G32 ERROR
5.1k
    moe.adams9093
    The printer still under construction so I havent made any offset measurements yet to G31 that would be my next step. But I need to solve this issue first where it home correctly as I wanted to do so. Also when I run m119 I get Z endstops to trigger correctly. But the problem is when I click home all the only one axis moves down the other 3 sets as where they are
    undefined 1 Reply Last reply 29 Jan 2021, 16:04 Reply Quote 0
      fcwilt @moe.adams9093
      @moe-adams9093 said in G32 ERROR:
      Before you mapped all four of those steppers to Z did you try them mapped just one at time to Z to verify that each worked?
        M574 Z2 S1 p"!exp.e2stop+exp.e3stop+exp.e5stop+exp.e6stop"
        You have one of the switches inverted with !, but not the rest. I assume they are all the same type of switch, yes? If so, you would need a ! before each pin name.
        undefined 1 Reply Last reply 29 Jan 2021, 16:37 Reply Quote 0
          moe.adams9093
          No I will do that tonight when I get back home and do some recrackin.
            moe.adams9093 @Phaedrux
            @Phaedrux man your sharp yes I think thats the problem. I will try it tonight because when I homed only that axis was moving and the rest wasn't moving at all. I thought when I combine all of them they should automatically be the same type. Thanks
              moe.adams9093
              So I went ahead and did combine all of my endstops on a single line in this order
              M574 Z2 S1 p"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
              it crashed my firmware so I had to do a hard reset and erase firmware and reupload new firmware but this time I did install 3.2. and also I did try just one endstop
              M574 Z2 S1 p"!exp.e2stop . ti did ignore the bed to go down to 500 it went to -500.
              undefined 1 Reply Last reply 31 Jan 2021, 19:22 Reply Quote 0
                Veti
                M574 Z2 S1 p
                dunno if it matter but use a capital P
                  moe.adams9093
                  I tried CAP P still doing the same thing
                    Veti @moe.adams9093
                    please post a M122 after the crash
                      moe.adams9093
                      its to late to post M112 because I already fixed this issue. now Im dealing with homing-all problem it just not working. I don't know if the duet can allow to use EndStops on max and Zprob On MIN
                      undefined 1 Reply Last reply 31 Jan 2021, 20:52 Reply Quote 0
                        Yes it can - just need to get the settings right.
                        Is homing using the Z end stop sensors working?
                          moe.adams9093
                          so now I was able to get one end stop to work but when press the end-stop all 4 z motors stop not individually.
                            moe.adams9093
                            when I write this code and hit save and restart the board Deg light will flash red and the bord is not reachable at this stage so I had to manually erase the firmware and reupload all files again
                            M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop";
                              moe.adams9093
                              M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e5stop+!duex.e6stop";
                              this line of Code it did work but when I press any of the end-stop all 4 Z motors Stop not individually
                              undefined 1 Reply Last reply 31 Jan 2021, 22:35 Reply Quote 0
                                I have no idea why you should have had to erase the firmware - that makes no sense at all.
                                In any case since you had to upload all the files again but post config.g and homeall.g using the </> tag to be sure we are looking at the most recent.
                                  Can you please send M122 and M98 P"config.g" and post the results?
                                  We are assuming you are on RRF3 but I don't think we've actually checked yet.
                                  It certainly can. The endstops are configured with M574 and called into action with a G1 H1 Z move, and the probe is configured with M558/G31 and called into action with G30. So as long as both are configured, you can choose which to use by either using a G1 H1 Z move or a G30/G29.
