    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
    • fcwiltundefined
      fcwilt @oozeBot
      @oozeBot said in oozeBot ele^gant:
      @fcwilt we briefly evaluated geared steppers but went a different direction. With our solution, we were able to move the z-axis much faster than with a geared stepper allowing for considerably faster z-hops, etc.
      Interesting.
      I have no problem moving the bed at the needed speeds.
      But I see you appear to be moving the entire XY gantry - curious.
      Are you seeing any Z belt stretch as the center of mass of the gantry moves?
      oozeBotundefined 1 Reply Last reply Reply Quote 0
      • oozeBotundefined
        oozeBot @fcwilt
        @fcwilt We use 9mm fiberglass reinforced Gates 2GT belts and have not experienced any stretch or degraded performance throughout the gantry’s range of motion- and we have really been pushing our prototypes hard.
        • fcwiltundefined
          fcwilt @oozeBot
          Thanks for the info.
          • oozeBotundefined
            oozeBot
            We've been heads down for awhile now wrapping up the design for our release candidate.. and finally have something to show - our new gantry! It has been completely redesigned to be smaller, lighter, and stiffer than the prototypes.
            We are in love! Check out the belt work..
            fcwiltundefined 1 Reply Last reply Reply Quote 3
            • fcwiltundefined
              fcwilt @oozeBot
              What is the rational for the idler nearest the stepper? The belt leaving the stepper could have run straight to a tensioner positioned closer to the stepper.
              Stephen6309undefined oozeBotundefined 2 Replies Last reply Reply Quote 0
              • Stephen6309undefined
                Stephen6309 @fcwilt
                @fcwilt If that idler is removed, the belt would only wrap half of the pulley and the belt could slip.
                • oozeBotundefined
                  oozeBot @fcwilt
                  @fcwilt said in oozeBot ele^gant:
                  Maximum surface area on the pulley.
                  • fcwiltundefined
                    fcwilt @oozeBot
                    Would you consider posting your calculations showing that much contact area was needed?
                    Thanks again.
                    • Sindariusundefined
                      Sindarius
                      Man that looks sharp
                      • oozeBotundefined
                        oozeBot @fcwilt
                        @fcwilt Gates recommends a minimum of 6 teeth in mesh between the belt and the sprocket. We are using 16 tooth pulleys. Removing that smooth idler would only allow for 4-5 teeth to fully engage. I strongly prefer to fully utilize 180+ degrees of the pulleys to engage 8 teeth minimum.
                        • fcwiltundefined
                          fcwilt @oozeBot
                          Oh.
                          • oozeBotundefined
                            oozeBot
                            We just wrapped up our new build plate, with 3-point leveling, made from .25” ATP-5 precision cast aluminum tooling plate. Fresh off the CNC!
                            Can’t wait to get it mounted for testing!
                            • fcwiltundefined
                              fcwilt @oozeBot
                              Boy, whoever cut that plate has a real hard time making straight cuts!
                              • oozeBotundefined
                                oozeBot @fcwilt
                                @fcwilt we took a bit of creative freedom with the design.. decided not everything on our machines had to be square!
                                • fcwiltundefined
                                  fcwilt @oozeBot
                                  It looks very good - somebody at your end is creative.
                                  I have next to no creativity - using round corners is about as creative as I can get. 😉
                                  • oozeBotundefined
                                    oozeBot
                                    More photos of the new build plate after cleaning it up and getting it installed. We are very pleased but there will be some additional design tweaks. I’ve got to say, I’m really impressed with the mesh bed leveling results..!
                                    • JamesMundefined
                                      JamesM
                                      The wham bam pex surface works good but I have had problems with it coming apart if the material I'm printing with tries to pull up ruining the surface. Seems like the top layer of it comes apart.
                                      • oozeBotundefined
                                        oozeBot @JamesM
                                        @JamesM so far, we’ve had good luck with it after sanding.. but it’s just one of many surfaces we are testing. However, I do understand what you are pointing out about it and will be watching for it..
                                        • oozeBotundefined
                                          oozeBot
                                          We have completed the motion system for the oozeBot ele^gant with all testing complete. It can sustain 400mm/s in X&Y and 250mm/s in Z!
                                          Check out a quick video of it in motion here: https://vimeo.com/515410723
                                          • whopping pochardundefined
                                            whopping pochard
                                            Beautiful machine! It's looking really great.
