numbers: 22987/22987 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2d584 Buffer RX/TX: 400/1864-0 === Duet Control Server === Duet Control Server v3.2.0 File: Buffered code: G1 F3000 X255.895 Y155.308 E0.22152 Buffered code: G1 X255.965 Y155.378 Buffered code: G0 F7200 X254.977 Y154.986 Buffered code: G1 F3000 X258.423 Y151.54 E0.14912 Buffered code: G1 X258.493 Y151.47 Buffered code: G0 F7200 X259.331 Y149.693 Buffered code: G1 F3000 X254.199 Y144.56 E0.2221 Buffered code: G1 X254.129 Y144.49 Buffered code: G0 F7200 X254.158 Y144.517 Buffered code: G0 X254.109 Y146.803 Buffered code: G1 F3000 X261.14 Y139.772 E0.30426 Buffered code: G1 X261.21 Y139.702 Buffered code: G0 F7200 X261.201 Y139.702 Buffered code: G0 X258.481 Y139.792 Buffered code: G1 F3000 X261.14 Y142.45 E0.11504 Buffered code: G1 X261.21 Y142.52 Buffered code: G0 F7200 X261.201 Y142.52 Buffered code: G0 X261.14 Y144.297 Buffered code: G1 F3000 X260.009 Y145.428 E0.04894 Buffered code: G0 F7200 X259.64 Y145.476 Buffered code: G1 F3000 X256.34 Y142.176 E0.1428 Buffered code: G1 X256.27 Y142.106 Buffered code: G0 F7200 X256.299 Y142.133 Buffered code: G0 X259.64 Y145.797 Buffered code: G1 F3000 X256.746 Y148.691 E0.12523 Buffered code: G1 X256.676 Y148.761 Buffered code: G0 F7200 X256.697 Y148.759 Buffered code: G0 X256.613 Y149.748 Buffered code: G0 X256.045 Y150.932 Buffered code: G1 F3000 X259.02 Y153.908 E0.12876 Buffered code: G1 X259.09 Y153.978 Buffered code: G0 F7200 X259.349 Y155.139 ==> 1472 bytes Code buffer space: 2232 Configured SPI speed: 8000000 Hz Full transfers per second: 41.83 Maximum length of RX/TX data transfers: 2808/1616 File /opt/dsf/sd/gcodes/bltouch.gcode is selected, processing
M122 b121
m122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3beta (2021-01-21 11:34:37) Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1) Never used RAM 3620, free system stack 0 words Move 90 HEAT 91 CanAsync 66 CanRecv 74 CanClock 66 TMC 56 MAIN 197 AIN 62 Last reset 00:44:52 ago, cause: power up Last software reset time unknown, reason: OutOfMemory, available RAM 15632, slot 1 Software reset code 0x01c0 ICSR 0x00000000 SP 0x20003578 Task MAIN Freestk 747 ok Stack: 20000d10 00011ceb 20000d10 0001df61 00000000 00004008 20000d10 0001ded5 20000d0c 00004000 a5a5a5a5 a5a5a5a5 00000000 0001dd9d 00004000 00018b21 a5a5a5a5 00018b3d a5a5a5a5 00011b39 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: position 331894, 859.0 steps/mm, standstill, SG min/max 0/496, read errors 0, write errors 0, ifcnt 19, reads 12002, writes 0, timeouts 0, DMA errors 0, steps req 109046 done 109046 Moves scheduled 6688, completed 6688, in progress 0, hiccups 0, step errors 0, maxPrep 498, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 4, peak Rx sync delay 214, resyncs 0, no step interrupt scheduled VIN: 23.5V MCU temperature: min 41.6C, current 66.4C, max 68.0C Ticks since heat task active 204, ADC conversions started 2684508, completed 2684507, timed out 0 Last sensors broadcast 0x00000002 found 1 210 ticks ago, loop time 0 CAN messages queued 3626, send timeouts 0, received 4384, lost 0, free buffers 36, min 36, error reg 0 dup 0, oos 0, bm 0, wbm 0 === Filament sensors === Interrupt 4 to 49us, poll 9 to 706us Driver 0: pos 5.74, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
Did it help with theunder extrusion?
@Phaedrux i cant tell at the moment. with the new firmware my heater is going crazy
after 2-3 Minutes into the Print the Temp sensor starting to jump from 250 to 18-25 °C and my toolfan starts and stops accordingly to the temperature... when under 50°C it stops , above it starts.
