    G32 ERROR
    5.4k
    • moe.adams9093undefined
      moe.adams9093 @Phaedrux
      @Phaedrux Ok so after long hours of troubleshooting and looking on duet documentation and also at duet form to find someone had the same issue. so at first when I added this code line to my config.g
      M574 Z2 S1 P"!duex.e2stop+!duex.e3stop+!duex.e5stop+!duex.e6stop";
      the moment when I hit save and restart the system never came back online my Degnostic light on the DuetEthernet Board was flashing red. at that stage, I went and connected via USB to enable M552S1 but my Yat Couldn't find the duet so I went ahead and jumped the 2 erase headers and reinstall the firmware everything came back as it supposed I went back a gain and added same code and it worked fine after that I'm not sure why the board did crash. so now this is my latest configuration files
      ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Oct 13 2020 21:14:55 GMT-0500 (Central Daylight Time)
      G90                                                     	; send absolute coordinates...
      M83                                                     	; ...but relative extruder moves
      M550 P"DIVINCI-3D (MP4560)"                             	; set printer name
      M669 K1                                                 	; select CoreXY mode
      M552 P0.0.0.0 S1                                        	; enable network and acquire dynamic address via DHCP
      M586 P0 S1                                              	; enable HTTP
      M586 P1 S0                                              	; disable FTP
      M586 P2 S0                                              	; disable Telnet
      M569 P10  R1 T2:2:2:2  S1  									; physical drive 0 goes forwards
      M569 P11  R1 T2:2:2:2  S1  									; physical drive 1 goes forwards
      M569 P3 S1                                             		; physical drive 3 goes forwards
      M569 P4 S1                                              	; physical drive 4 goes forwards
      M569 P5 S1                                              	; physical drive 5 goes Backwards
      M569 P6 S1 													; physical drive 6 goes Backwards
      M569 P8 S0			          								; physical drive 7 goes Backwards
      M569 P9 S0                                              	; physical drive 9 goes backwards
      M584 X10 Y11 Z5:6:8:9 E3:4                              	; set drive mapping
      M671 X5.0:455.0:455.0:5.0 Y25.0:25.0:455.0:455.0 S6    	; ZBelts Near Locations
      M350 X16 Y16 Z16 E16:16 I1                              	; configure microstepping with interpolation
      M92 X40.00 Y40.00 Z410.00 E415.00:415.00 					; set steps per mm
      M566 X900.00 Y900.00 Z12.00 E120.00:120.00              	; set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z400 E1200.00:1200.00        		; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z40.00 E250.00:250.00           		; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1000 E500:500 I30                     	; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                                 	; Set idle timeout
      M208 X0 Y0 Z0 S1                                        	; set axis minima
      M208 X460 Y460 Z460 S0                                  	; set axis maxima
      M574 X1 S1 P"!xstop"                                    		; configure active-high endstop for low end on X via pin !xstop
      M574 Y1 S1 P"!ystop"                                    		; configure active-high endstop for low end on Y via pin !ystop
      M574 Z1 S2                                              		; configure Z-probe endstop for low end on Z
      M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"	; configure Z-probe endstop for low end on Z
      M558 P1 C"zprobe.in" H25 F600 T6000                      	; set Z probe type to unmodulated and the dive height + speeds
      G31 P500 X0 Y0 Z2.5                                     	; set Z probe trigger value, offset and trigger height
      M557 X20:440 Y20:440 S20                                	; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4725 C7.06e-8 	; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                   	; create bed heater output on bedheat and map it to sensor 0
      M307 H0 A11 C99000 D2000 B1                  				; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                                 	; map heated bed to heater 0
      M143 H0 S120                                            	; set temperature limit for heater 0 to 120C
      M308 S1 P"spi.cs1" Y"thermocouple-max31856"             	; configure sensor 1 as thermocouple via CS pin spi.cs1
      M950 H1 C"e0heat" T1                                    	; create nozzle heater output on e0heat and map it to sensor 1
      M307 H1 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
      M308 S2 P"spi.cs2" Y"thermocouple-max31856"             	; configure sensor 2 as thermocouple via CS pin spi.cs2
      M950 H2 C"e1heat" T2                                    	; create nozzle heater output on e1heat and map it to sensor 2
      M307 H2 B0 S1.00                                        	; disable bang-bang mode for heater  and set PWM limit
