G32 ERROR
This post is deleted! -
; Configuration file for Duet WiFi (firmware version 3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"DIVINCI-3D (MP4560)" ; set printer name M669 K1 ; select CoreXY mode ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P10 R1 T2:2:2:2 S1 ; physical drive 0 goes forwards M569 P11 R1 T2:2:2:2 S1 ; physical drive 1 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M569 P4 S1 ; physical drive 4 goes forwards M569 P5 S1 ; physical drive 5 goes Backwards M569 P6 S1 ; physical drive 6 goes Backwards M569 P8 S0 ; physical drive 7 goes Backwards M569 P9 S0 ; physical drive 9 goes backwards M584 X10 Y11 Z5:6:8:9 E3:4 ; set drive mapping M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6 ; ZBelts Near Locations M350 X32 Y32 Z16 E16:16 I1 ; configure microstepping with interpolation M92 X80.00 Y80.00 Z410.00 E415.00:415.00 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2) M906 X1800 Y1800 Z1000 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X460 Y460 Z460 S0 ; set axis maxima M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z M574 Z2 S1 p"!exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop" ; Configure active- high endstops for high end on Z ; Z-Probe M558 P1 C"zprobe.in" H25 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds G31 P500 X0 Y0 Z2.5 ; set Z probe trigger value, offset and trigger height M557 X20:440 Y20:440 S20 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 M307 H0 A11 C99000 D2000 B1 ; enable bang-bang mode for the bed heater and set PWM limit M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1 M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S2 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs2 M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2 M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950 ; configure sensor 3 as thermistor on pin duex.e2temp M950 H3 C"duex.e2heat" T3 ; create chamber heater output on duex.e2heat and map it to sensor 3 M307 H3 A11 C99000 D2000 B1 ; enable bang-bang mode for the chamber heater and set PWM limit M141 H3 ; map chamber to heater 3 ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on ; Tools M563 P0 S"MAIN EXTRUDER" D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C M563 P1 S"SECOND EXTRUDER" D1 H2 F0 ; define tool 1 G10 P1 X0 Y0 Z0 ; set tool 1 axis offsets G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C ; Custom settings are not defined ; Miscellaneous M575 P1 S1 B57600 ; enable support for PanelDue M501 ; load saved parameters from non-volatile memory M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss T0 ; select first tool
; homeall.g ; called to home all axes ; ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time) G91 ; relative positioning G1 H1 Z500 F6000 ; lift Z relative to current position G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass) G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass) G1 H2 X5 Y5 F6000 ; go back a few mm G1 H1 X-465 F360 ; move slowly to X axis endstop once more (second pass) G1 H1 Y-465 F360 ; then move slowly to Y axis endstop G1 H2 Z-500 F6000; G1 X235 Y235 F6000 ; Prob at Center M558 F600 A1 ; Dive fast once G30 ; probe Z M558 F300 A10 ; Slow second dive with more accuracy G30 ; probe z again
Sorry this is in the requested format
thank you
Try removing the M574 Z1 S2 command from config.g - or comment it out - and see if that makes a difference.
In the G31 command you have the probe X and Y offsets as 0 - that means the probe is in the same place as the nozzle - is that the case?
Have you verified that each Z end stop sensor responds correctly as indicated by issuing an M119 command if you operated them manuall?
The printer still under construction so I havent made any offset measurements yet to G31 that would be my next step. But I need to solve this issue first where it home correctly as I wanted to do so. Also when I run m119 I get Z endstops to trigger correctly. But the problem is when I click home all the only one axis moves down the other 3 sets as where they are
@moe-adams9093 said in G32 ERROR:
Before you mapped all four of those steppers to Z did you try them mapped just one at time to Z to verify that each worked?
You have one of the switches inverted with !, but not the rest. I assume they are all the same type of switch, yes? If so, you would need a ! before each pin name.
No I will do that tonight when I get back home and do some recrackin.
@Phaedrux man your sharp yes I think thats the problem. I will try it tonight because when I homed only that axis was moving and the rest wasn't moving at all. I thought when I combine all of them they should automatically be the same type. Thanks
So I went ahead and did combine all of my endstops on a single line in this order
M574 Z2 S1 p"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
it crashed my firmware so I had to do a hard reset and erase firmware and reupload new firmware but this time I did install 3.2. and also I did try just one endstop
M574 Z2 S1 p"!exp.e2stop . ti did ignore the bed to go down to 500 it went to -500. -
I tried CAP P still doing the same thing
its to late to post M112 because I already fixed this issue. now Im dealing with homing-all problem it just not working. I don't know if the duet can allow to use EndStops on max and Zprob On MIN
Yes it can - just need to get the settings right.
Is homing using the Z end stop sensors working?
so now I was able to get one end stop to work but when press the end-stop all 4 z motors stop not individually.
when I write this code and hit save and restart the board Deg light will flash red and the bord is not reachable at this stage so I had to manually erase the firmware and reupload all files againM574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e5stop+!duex.e6stop";
this line of Code it did work but when I press any of the end-stop all 4 Z motors Stop not individually
I have no idea why you should have had to erase the firmware - that makes no sense at all.
In any case since you had to upload all the files again but post config.g and homeall.g using the </> tag to be sure we are looking at the most recent.
Can you please send M122 and M98 P"config.g" and post the results?
We are assuming you are on RRF3 but I don't think we've actually checked yet.
It certainly can. The endstops are configured with M574 and called into action with a G1 H1 Z move, and the probe is configured with M558/G31 and called into action with G30. So as long as both are configured, you can choose which to use by either using a G1 H1 Z move or a G30/G29.