Sounds like a bad connection on the thermistor
that was my first idea too, but when no print is running the temp is stable
@Frederik said in Random underextrusion Problem:
Yes, because when no print is running, the cables are stationary.
@Phaedrux definetly not the cables
i resetted the Toolboard with the 2 knobs and restarted the same file:
absolute stable, nothing touched on the cables
@Phaedrux but what i can tell about the under extrusion, it seems that the artefacts are gone
after this i will print the same Led_Bar.gcode from the last time,
where the Problem occured.But it seems that the Print Quality is restored
This is a Picture where the Problem is better visible. It was switching between under and over extrusion in always the same intervals
M122 at the end of the Print,
I have to print a bigger object to check if the Problem is gonem122 b121 Diagnostics for board 121: Duet TOOL1LC firmware version 3.3beta (2021-01-21 11:34:37) Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1) Never used RAM 3692, free system stack 0 words Move 90 HEAT 91 CanAsync 66 CanRecv 74 CanClock 66 TMC 56 MAIN 205 AIN 62 Last reset 00:35:43 ago, cause: software Last software reset time unknown, reason: OutOfMemory, available RAM 15632, slot 1 Software reset code 0x01c0 ICSR 0x00000000 SP 0x20003578 Task MAIN Freestk 747 ok Stack: 20000d10 00011ceb 20000d10 0001df61 00000000 00004008 20000d10 0001ded5 20000d0c 00004000 a5a5a5a5 a5a5a5a5 00000000 0001dd9d 00004000 00018b21 a5a5a5a5 00018b3d a5a5a5a5 00011b39 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 a5a5a5a5 Driver 0: position 450451, 859.0 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 14, reads 831, writes 0, timeouts 0, DMA errors 0, steps req 0 done 0 Moves scheduled 9915, completed 9915, in progress 0, hiccups 0, step errors 0, maxPrep 0, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0 Peak sync jitter 3, peak Rx sync delay 183, resyncs 0, no step interrupt scheduled VIN: 23.5V MCU temperature: min 48.7C, current 69.2C, max 74.0C Ticks since heat task active 57, ADC conversions started 2139229, completed 2139228, timed out 0 Last sensors broadcast 0x00000002 found 1 64 ticks ago, loop time 0 CAN messages queued 52, send timeouts 0, received 23, lost 0, free buffers 36, min 36, error reg 0 dup 0, oos 0, bm 0, wbm 0 === Filament sensors === Interrupt 4 to 8us, poll 28 to 181us Driver 0: pos 5.54, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
m122 === Diagnostics === RepRapFirmware for Duet 3 MB6HC version 3.3beta running on Duet 3 MB6HC v1.01 or later (SBC mode) Board ID: 08DJM-956BA-NA3TN-6J9DL-3S46S-99AUT Used output buffers: 1 of 40 (13 max) === RTOS === Static ram: 149784 Dynamic ram: 60768 of which 80 recycled Never used RAM 140040, free system stack 139 words Tasks: Linux(blocked,145) HEAT(blocked,299) CanReceiv(blocked,880) CanSender(blocked,346) CanClock(blocked,326) TMC(blocked,16) MAIN(running,922) IDLE(ready,20) Owned mutexes: HTTP(MAIN) === Platform === Last reset 00:35:46 ago, cause: power up Last software reset at 2021-01-31 18:05, reason: User, none spinning, available RAM 139964, slot 0 Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00400000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a Error status: 0x00 Aux0 errors 0,0,0 Aux1 errors 0,0,0 MCU temperature: min 47.4, current 50.1, max 50.5 Supply voltage: min 24.0, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes 12V rail voltage: min 12.1, current 12.1, max 12.2, under voltage events: 0 Driver 0: position 111650, standstill, reads 1676, writes 23 timeouts 0, SG min/max 0/852 Driver 1: position -9570, standstill, reads 1676, writes 23 timeouts 0, SG min/max 0/1023 Driver 2: position 15080, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/868 Driver 3: position 0, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/862 Driver 4: position 0, standstill, reads 1677, writes 23 timeouts 0, SG min/max 0/877 Driver 5: position 0, standstill, reads 1686, writes 14 timeouts 0, SG min/max 0/0 Date/time: 2021-01-31 19:12:16 Slowest loop: 60.63ms; fastest: 0.03ms === Storage === Free file entries: 10 SD card 0 not detected, interface speed: 