    Help me! I made a duet3 6ch, and the power failed
    28
    1.3k
    • wanwanundefined
      wanwan
      Burn down a piece of drive. It doesn't matter. However, there is a memory protection failure, what is the reason to help me!
      code_text
      2021/2/4下午3:24:50	M122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DGM-9561L-D63T4-6J1FA-3S46J-KA0RG
      Used output buffers: 3 of 40 (25 max)
      Static ram: 149788
      Dynamic ram: 92280 of which 404 recycled
      Never used RAM 116360, free system stack 204 words
      Tasks: NETWORK(ready,193) ETHERNET(blocked,109) HEAT(blocked,362) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
      Owned mutexes:
      Last reset 00:14:41 ago, cause: power up
      Last software reset at 2021-02-04 14:59, reason: MemoryProtectionFault mmarValid daccViol, GCodes spinning, available RAM 116360, slot 1
      Software reset code 0x4163 HFSR 0x00000000 CFSR 0x00000082 ICSR 0x00400804 BFAR 0x0000003a SP 0x2041fbb8 Task MAIN Freestk 1660 ok
      Stack: 00000000 00000001 00000001 00000000 0000001d 0046ad93 0046b178 610f0000 2042ae18 00000000 2042ae18 0046b0ff 2042ae18 00000000 6ca7badd 0000000a 2042ae18 2042c3ac 00000000 00000001 00000000 0046ad93 2042c3ac 00000000 00000000 0046b0ed 2042c3ac
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 28.8, current 31.2, max 31.5
      Supply voltage: min 3.9, current 3.9, max 4.0, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 3.8, current 3.8, max 4.1, under voltage events: 0
      Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Date/time: 2021-02-04 15:24:49
      Slowest loop: 1.53ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 1.26ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 1 0 0
      === CAN ===
      Messages queued 0, send timeouts 4100, received 0, lost 0, longest wait 0ms for reply type 0, free buffers 48)
      Rushmere3Dundefined jrocklandundefined 2 Replies Last reply Reply Quote 1
      • Rushmere3Dundefined
        Rushmere3D @wanwan
        @wanwan Not sure where you got that but it's not a Duet3D board. I'd suggest asking the seller for help.
        Follow my adventures in 3D Printing, laser cutting and electronics. https://linktr.ee/Rushmere3D
        wanwanundefined 1 Reply Last reply Reply Quote 0
        • wanwanundefined
          wanwan @Rushmere3D
          @Rushmere3D Thank you. I made it myself
          Rushmere3Dundefined 1 Reply Last reply Reply Quote 0
            Rushmere3D @wanwan
            @wanwan That's impressive to be fair and I'm not the person to help, lol.
            • o_lampeundefined
              o_lampe
              @wanwan
              Impressive indeed.
              Do these two parts touch and cause a shortcut?
              • wanwanundefined
                wanwan @o_lampe
                @o_lampe I checked. No problem. And they're parallel connection
                  Are you using our standard RRF 3.2 firmware binary, or have you built your own?
                  • wanwanundefined
                    wanwan @dc42
                    @dc42 Use the official standard firmware. Now the problem has been solved. thank you
                    • o_lampeundefined
                      o_lampe @wanwan
                      @wanwan
                      If you have a few more empty PCBs, you could populate them step-by-step, beginning with the DC-DC power converter and test every function one at a time.
                      Or do a shortcut test on an empty PCB, maybe some inner layers aren't OK?
                      It seems, there is a lot of solder on the pads, maybe there's a heatsink/GND pad under the MPU or the MOSFETs which got too much solderpaste and caused a shortcut?
                      • wanwanundefined
                        wanwan @o_lampe
                        @o_lampe I want to have a cheap DUET3. I decided to do it myself. Now it doesn't seem like a good idea
                          dc42 administrators @wanwan
                          @wanwan said in Help me! I made a duet3 6ch, and the power failed:
                          How did you solve it?
                          I asked about the firmware because the stack trace didn't seem to match up exactly with the map file for the standard firmware binary.
                          wanwanundefined 2 Replies Last reply Reply Quote 0
                          • wanwanundefined
                            wanwan @dc42
                            @dc42 I made a mistake 。Down to 3.0, the problem still exists.
                            • wanwanundefined
                              wanwan @dc42
                              @dc42 This problem is an error that occurred after the driver was burned
                                Can you explain more? I would not expect the firmware to crash even if a driver failed, unless the failed driver fed injection current into the MCU sufficient to cause it to behave incorrectly. What type of driver did you connect that failed?
                                • wanwanundefined
                                  wanwan @dc42
                                  @dc42 Do you mean that the current breaks down the MUC when the drive is burned?
                                    It's possible that a burned driver may feed current into the MCU pin driving Step, Dir, or one of the SPI signals. The input protection diodes shunt this current to Vcc (3.3V). If the current is small enough, operation of the chip will be unaffected. With somewhat higher current, the chip may malfunction, but no permanent damage will be done. Higher still and permanent damage will be done.
                                    What I would ideally like to know is whether the firmware crashed because it didn't get the expected response from the driver (which I would regard as a firmware bug to be fixed), or the MCU crashed because of injection current.
                                    • Vetiundefined
                                      Veti @wanwan
                                      did the parts work out to be more in the end?
                                      • wanwanundefined
                                        wanwan @dc42
                                        @dc42 After hearing your explanation, I think it's ,the MCU crashed because of injection current
                                        • wanwanundefined
                                          wanwan
                                          This is just generated
                                          2021/2/4下午9:57:21	M122
                                          Used output buffers: 1 of 40 (25 max)
                                          Static ram: 149788
                                          Never used RAM 116360, free system stack 187 words
                                          Tasks: NETWORK(ready,223) ETHERNET(blocked,109) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
                                          Owned mutexes:
                                          Last reset 02:36:41 ago, cause: power up
                                          Last software reset details not available
                                          Error status: 0x00
                                          Aux0 errors 0,0,0
                                          Aux1 errors 0,0,0
                                          MCU temperature: min 31.7, current 32.3, max 32.9
                                          12V rail voltage: min 3.8, current 3.9, max 7.1, under voltage events: 0
                                          Date/time: 2021-02-04 21:57:18
                                          Slowest loop: 1.41ms; fastest: 0.05ms
                                          === Storage ===
                                          === MainDDARing ===
                                          === AuxDDARing ===
                                          Segments left: 0
                                          === Network ===
                                          Slowest loop: 0.97ms; fastest: 0.02ms
                                          - Ethernet -
                                          State: active
                                          Error counts: 0 0 0 0 0
                                          === CAN ===
                                          Messages queued 0, send timeouts 46881, received 0, lost 0, longest wait 0ms
                                            So if the reset was unexplained, it was caused by a loss of power.
