    oozeBot Elevate
    My Duet controlled machine
    17
    92
    6.4k
    • oozeBotundefined
      oozeBot @fcwilt
      @fcwilt said in oozeBot ele^gant:
      What is the rational for the idler nearest the stepper? The belt leaving the stepper could have run straight to a tensioner positioned closer to the stepper.
      Maximum surface area on the pulley.
      • fcwiltundefined
        fcwilt @oozeBot
        @oozeBot said in oozeBot ele^gant:
        Would you consider posting your calculations showing that much contact area was needed?
        Thanks again.
        oozeBotundefined 1 Reply Last reply Reply Quote 0
        • Sindariusundefined
          Sindarius
          Man that looks sharp
          • oozeBotundefined
            oozeBot @fcwilt
            @fcwilt Gates recommends a minimum of 6 teeth in mesh between the belt and the sprocket. We are using 16 tooth pulleys. Removing that smooth idler would only allow for 4-5 teeth to fully engage. I strongly prefer to fully utilize 180+ degrees of the pulleys to engage 8 teeth minimum.
            • fcwiltundefined
              fcwilt @oozeBot
              Oh.
              • oozeBotundefined
                oozeBot
                We just wrapped up our new build plate, with 3-point leveling, made from .25” ATP-5 precision cast aluminum tooling plate. Fresh off the CNC!
                Can’t wait to get it mounted for testing!
                • fcwiltundefined
                  fcwilt @oozeBot
                  Boy, whoever cut that plate has a real hard time making straight cuts!
                  • oozeBotundefined
                    oozeBot @fcwilt
                    @fcwilt we took a bit of creative freedom with the design.. decided not everything on our machines had to be square!
                    • fcwiltundefined
                      fcwilt @oozeBot
                      It looks very good - somebody at your end is creative.
                      I have next to no creativity - using round corners is about as creative as I can get. 😉
                      • oozeBotundefined
                        oozeBot
                        More photos of the new build plate after cleaning it up and getting it installed. We are very pleased but there will be some additional design tweaks. I’ve got to say, I’m really impressed with the mesh bed leveling results..!
                        • JamesMundefined
                          JamesM
                          The wham bam pex surface works good but I have had problems with it coming apart if the material I'm printing with tries to pull up ruining the surface. Seems like the top layer of it comes apart.
                          • oozeBotundefined
                            oozeBot @JamesM
                            @JamesM so far, we’ve had good luck with it after sanding.. but it’s just one of many surfaces we are testing. However, I do understand what you are pointing out about it and will be watching for it..
                            • oozeBotundefined
                              oozeBot
                              We have completed the motion system for the oozeBot ele^gant with all testing complete. It can sustain 400mm/s in X&Y and 250mm/s in Z!
                              Check out a quick video of it in motion here: https://vimeo.com/515410723
                              • whopping pochardundefined
                                whopping pochard
                                Beautiful machine! It's looking really great.
                                  Well done. Looking forward to seeing more.
                                  • fcwiltundefined
                                    fcwilt
                                    Your height map is obscenely good - are you just trying to make the rest of us feel inadequate? 😉
                                    What I wouldn't give to have a bed that flat.
                                    And why doesn't your machine try to shake itself apart at those speeds?
                                    I've never tried speeds like that but I'm pretty sure my printers would disassemble themselves in protest.
                                    What printing speeds are you aiming for?
                                    • oozeBotundefined
                                      oozeBot @fcwilt
                                      Thanks! I'd like to think the engineering has something to do with it not rattling itself apart.. 😉 and for the aluminum build plate, depending on our demand, we are considering making custom sizes available for sale to help subsidize the substantial cost of the industrial CNC machine we are purchasing.
                                      We only print in ABS and have found it does best between 60-80mm/s. And since we are focusing on the printed parts needed for our printers, that's our target. However, we've certainly pushed the prototypes harder.. and I truly believe the release candidates are a much more rigid design, so we shall see here very soon!
                                      • fcwiltundefined
                                        fcwilt @oozeBot
                                        @oozeBot
                                        Being able to purchase custom sized beds with appropriate mounting holes would be heaven on earth.
                                        I don't print ABS but I was under the impression that there were newer alternatives that had desirable specs. Yes? No?
                                        • oozeBotundefined
                                          oozeBot @fcwilt
                                          This is something we'd really like to help the community with once we get our design to market..
                                          As for other filaments, the only alternative we'd currently consider is ASA. There are plenty of other specialty filaments out there that have better characteristics, and we've tried most, but we always end up coming back to ABS as it checks all the boxes for our needs.
                                          • oozeBotundefined
                                            oozeBot
                                            One more quick video of our final motion system, this time isolated by each axis. Z is moving at 250mm/s and X&Y is moving at 400mm/s!
                                            https://vimeo.com/515982259
