    Help me! I made a duet3 6ch, and the power failed
    28
    1.3k
    • wanwanundefined
      wanwan
      This is just generated
      2021/2/4下午9:57:21	M122
      RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
      Board ID: 08DGM-9561L-D63T4-6J1FA-3S46J-KA0RG
      Used output buffers: 1 of 40 (25 max)
      Static ram: 149788
      Dynamic ram: 92280 of which 404 recycled
      Never used RAM 116360, free system stack 187 words
      Tasks: NETWORK(ready,223) ETHERNET(blocked,109) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
      Owned mutexes:
      Last reset 02:36:41 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      Aux0 errors 0,0,0
      Aux1 errors 0,0,0
      MCU temperature: min 31.7, current 32.3, max 32.9
      Supply voltage: min 3.9, current 3.9, max 4.0, under voltage events: 0, over voltage events: 0, power good: no
      12V rail voltage: min 3.8, current 3.9, max 7.1, under voltage events: 0
      Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
      Date/time: 2021-02-04 21:57:18
      Slowest loop: 1.41ms; fastest: 0.05ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 0.7ms, write time 0.0ms, max retries 0
      DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
      === MainDDARing ===
      === AuxDDARing ===
      Segments left: 0
      Movement lock held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is idle in state(s) 0
      Aux2 is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 0.97ms; fastest: 0.02ms
      HTTP sessions: 1 of 8
      - Ethernet -
      State: active
      Error counts: 0 0 0 0 0
      === CAN ===
      Messages queued 0, send timeouts 46881, received 0, lost 0, longest wait 0ms
        dc42 administrators @wanwan
        @wanwan said in Help me! I made a duet3 6ch, and the power failed:
        So if the reset was unexplained, it was caused by a loss of power.
        wanwanundefined 1 Reply Last reply Reply Quote 0
        • wanwanundefined
          wanwan @dc42
          @dc42 I'm relieved that the worst didn't happen.Thank you
          • jrocklandundefined
            jrockland
            soo... you did your own board, and put Duet3D logo on it ? am I missing something here ?
            Nuramoriundefined 1 Reply Last reply Reply Quote 0
            • Nuramoriundefined
              Nuramori @jrockland
              @jrockland said in Help me! I made a duet3 6ch, and the power failed:
              He’s done the same with a duet WiFi variant. He’s shared images and videos on our Facebook support group for the blv cube and has stated he’s selling them, but supposedly doesn’t/can’t sell them outside of China (the veracity of that is up to the reader to decide).
              jrocklandundefined 1 Reply Last reply Reply Quote 1
                jrockland @Nuramori
                @Nuramori ill keep an eye open for those boards in north america and let duet know.
                  jrockland @wanwan
                  @wanwan so to be clear you made cheap chinese copy using both the logo and name of duet AND you want their help to fix your problems ? Am I in a comedy show right now ?
                  deckingmanundefined 1 Reply Last reply Reply Quote 1
                    Well it is open hardware. Though using the logo is not allowed and if being made for sale must be made clear that it is not an official product.
                    https://github.com/Duet3D/Duet-2-Hardware/blob/master/LICENSE
                    https://github.com/Duet3D/Duet3-Mainboard-6HC/blob/master/LICENSE
                      deckingman @jrockland
                      Not only does he want help from the Duet team, but he's getting it. Seems like a very strange business model to me.......
                      • wanwanundefined
                        wanwan @Phaedrux
                        @Phaedrux no offense. The purpose of making this PCB is not to sell it. I think I should close the theme