37.5MBytes/sec SD card longest read time 0.0ms, write time 0.0ms, max retries 0 === Move === DMs created 125, maxWait 640640ms, bed compensation in use: none, comp offset 0.000 === MainDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [1, 0, 70], CDDA state -1 === AuxDDARing === Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1 === Heat === Bed heaters = 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = 2 -1 -1 -1 Heater 0 is on, I-accum = 0.4 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Movement lock held by null HTTP* is doing "M122" in state(s) 0 Telnet is idle in state(s) 0 File* is doing "M190 S100" in state(s) 0 USB is idle in state(s) 0 Aux is idle in state(s) 0 Trigger* is idle in state(s) 0 Queue* is idle in state(s) 0 LCD is idle in state(s) 0 SBC is idle in state(s) 0 Daemon is idle in state(s) 0 Aux2 is idle in state(s) 0 Autopause is idle in state(s) 0 Code queue is empty. === Filament sensors === Extruder 0: no data received === CAN === Messages queued 18772, send timeouts 22, received 26574, lost 102, longest wait 6ms for reply type 6029, peak Tx sync delay 16884, free buffers 48 (min 45) === SBC interface === State: 4, failed transfers: 0 Last transfer: 2ms ago RX/TX seq numbers: 17148/17148 SPI underruns 0, overruns 0 Number of disconnects: 0, IAP RAM available 0x2d584 Buffer RX/TX: 56/1312-0 === Duet Control Server === Duet Control Server v3.2.0 File: Buffered code: M104 S250 Buffered code: M109 S250 Buffered code: M82 ;absolute extrusion mode Buffered code: G1 Z15.0 F6000 ;Move the platform down 15mm Buffered code: G1 X50 Y380 F3000 Buffered code: G92 E0 Buffered code: G1 F200 E35 Buffered code: G92 E0 Buffered code: M83 ;relative extrusion mode Buffered code: G1 F2100 E-0.6 Buffered code: ;LAYER_COUNT:47 Buffered code: ;LAYER:0 Buffered code: M107 Buffered code: G0 F3600 X138.176 Y161.255 Z0.3 Buffered code: G1 F2100 E0.6 Buffered code: G1 F1500 X138.735 Y160.865 E0.03128 Buffered code: G1 X139.335 Y160.543 E0.03125 Buffered code: G1 X139.968 Y160.294 E0.03122 Buffered code: G1 X140.627 Y160.121 E0.03127 Buffered code: G1 X141.301 Y160.026 E0.03124 Buffered code: G1 X141.77 Y160.007 E0.02154 Buffered code: G1 X147.626 Y160.007 E0.26878 Buffered code: G1 X148.306 Y160.047 E0.03127 Buffered code: G1 X148.976 Y160.166 E0.03123 Buffered code: G1 X149.628 Y160.363 E0.03126 Buffered code: G1 X150.252 Y160.635 E0.03124 Buffered code: G1 X150.84 Y160.979 E0.03127 Buffered code: G1 X151.384 Y161.389 E0.03127 Buffered code: G1 X151.851 Y161.837 E0.0297 ==> 1228 bytes Code buffer space: 2784 Configured SPI speed: 8000000 Hz Full transfers per second: 25.02 Maximum length of RX/TX data transfers: 3092/1456 File /opt/dsf/sd/gcodes/4x_glass_Bed_holder.gcode is selected, processing
When you pid tuned the bed, did you put B0 in the result?
The new tuning hint leaves it off, so if you just copied that rather than using M500, it will default to bang bang.
Wouldn't have thought it'd affect that high up the print and you should see a cyclic temp variation, but worth checking. -
@OwenD Thanks for the tip. I checked it, in my config was the old version, but in config.override there was the new Version with B0 at the end.
But i have this Parameter normal in a additional Line
LikeM307 H2 B0 S1.00 ;PID Parameters Bed for 110°C M307 H0 R0.585 C805.600:805.600 D2.90 S1.00 V24.1
Regards
Frederik -
Yesterday i did some testprints with the extruder connected to the Toolboard, then to the Mainboard.
The first row of test was a disaster when connected to the Toolboard Driver.
Again Massive Underextrusion and other artefacts.
The Heatertemp jumped around and the LaserFIlamentSensor was constantly reporting to little movement (30:130,3mm)
i had to abort the print at around 50% , after restarting it from Pause around 8 Times.
The same Print connected to the Mainboard Driver 5: No Heater or Filament Sensor Errors! The Print Finished as expected.
Today i changed the Toolboard Firmware to the Version Previous Januar16, that is also in the 3.3Beta Folder.
I running the same Prints again to check if it is better.
since Updating to 3.3 i have no BLTouch Probing Errors the last 2 Days.
Regards
Frederik