      M308 S3 P"duex.e2temp" Y"thermistor" T10000 B3950       	; configure sensor 3 as thermistor on pin duex.e2temp
      M950 H3 C"duex.e2heat" T3                               	; create chamber heater output on duex.e2heat and map it to sensor 3
      M307 H3 A11 C99000 D2000 B1                             	; enable bang-bang mode for the chamber heater and set PWM limit
      M141 H3                                                 	; map chamber to heater 3
      M950 F0 C"fan0" Q500                                    	; create fan 0 on pin fan0 and set its frequency
      M106 P0 S1 H-1                                          	; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"fan1" Q500                                    	; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H2 T45                                       	; set fan 1 value. Thermostatic control is turned on
      M950 F2 C"fan2" Q500                                    	; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1:2 T45                                     	; set fan 2 value. Thermostatic control is turned on
      M563 P0 S"MAIN EXTRUDER" D0 H1 F0                       	; define tool 0
      G10 P0 X0 Y0 Z0                                         	; set tool 0 axis offsets
      G10 P0 R0 S0                                            	; set initial tool 0 active and standby temperatures to 0C
      M563 P1 S"SECOND EXTRUDER" D1 H2 F0                     	; define tool 1
      G10 P1 X0 Y0 Z0                                         	; set tool 1 axis offsets
      G10 P1 R0 S0                                            	; set initial tool 1 active and standby temperatures to 0C
      M575 P1 S1 B57600                                       	; enable support for PanelDue
      M501                                                    	; load saved parameters from non-volatile memory
      M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000"      	; set voltage thresholds and actions to run on power loss
      T0                                                      	; select first tool
      ; homeall.g
      ; called to home all axes
      G1 H1 Z500 F6000          ; lift Z relative to current position
      G1 H1 X-465 F8000 ; move quickly to X endstop and stop there (first pass)
      G1 H1 Y-465 F8000 ; move quickly to Y endstop and stop there (first pass)
      G1 H2 X5 Y5 F6000       ; go back a few mm
      G1 H1 X-465 F360        ; move slowly to X axis endstop once more (second pass)
      G1 H1 Y-465 F360        ; then move slowly to Y axis endstop
      G1 X235 Y235 F6000      ; Prob at Center
      M558 F600 A1 		    ; Dive fast once
      G30			            ; probe Z
      M558 F300 A10 		    ; Slow second dive with more accuracy
      G30			            ; probe z again
      1/31/2021, 11:51:21 PM: M122: === Diagnostics ===
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.2 running on Duet Ethernet 1.02 or later + DueX5
      Board ID: 08DLM-996RU-N8PS0-7J9D8-3S86T-1B8VP
      Used output buffers: 3 of 24 (24 max)
      Static ram: 23460
      Dynamic ram: 70344 of which 40 recycled
      Never used RAM 18236, free system stack 210 words
      Tasks: NETWORK(ready,173) HEAT(blocked,309) DUEX(blocked,35) MAIN(running,452) IDLE(ready,19)
      Owned mutexes:
      Last reset 00:02:05 ago, cause: power up
      Last software reset at 2021-01-31 23:46, reason: User, GCodes spinning, available RAM 18236, slot 0
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU temperature: min 26.3, current 26.8, max 27.1
      Supply voltage: min 25.0, current 25.0, max 25.1, under voltage events: 0, over voltage events: 0, power good: yes
      Driver 0: position 0, standstill, SG min/max not available
      Driver 1: position 0, standstill, SG min/max not available
      Driver 2: position 0, standstill, SG min/max not available
      Driver 3: position 0, standstill, SG min/max not available
      Driver 4: position 0, standstill, SG min/max not available
      Driver 5: position 0, standstill, SG min/max not available
      Driver 6: position 0, standstill, SG min/max not available
      Driver 7: position 0, standstill, SG min/max not available
      Driver 8: position 0, standstill, SG min/max not available
      Driver 9: position 0, standstill, SG min/max not available
      Driver 10: position 0
      Driver 11: position 0
      Date/time: 2021-01-31 23:51:20
      Cache data hit count 194997097
      Slowest loop: 8.94ms; fastest: 0.21ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 3.9ms, write time 2.4ms, max retries 0
      === MainDDARing ===
      === AuxDDARing ===
      Bed heaters = 0 -1 -1 -1, chamberHeaters = 3 -1 -1 -1
      Heater 1 is on, I-accum = 0.0
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 25.61ms; fastest: 0.07ms
      HTTP sessions: 2 of 8
      Interface state active, link 100Mbps full duplex
      === DueX ===
      Read count 0, 0.00 reads/min
      **The Problem now when I click HomeZ only driver number 6 moves down (!exp.e6stop) and if press any end-stop it will stop it but the rest they do not move at all this is the problem I have I don't know if the Duex5 is bad and not communicating effectively with the duet ethernet board. **
        @Phaedrux said in G32 ERROR:
        M98 P"config.g" and post the results?