                                  undefined 1 Reply Last reply 1 Feb 2021, 06:18 Reply Quote 0
                                    @Phaedrux Ok so after long hours of troubleshooting and looking on duet documentation and also at duet form to find someone had the same issue. so at first when I added this code line to my config.g
                                    the moment when I hit save and restart the system never came back online my Degnostic light on the DuetEthernet Board was flashing red. at that stage, I went and connected via USB to enable M552S1 but my Yat Couldn't find the duet so I went ahead and jumped the 2 erase headers and reinstall the firmware everything came back as it supposed I went back a gain and added same code and it worked fine after that I'm not sure why the board did crash. so now this is my latest configuration files
                                    ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
                                    M550 P"DIVINCI-3D (MP4560)" ; set printer name
                                    M669 K1 ; select CoreXY mode
                                    M586 P0 S1 ; enable HTTP
                                    M586 P1 S0 ; disable FTP
                                    M586 P2 S0 ; disable Telnet
                                    M569 P10 R1 T2:2:2:2 S1 ; physical drive 0 goes forwards
                                    M569 P11 R1 T2:2:2:2 S1 ; physical drive 1 goes forwards
                                    M569 P4 S1 ; physical drive 4 goes forwards
                                    M569 P5 S1 ; physical drive 5 goes Backwards
                                    M569 P6 S1 ; physical drive 6 goes Backwards
                                    M569 P8 S0 ; physical drive 7 goes Backwards
                                    M569 P9 S0 ; physical drive 9 goes backwards
                                    M584 X10 Y11 Z5:6:8:9 E3:4 ; set drive mapping
                                    M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6 ; ZBelts Near Locations
                                    M92 X40.00 Y40.00 Z410.00 E415.00:415.00 ; set steps per mm
                                    M566 X900.00 Y900.00 Z12.00 E120.00:120.00 ; set maximum instantaneous speed changes (mm/min)
                                    M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00 ; set maximum speeds (mm/min)
                                    M201 X500.00 Y500.00 Z40.00 E250.00:250.00 ; set accelerations (mm/s^2)
                                    M906 X1800 Y1800 Z1000 E500:500 I30 ; set motor currents (mA) and motor idle factor in per cent
                                    M84 S30 ; Set idle timeout
                                    M208 X460 Y460 Z460 S0 ; set axis maxima
                                    M574 X1 S1 P"!xstop" ; configure active-high endstop for low end on X via pin !xstop
                                    M574 Y1 S1 P"!ystop" ; configure active-high endstop for low end on Y via pin !ystop
                                    M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop" ; configure Z-probe endstop for low end on Z
                                    M558 P1 C"zprobe.in" H25 F600 T6000 ; set Z probe type to unmodulated and the dive height + speeds
                                    M557 X20:440 Y20:440 S20 ; define mesh grid
                                    M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 0 as thermistor on pin bedtemp
                                    M307 H0 A11 C99000 D2000 B1 ; enable bang-bang mode for the bed heater and set PWM limit
                                    M308 S1 P"spi.cs1" Y"thermocouple-max31856" ; configure sensor 1 as thermocouple via CS pin spi.cs1
                                    M308 S2 P"spi.cs2" Y"thermocouple-max31856" ; configure sensor 2 as thermocouple via CS pin spi.cs2
                                    M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                                    M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                    M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950 ; configure sensor 3 as thermistor on pin duex.e2temp
                                    M950 H3 C"duex.e2heat" T3 ; create chamber heater output on duex.e2heat and map it to sensor 3
                                    M307 H3 A11 C99000 D2000 B1 ; enable bang-bang mode for the chamber heater and set PWM limit
                                    M141 H3 ; map chamber to heater 3
                                    M106 P0 S1 H-1 ; set fan 0 value. Thermostatic control is turned on
                                    M106 P1 S1 H2 T45 ; set fan 1 value. Thermostatic control is turned on
                                    M950 F2 C"fan2" Q500 ; create fan 2 on pin fan2 and set its frequency
                                    M106 P2 S1 H1:2 T45 ; set fan 2 value. Thermostatic control is turned on
                                    M563 P0 S"MAIN EXTRUDER" D0 H1 F0 ; define tool 0
                                    M563 P1 S"SECOND EXTRUDER" D1 H2 F0 ; define tool 1
                                    T0 ; select first tool
                                    ; homeall.g
                                    ; called to home all axes
                                    G91 ; relative positioning
                                    G1 H1 Z500 F6000 ; lift Z relative to current position
                                    G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
                                    G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
                                    G1 H2 X5 Y5 F6000 ; go back a few mm
                                    G1 H1 X-465 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H1 Y-465 F360 ; then move slowly to Y axis endstop
                                    G1 X235 Y235 F6000 ; Prob at Center
                                    M558 F600 A1 ; Dive fast once
                                    G30 ; probe Z
