Faulty Smart Effector
Smart effector for delta printers
775
    tcj
    since today my smart effector seems to be faulty.
    It continuously triggers even with the board alone (without heatsink, arms, fans ..), green trigger light and 1000 value in web control.
    It flashes three times when turned on and then lights green all the time.
    I can't see any damage
    HELP
    Thanks
    Thomas
      Veti
      try changing the sensitivity
      https://duet3d.dozuki.com/Wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Section_Programming_the_sensitivity
        tcj
        Thanks, but that is not the only thing that I tried several times but without any success. 😞
          Veti
          post high resolution pictures of the front and back of the effector
            tcj
            I've already inspected the whole effector with a magnifying glass
            There is nothing abnormally
              When and where did you purchase it?
                tcj
                Sep '19 at filafarm.de
                I've already sent them a mail
                  Photos? Maybe we can see something you can't?
                  Wiring?
                  Did anything change recently with the printer?
                  When was it working last?
                    tcj
                    Wiring is ok - worked for months
                    Updated RRF a few days ago, but not yesterday
                    Working last night at last
                      Is that a scratch on the second photo on the bottom edge?
                        tcj
                        yes, but it's there since I received it and it is only on the lacquer coat
                          What M672 are you using?
                            tcj
                            tried M672 S131:131 without success - even no flashing of the LED
                            and before you're asking 😉
                            ;### Z-Probe ###
                            M558 P8 R0.2 F1200 H2 C"zprobe.in"
                            G31 P100 X0 Y0 Z-0.19           		; Set Z probe trigger value, offset and trigger height
                            M557 R180 S40                          		; Define mesh grid
                              Veti
                              @tcj said in Faulty Smart Effector:
                              this is missing the zprobe.mod to control the sensitivity
                              try C"zprobe.in+zprobe.mod"
                              undefined 2 Replies Last reply 31 Jan 2021, 18:34 Reply Quote 1
                                tcj @Veti
                                @Veti 😽
                                  tcj @Veti
                                  @Veti Thank you so much!
                                  It works!
                                    Lightpath
                                    @Veti said in Faulty Smart Effector:
                                    This should be in the documentation.
                                    undefined 1 Reply Last reply 25 Feb 2021, 16:36 Reply Quote 1
                                      Phaedrux Moderator @Lightpath
                                      @Lightpath said in Faulty Smart Effector:
                                      Consider it done.
