    Help me! I made a duet3 6ch, and the power failed
    28
    1.3k
    • wanwanundefined
      wanwan @o_lampe
      @o_lampe I checked. No problem. And they're parallel connection
        Are you using our standard RRF 3.2 firmware binary, or have you built your own?
        wanwanundefined 1 Reply Last reply Reply Quote 0
        • wanwanundefined
          wanwan @dc42
          @dc42 Use the official standard firmware. Now the problem has been solved. thank you
          • o_lampeundefined
            o_lampe @wanwan
            @wanwan
            If you have a few more empty PCBs, you could populate them step-by-step, beginning with the DC-DC power converter and test every function one at a time.
            Or do a shortcut test on an empty PCB, maybe some inner layers aren't OK?
            It seems, there is a lot of solder on the pads, maybe there's a heatsink/GND pad under the MPU or the MOSFETs which got too much solderpaste and caused a shortcut?
            • wanwanundefined
              wanwan @o_lampe
              @o_lampe I want to have a cheap DUET3. I decided to do it myself. Now it doesn't seem like a good idea
                dc42 administrators @wanwan
                @wanwan said in Help me! I made a duet3 6ch, and the power failed:
                How did you solve it?
                I asked about the firmware because the stack trace didn't seem to match up exactly with the map file for the standard firmware binary.
                wanwanundefined 2 Replies Last reply Reply Quote 0
                • wanwanundefined
                  wanwan @dc42
                  @dc42 I made a mistake 。Down to 3.0, the problem still exists.
                  • wanwanundefined
                    wanwan @dc42
                    @dc42 This problem is an error that occurred after the driver was burned
                      Can you explain more? I would not expect the firmware to crash even if a driver failed, unless the failed driver fed injection current into the MCU sufficient to cause it to behave incorrectly. What type of driver did you connect that failed?
                      • wanwanundefined
                        wanwan @dc42
                        @dc42 Do you mean that the current breaks down the MUC when the drive is burned?
                          It's possible that a burned driver may feed current into the MCU pin driving Step, Dir, or one of the SPI signals. The input protection diodes shunt this current to Vcc (3.3V). If the current is small enough, operation of the chip will be unaffected. With somewhat higher current, the chip may malfunction, but no permanent damage will be done. Higher still and permanent damage will be done.
                          What I would ideally like to know is whether the firmware crashed because it didn't get the expected response from the driver (which I would regard as a firmware bug to be fixed), or the MCU crashed because of injection current.
                          • Vetiundefined
                            Veti @wanwan
                            did the parts work out to be more in the end?
                            • wanwanundefined
                              wanwan @dc42
                              @dc42 After hearing your explanation, I think it's ,the MCU crashed because of injection current
                              • wanwanundefined
                                wanwan
                                This is just generated
                                2021/2/4下午9:57:21	M122
                                RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                                Board ID: 08DGM-9561L-D63T4-6J1FA-3S46J-KA0RG
                                Used output buffers: 1 of 40 (25 max)
                                Static ram: 149788
                                Dynamic ram: 92280 of which 404 recycled
                                Never used RAM 116360, free system stack 187 words
                                Tasks: NETWORK(ready,223) ETHERNET(blocked,109) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
                                Owned mutexes:
                                Last reset 02:36:41 ago, cause: power up
                                Last software reset details not available
                                Error status: 0x00
                                Aux0 errors 0,0,0
                                Aux1 errors 0,0,0
                                MCU temperature: min 31.7, current 32.3, max 32.9
                                Supply voltage: min 3.9, current 3.9, max 4.0, under voltage events: 0, over voltage events: 0, power good: no
                                12V rail voltage: min 3.8, current 3.9, max 7.1, under voltage events: 0
                                Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                                Date/time: 2021-02-04 21:57:18
                                Slowest loop: 1.41ms; fastest: 0.05ms
                                === Storage ===
                                Free file entries: 10
                                SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                                DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                === MainDDARing ===
                                === AuxDDARing ===
                                Segments left: 0
                                Movement lock held by null
                                HTTP is idle in state(s) 0
                                Telnet is idle in state(s) 0
                                File is idle in state(s) 0
                                USB is idle in state(s) 0
                                Aux is idle in state(s) 0
                                Trigger is idle in state(s) 0
                                Queue is idle in state(s) 0
                                LCD is idle in state(s) 0
                                SBC is idle in state(s) 0
                                Daemon is idle in state(s) 0
                                Aux2 is idle in state(s) 0
                                Code queue is empty.
                                === Network ===
                                Slowest loop: 0.97ms; fastest: 0.02ms
                                HTTP sessions: 1 of 8
                                - Ethernet -
                                State: active
                                Error counts: 0 0 0 0 0
                                === CAN ===
                                Messages queued 0, send timeouts 46881, received 0, lost 0, longest wait 0ms
                                  So if the reset was unexplained, it was caused by a loss of power.
                                  • wanwanundefined
                                    wanwan @dc42
                                    @dc42 I'm relieved that the worst didn't happen.Thank you
                                    • jrocklandundefined
                                      jrockland
                                      soo... you did your own board, and put Duet3D logo on it ? am I missing something here ?
                                      Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                      • Nuramoriundefined
                                        Nuramori @jrockland
                                        @jrockland said in Help me! I made a duet3 6ch, and the power failed:
                                        He’s done the same with a duet WiFi variant. He’s shared images and videos on our Facebook support group for the blv cube and has stated he’s selling them, but supposedly doesn’t/can’t sell them outside of China (the veracity of that is up to the reader to decide).
                                        jrocklandundefined 1 Reply Last reply Reply Quote 1
                                          jrockland @Nuramori
                                          @Nuramori ill keep an eye open for those boards in north america and let duet know.
                                            jrockland @wanwan
                                            @wanwan so to be clear you made cheap chinese copy using both the logo and name of duet AND you want their help to fix your problems ? Am I in a comedy show right now ?
                                            deckingmanundefined 1 Reply Last reply Reply Quote 1