                                    M558 F300 A10 ; Slow second dive with more accuracy
                                    G30 ; probe z again
                                    1/31/2021, 11:51:21 PM: M122: === Diagnostics ===
                                    RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5
                                    Board ID: 08DLM-996RU-N8PS0-7J9D8-3S86T-1B8VP
                                    Used output buffers: 3 of 24 (24 max)
                                    Static ram: 23460
                                    Dynamic ram: 70344 of which 40 recycled
                                    Never used RAM 18236, free system stack 210 words
                                    Tasks: NETWORK(ready,173) HEAT(blocked,309) DUEX(blocked,35) MAIN(running,452) IDLE(ready,19)
                                    Owned mutexes:
                                    Last reset 00:02:05 ago, cause: power up
                                    Last software reset at 2021-01-31 23:46, reason: User, GCodes spinning, available RAM 18236, slot 0
                                    Error status: 0x04
                                    Aux0 errors 0,0,0
                                    MCU temperature: min 26.3, current 26.8, max 27.1
                                    Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
                                    Driver 0: position 0, standstill, SG min/max not available
                                    Driver 1: position 0, standstill, SG min/max not available
                                    Driver 2: position 0, standstill, SG min/max not available
                                    Driver 3: position 0, standstill, SG min/max not available
                                    Driver 4: position 0, standstill, SG min/max not available
                                    Driver 5: position 0, standstill, SG min/max not available
                                    Driver 6: position 0, standstill, SG min/max not available
                                    Driver 7: position 0, standstill, SG min/max not available
                                    Driver 8: position 0, standstill, SG min/max not available
                                    Driver 9: position 0, standstill, SG min/max not available
                                    Driver 10: position 0
                                    Driver 11: position 0
                                    Date/time: 2021-01-31 23:51:20
                                    Cache data hit count 194997097
                                    Slowest loop: 8.94ms; fastest: 0.21ms
                                    === Storage ===
                                    Free file entries: 10
                                    SD card longest read time 3.9ms, write time 2.4ms, max retries 0
                                    === MainDDARing ===
                                    === AuxDDARing ===
                                    Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
                                    Heater 1 is on, I-accum = 0.0
                                    Segments left: 0
                                    Movement lock held by null
                                    HTTP is idle in state(s) 0
                                    Telnet is idle in state(s) 0
                                    File is idle in state(s) 0
                                    USB is idle in state(s) 0
                                    Aux is idle in state(s) 0
                                    Trigger is idle in state(s) 0
                                    Queue is idle in state(s) 0
                                    LCD is idle in state(s) 0
                                    Daemon is idle in state(s) 0
                                    Code queue is empty.
                                    === Network ===
                                    Slowest loop: 25.61ms; fastest: 0.07ms
                                    HTTP sessions: 2 of 8
                                    Interface state active, link 100Mbps full duplex
                                    === DueX ===
                                    Read count 0, 0.00 reads/min
                                    **The Problem now when I click HomeZ only driver number 6 moves down (!exp.e6stop) and if press any end-stop it will stop it but the rest they do not move at all this is the problem I have I don't know if the Duex5 is bad and not communicating effectively with the duet ethernet board. **
                                      @Phaedrux said in G32 ERROR:
                                      And just to confirm, you have all Z motors and endstops connected to the Duex?
                                      And your duex is wired up for power/ground as shown here?
                                      https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
                                        moe.adams9093
                                        1/31/2021, 11:51:56 PM: M98 P"config.g": HTTP is enabled on port 80
                                        FTP is disabled
                                        TELNET is disabled
                                        Error: bad grid definition: Too many grid points; suggest increase spacing to 21.0mm
                                        Warning: Macro file config-override.g not found
                                        sorry I thought I did post my M98. but everything works correctly on my duex5 except my end stops. If I run M564 S0 H0 all Zmotors work correctly. the duex5 is wired correctly as and all endstops wired correctly as well
                                          fcwilt
                                          The comment says 7 the command specifies 8.
                                          Have you manually activated each Z end stop sensor, one at a time, and run M119 to verify the reported end stop state?
                                          27 out of 108