        And just to confirm, you have all Z motors and endstops connected to the Duex?
        And your duex is wired up for power/ground as shown here?
        https://duet3d.dozuki.com/Wiki/Duex2_and_Duex5_Features#Section_Wiring
          moe.adams9093
          1/31/2021, 11:51:56 PM: M98 P"config.g": HTTP is enabled on port 80
          FTP is disabled
          TELNET is disabled
          Error: bad grid definition: Too many grid points; suggest increase spacing to 21.0mm
          Warning: Macro file config-override.g not found
          sorry I thought I did post my M98. but everything works correctly on my duex5 except my end stops. If I run M564 S0 H0 all Zmotors work correctly. the duex5 is wired correctly as and all endstops wired correctly as well
          • fcwiltundefined
            fcwilt
            @moe-adams9093 said in G32 ERROR:
            The comment says 7 the command specifies 8.
            Have you manually activated each Z end stop sensor, one at a time, and run M119 to verify the reported end stop state?
              moe.adams9093
              Yes I did and they all trigger as Z max endstop on m119
                moe.adams9093
                M569 P5 S1
                M569 P6 S1
                M569 P8 S0
                M569 P9 S0
                Yes this is the correct format for all of my z axis motors 2 motors are mirror to the other 2 thats why I have p8 s0 and p9 s0
                • fcwiltundefined
                  fcwilt @moe.adams9093
                  Great.
                  Can you easily remove the bed assembly so we can test each Z stepper one at a time?
                    moe.adams9093
                    I already did to avoid crashes
                      moe.adams9093
                      As I explained driver number 6 on the duex5 works the way it supposed to but when add another endstop to my config.g it won't work like for example and click home Z it won't work only driver 6 even when I added them all
                      • fcwiltundefined
                        Great.
                        Then I would try this.
                        In you config.g file make duplicate entries for the M584 M350 M92 M566 M203 M201 M906 commands.
                        Comment out the first set of commands so you can easily return to using them.
                        In the second set of commands
                        • Change M584 X10 Y11 Z5:6:8:9 E3:4 to M584 X10 Y11 Z5 A6 B8 C9 E3:4
                        • Change the other commands as needed to include the new axes A B and C
                        This will allow you to access each Z stepper individually (as Z A B or C) using the job buttons in the DWC.
                        moe.adams9093undefined 1 Reply Last reply Reply Quote 0
                          moe.adams9093
                          This post is deleted!
                            moe.adams9093 @fcwilt
                            @fcwilt Ok what about when I use my Z-Probe and to run G32 how that going work
                            • fcwiltundefined
                              The changes I suggested were only for TESTING to verify that each Z stepper on it's own was working as expected with no possible interactions with the other Z steppers.
                              Once you were sure that they were working then you would restore the original stepper configuration commands.
                                moe.adams9093
                                Ok make sense thank you
                                  Instead of using exp.e#stop let's try using the pin names for the actual deux pins.
                                  duex.e2stop
                                  duex.e3stop
                                  duex.e4stop
                                  duex.e5stop
                                  duex.e6stop
                                  When using these names I think you can remove the !, but please test carefully.
                                    @Phaedrux so I did move the ! And did exactly as
                                    M574 Z2 S1 P" duex.e2stop+ duex.e3stop+duex.e5stop+ duex.e6stop"; when I click home Z axis are not moving they do get power but no signal
                                      And if you check M119 what does the endstop status say?
                                      If it says the z endstop is triggered but the switch isn't pressed, then you would need to add the ! again to invert the signal.
                                        @Phaedrux yes thats what I got
                                        2/1/2021, 1:30:18 PM: M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                                          moe.adams9093 @moe.adams9093
                                          I'm going to put ! back and see what's going on
                                            moe.adams9093
                                            The only one is communicating probably is e6stop
