    Help me! I made a duet3 6ch, and the power failed
    28
    1.3k
    • o_lampeundefined
      o_lampe @wanwan
      @wanwan
      If you have a few more empty PCBs, you could populate them step-by-step, beginning with the DC-DC power converter and test every function one at a time.
      Or do a shortcut test on an empty PCB, maybe some inner layers aren't OK?
      It seems, there is a lot of solder on the pads, maybe there's a heatsink/GND pad under the MPU or the MOSFETs which got too much solderpaste and caused a shortcut?
      wanwanundefined 1 Reply Last reply Reply Quote 0
      • wanwanundefined
        wanwan @o_lampe
        @o_lampe I want to have a cheap DUET3. I decided to do it myself. Now it doesn't seem like a good idea
          dc42 administrators @wanwan
          @wanwan said in Help me! I made a duet3 6ch, and the power failed:
          @dc42 Use the official standard firmware. Now the problem has been solved. thank you
          How did you solve it?
          I asked about the firmware because the stack trace didn't seem to match up exactly with the map file for the standard firmware binary.
          wanwanundefined 2 Replies Last reply Reply Quote 0
          • wanwanundefined
            wanwan @dc42
            @dc42 I made a mistake 。Down to 3.0, the problem still exists.
            • wanwanundefined
              wanwan @dc42
              @dc42 This problem is an error that occurred after the driver was burned
                Can you explain more? I would not expect the firmware to crash even if a driver failed, unless the failed driver fed injection current into the MCU sufficient to cause it to behave incorrectly. What type of driver did you connect that failed?
                • wanwanundefined
                  wanwan @dc42
                  @dc42 Do you mean that the current breaks down the MUC when the drive is burned?
                    It's possible that a burned driver may feed current into the MCU pin driving Step, Dir, or one of the SPI signals. The input protection diodes shunt this current to Vcc (3.3V). If the current is small enough, operation of the chip will be unaffected. With somewhat higher current, the chip may malfunction, but no permanent damage will be done. Higher still and permanent damage will be done.
                    What I would ideally like to know is whether the firmware crashed because it didn't get the expected response from the driver (which I would regard as a firmware bug to be fixed), or the MCU crashed because of injection current.
                    • Vetiundefined
                      Veti @wanwan
                      did the parts work out to be more in the end?
                      • wanwanundefined
                        wanwan @dc42
                        @dc42 After hearing your explanation, I think it's ,the MCU crashed because of injection current
                        • wanwanundefined
                          wanwan
                          This is just generated
                          2021/2/4下午9:57:21	M122
                          RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
                          Board ID: 08DGM-9561L-D63T4-6J1FA-3S46J-KA0RG
                          Used output buffers: 1 of 40 (25 max)
                          Static ram: 149788
                          Dynamic ram: 92280 of which 404 recycled
                          Never used RAM 116360, free system stack 187 words
                          Tasks: NETWORK(ready,223) ETHERNET(blocked,109) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
                          Owned mutexes:
                          Last reset 02:36:41 ago, cause: power up
                          Last software reset details not available
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          MCU temperature: min 31.7, current 32.3, max 32.9
                          Supply voltage: min 3.9, current 3.9, max 4.0, under voltage events: 0, over voltage events: 0, power good: no
                          12V rail voltage: min 3.8, current 3.9, max 7.1, under voltage events: 0
                          Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
                          Date/time: 2021-02-04 21:57:18
                          Slowest loop: 1.41ms; fastest: 0.05ms
                          === Storage ===
                          Free file entries: 10
                          SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                          DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Segments left: 0
                          Movement lock held by null
                          HTTP is idle in state(s) 0
                          Telnet is idle in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Trigger is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === Network ===
                          Slowest loop: 0.97ms; fastest: 0.02ms
                          HTTP sessions: 1 of 8
                          - Ethernet -
                          State: active
                          Error counts: 0 0 0 0 0
                          === CAN ===
                          Messages queued 0, send timeouts 46881, received 0, lost 0, longest wait 0ms
                            So if the reset was unexplained, it was caused by a loss of power.
                            • wanwanundefined
                              wanwan @dc42
                              @dc42 I'm relieved that the worst didn't happen.Thank you
                              • jrocklandundefined
                                jrockland
                                soo... you did your own board, and put Duet3D logo on it ? am I missing something here ?
                                Nuramoriundefined 1 Reply Last reply Reply Quote 0
                                • Nuramoriundefined
                                  Nuramori @jrockland
                                  @jrockland said in Help me! I made a duet3 6ch, and the power failed:
                                  He’s done the same with a duet WiFi variant. He’s shared images and videos on our Facebook support group for the blv cube and has stated he’s selling them, but supposedly doesn’t/can’t sell them outside of China (the veracity of that is up to the reader to decide).
                                  jrocklandundefined 1 Reply Last reply Reply Quote 1
                                    jrockland @Nuramori
                                    @Nuramori ill keep an eye open for those boards in north america and let duet know.
                                      jrockland @wanwan
                                      @wanwan so to be clear you made cheap chinese copy using both the logo and name of duet AND you want their help to fix your problems ? Am I in a comedy show right now ?
                                      deckingmanundefined 1 Reply Last reply Reply Quote 1
                                        Well it is open hardware. Though using the logo is not allowed and if being made for sale must be made clear that it is not an official product.
                                        https://github.com/Duet3D/Duet-2-Hardware/blob/master/LICENSE
                                        https://github.com/Duet3D/Duet3-Mainboard-6HC/blob/master/LICENSE
                                          deckingman @jrockland
                                          Not only does he want help from the Duet team, but he's getting it. Seems like a very strange business model to me.......
                                          • wanwanundefined
                                            wanwan @Phaedrux
                                            @Phaedrux no offense. The purpose of making this PCB is not to sell it. I think I should close the theme
