    G32 ERROR
    5.4k
    • moe.adams9093undefined
      moe.adams9093
      As I explained driver number 6 on the duex5 works the way it supposed to but when add another endstop to my config.g it won't work like for example and click home Z it won't work only driver 6 even when I added them all
      • fcwiltundefined
        fcwilt @moe.adams9093
        @moe-adams9093 said in G32 ERROR:
        I already did to avoid crashes
        Great.
        Then I would try this.
        In you config.g file make duplicate entries for the M584 M350 M92 M566 M203 M201 M906 commands.
        Comment out the first set of commands so you can easily return to using them.
        In the second set of commands
        • Change M584 X10 Y11 Z5:6:8:9 E3:4 to M584 X10 Y11 Z5 A6 B8 C9 E3:4
        • Change the other commands as needed to include the new axes A B and C
        This will allow you to access each Z stepper individually (as Z A B or C) using the job buttons in the DWC.
        moe.adams9093undefined 1 Reply Last reply Reply Quote 0
          moe.adams9093
          This post is deleted!
            moe.adams9093 @fcwilt
            @fcwilt Ok what about when I use my Z-Probe and to run G32 how that going work
            • fcwiltundefined
              The changes I suggested were only for TESTING to verify that each Z stepper on it's own was working as expected with no possible interactions with the other Z steppers.
              Once you were sure that they were working then you would restore the original stepper configuration commands.
                moe.adams9093
                Ok make sense thank you
                  M574 Z2 S1 P"!exp.e2stop+!exp.e3stop+!exp.e5stop+!exp.e6stop"
                  Instead of using exp.e#stop let's try using the pin names for the actual deux pins.
                  duex.e2stop
                  duex.e3stop
                  duex.e4stop
                  duex.e5stop
                  duex.e6stop
                  When using these names I think you can remove the !, but please test carefully.
                    moe.adams9093 @Phaedrux
                    @Phaedrux so I did move the ! And did exactly as
                    M574 Z2 S1 P" duex.e2stop+ duex.e3stop+duex.e5stop+ duex.e6stop"; when I click home Z axis are not moving they do get power but no signal
                      And if you check M119 what does the endstop status say?
                      If it says the z endstop is triggered but the switch isn't pressed, then you would need to add the ! again to invert the signal.
                        @Phaedrux yes thats what I got
                        2/1/2021, 1:30:18 PM: M119: Endstops - X: not stopped, Y: not stopped, Z: at max stop, Z probe: not stopped
                          moe.adams9093 @moe.adams9093
                          I'm going to put ! back and see what's going on
                            moe.adams9093
                            The only one is communicating probably is e6stop
                              moe.adams9093
                              Its not working. when I added this code
                              M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop+!duex.e4stop";
                              and run M119
                              M119
                              Endstops - X: at min stop, Y: at min stop, Z: no endstop, Z probe: not stopped
                              but If I remove any one of any of the above endstops
                              example:
                              M574 Z2 S1 p"!duex.e6stop+!duex.e5stop+!duex.e3stop";
                              my M119 will show Z end stop is available I don't know what's causing this issue to not take all 4endstops. also when I press any of the endstops they all stop automatically not individually. I don't know whats happening maybe my duex 5 is bad or if you guys know any solution around please let me know. thank you
                                moe.adams9093
                                I believe somehow some of my end stop input on my duex 5 is not responding correctly. can I use stall detection to stop each motor at Zmax. please share your thoughts
                                fcwiltundefined Phaedruxundefined 2 Replies Last reply Reply Quote 0
                                • alankilianundefined
                                  alankilian
                                  @dc42 I hate to jump in and be an idiot, but is it because MaxAxes is set to six in the firmware?
                                  • fcwiltundefined
                                    I have the same board setup as you - Duet 2 WiFi + Duex5.
                                    On my printer I only have 3 Z steppers so my end stop configuration command is:
                                    M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop"
                                    As an experiment I entered this on the DWC Console
                                    M574 Z1 S1 P"!duex.e2stop + !duex.e3stop + !duex.e4stop + !duex.e5stop"
                                    and got this error message:
                                    Error: M574: Unknown pin name 'duex.e5sto'
                                    Notice the last character, the p, is missing.
                                    I then took that same text and created a gcode file with it in my sys directory.
                                    I executed the file with the M98 command and got the same error.
                                    I then used this text to create another gcode file with it in my sys directory:
                                    M574 Z1 S1 P"!exp.4 + !exp.9 + !exp.14 + !exp.19"
                                    which are alternate names for the pins.
                                    I executed the file with the M98 command and got NO error.
                                    Then I executed from the DWC console a M574 and got this:
                                    Endstop configuration:
                                    X: low end switch connected to pin xstop
                                    Y: high end switch connected to pin ystop
                                    Z: low end switches connected to pins !(exp.e2stop,exp.4) !(exp.e3stop,exp.9,spi.cs6,duex.cs6) !(exp.e4stop,exp.14,spi.cs7,duex.cs7) !(exp.e5stop,exp.19,spi.cs8,duex.cs8)
                                    Notice for Z that all four pins are now present - albeit with all possible names for each pin.
                                    It looks like there may be some sort of command length limitation causing the problem.
                                    I tried this test with both 3.1.1 and 3.2.0.
                                    Try the alternate names and see if they work for you.
                                      Phaedrux Moderator @fcwilt
                                      @fcwilt Do you get the same error with the original pin names he had used?
                                      fcwiltundefined 2 Replies Last reply Reply Quote 0
                                      • fcwiltundefined
                                        fcwilt @Phaedrux
                                        @Phaedrux said in G32 ERROR:
                                        Hold on and I will try.
                                          Phaedrux Moderator @alankilian
                                          @alankilian said in G32 ERROR:
                                          It shouldn't because in RRF3 you can use multiple endstops on a single axis. No need to create additional axis anymore.
                                          • fcwiltundefined
                                            fcwilt @Phaedrux
                                            That works.
