    Help me! I made a duet3 6ch, and the power failed
    28
    1.3k
      dc42 administrators @wanwan
      @wanwan said in Help me! I made a duet3 6ch, and the power failed:
      Do you mean that the current breaks down the MUC when the drive is burned?
      It's possible that a burned driver may feed current into the MCU pin driving Step, Dir, or one of the SPI signals. The input protection diodes shunt this current to Vcc (3.3V). If the current is small enough, operation of the chip will be unaffected. With somewhat higher current, the chip may malfunction, but no permanent damage will be done. Higher still and permanent damage will be done.
      What I would ideally like to know is whether the firmware crashed because it didn't get the expected response from the driver (which I would regard as a firmware bug to be fixed), or the MCU crashed because of injection current.
      wanwanundefined 1 Reply Last reply Reply Quote 0
      • Vetiundefined
        Veti @wanwan
        I decided to do it myself. Now it doesn't seem like a good idea
        did the parts work out to be more in the end?
        • wanwanundefined
          wanwan @dc42
          @dc42 After hearing your explanation, I think it's ,the MCU crashed because of injection current
          • wanwanundefined
            wanwan
            This is just generated
            2021/2/4下午9:57:21	M122
            RepRapFirmware for Duet 3 MB6HC version 3.2 running on Duet 3 MB6HC v1.01 or later (standalone mode)
            Board ID: 08DGM-9561L-D63T4-6J1FA-3S46J-KA0RG
            Used output buffers: 1 of 40 (25 max)
            Static ram: 149788
            Dynamic ram: 92280 of which 404 recycled
            Never used RAM 116360, free system stack 187 words
            Tasks: NETWORK(ready,223) ETHERNET(blocked,109) HEAT(blocked,353) CanReceiv(blocked,927) CanSender(blocked,371) CanClock(blocked,349) TMC(blocked,65) MAIN(running,1148) IDLE(ready,19)
            Owned mutexes:
            Last reset 02:36:41 ago, cause: power up
            Last software reset details not available
            Error status: 0x00
            Aux0 errors 0,0,0
            Aux1 errors 0,0,0
            MCU temperature: min 31.7, current 32.3, max 32.9
            Supply voltage: min 3.9, current 3.9, max 4.0, under voltage events: 0, over voltage events: 0, power good: no
            12V rail voltage: min 3.8, current 3.9, max 7.1, under voltage events: 0
            Driver 0: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Driver 1: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Driver 2: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Driver 3: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Driver 4: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Driver 5: position 0, ok, reads 0, writes 0 timeouts 0, SG min/max not available
            Date/time: 2021-02-04 21:57:18
            Slowest loop: 1.41ms; fastest: 0.05ms
            === Storage ===
            Free file entries: 10
            SD card longest read time 0.7ms, write time 0.0ms, max retries 0
            DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
            === MainDDARing ===
            === AuxDDARing ===
            Segments left: 0
            Movement lock held by null
            HTTP is idle in state(s) 0
            Telnet is idle in state(s) 0
            File is idle in state(s) 0
            USB is idle in state(s) 0
            Aux is idle in state(s) 0
            Trigger is idle in state(s) 0
            Queue is idle in state(s) 0
            LCD is idle in state(s) 0
            SBC is idle in state(s) 0
            Daemon is idle in state(s) 0
            Aux2 is idle in state(s) 0
            Code queue is empty.
            === Network ===
            Slowest loop: 0.97ms; fastest: 0.02ms
            HTTP sessions: 1 of 8
            - Ethernet -
            State: active
            Error counts: 0 0 0 0 0
            === CAN ===
            Messages queued 0, send timeouts 46881, received 0, lost 0, longest wait 0ms
              So if the reset was unexplained, it was caused by a loss of power.
              • wanwanundefined
                wanwan @dc42
                @dc42 I'm relieved that the worst didn't happen.Thank you
                • jrocklandundefined
                  jrockland
                  soo... you did your own board, and put Duet3D logo on it ? am I missing something here ?
                  Nuramoriundefined 1 Reply Last reply Reply Quote 0
                  • Nuramoriundefined
                    Nuramori @jrockland
                    @jrockland said in Help me! I made a duet3 6ch, and the power failed:
                    He’s done the same with a duet WiFi variant. He’s shared images and videos on our Facebook support group for the blv cube and has stated he’s selling them, but supposedly doesn’t/can’t sell them outside of China (the veracity of that is up to the reader to decide).
                    jrocklandundefined 1 Reply Last reply Reply Quote 1
                      jrockland @Nuramori
                      @Nuramori ill keep an eye open for those boards in north america and let duet know.
                        jrockland @wanwan
                        @wanwan so to be clear you made cheap chinese copy using both the logo and name of duet AND you want their help to fix your problems ? Am I in a comedy show right now ?
                        deckingmanundefined 1 Reply Last reply Reply Quote 1
                          Well it is open hardware. Though using the logo is not allowed and if being made for sale must be made clear that it is not an official product.
                          https://github.com/Duet3D/Duet-2-Hardware/blob/master/LICENSE
                          https://github.com/Duet3D/Duet3-Mainboard-6HC/blob/master/LICENSE
                            deckingman @jrockland
                            Not only does he want help from the Duet team, but he's getting it. Seems like a very strange business model to me.......
                            • wanwanundefined
                              wanwan @Phaedrux
                              @Phaedrux no offense. The purpose of making this PCB is not to sell it. I think I should close the theme
