    DC42 IR probe and mesh bed map problems
    Firmware installation
    8
    16
    2.5k
    • okerchoundefined
      okercho
      I'm looking forward for your precision-piezo to be back in stock, @DjDemonD, when do you expect to have it back?
      Cheers
      Okercho
      Custom Prusa i3 Hephestos with Duet Wi-Fi
      E3d V6 with Bondtech BMG DirectDrive and PrecisionPiezo Sensor
      Rebuilding Hypercube Evolution
      • Corexyundefined
        Corexy
        I'm using a similar size Printbite on a 1/4" cast ally plate, and my probe seems pretty happy and giving quite constant results.
        Only 5 contact points though, just clockwise from the front left and ending in the center.
        Do we have contact probes that work with the Duet Wifi now?
        • DjDemonDundefined
          DjDemonD
          Yes the Piezo20 probe module works with any firmware.
          www.precisionpiezo.co.uk
            The current production PrintBite seems to be transparent to IR, which is not ideal for the sensor. I think it is picking up the grid lines. You will probably get better results if you choose the grid origin and spacing so that every probe point is in the centre of a grid square.
            • GeckoBox3Dundefined
              GeckoBox3D
              I never solved this issue unfortunately… placing paper lessened the problem but it still persisted. Also, the grid lines do not explain the diagonal lines as otherwise you would expect the waves to travel along X or Y (Or both).
              Quite disappointing really and may have to give the BLtouch or the new piezo sensors a go.
                The grid lines could indeed explain the diagonal lines, it all depends on the relationship between the grid spacing on the build plate and the grid spacing you choose in your M557 command.
                  GeckoBox3D
                  @dc42:
                  The grid lines are set to 20mm apart, if the IR probe was hitting them, surely this would happen in a repeatable pattern either across X (vertical waves), across Y (horizontal waves), or both (grid like waves). Depending on how big the probing grid is, this may not happen every time but you will still see a repeating wave. How would you see diagonal waves? This diagonal wave also appeared with blue tape covering the surface, although to a slightly lesser extent. Something else must be causing this noise. It also picked up where the blue tape overlapped, so at least I know the accuracy is there.
                    GeckoBox3D
                    Any thoughts on how to get this probe working? could live with it not working on printbite, but it doesn't make sense to me that it is showing noise on uniform surfaces such as paper and blue tape.
                    • Whitewolfundefined
                      Whitewolf
                      Try using a black piece of construction paper first. I know these sensors give amazing results on it if they are functioning properly. I was able to dial in to -.008 to .023 deviations with black paper under glass but on top should work just as well.
                      Otherwise you could try another sensor.
                      • SM3Dundefined
                        SM3D
                        Hi Geckobox,
                        I had a similar problem while doing the calibration. I mentioned in this forum too. Like Whitewolf, I used a matte black craft paper under plain glass bed. I cleaned the glass with standard window cleaner to make sure there is no dirt. Now I get a repeatable calibration with deviation under 10 microns and good mesh bed compensation.
                        Previously I used PEI surface but I had some scratches due to which I had weird calibration and bed compensation results. Once I used the black paper these problems disappeared. I would suggest you try this.
                        Regards,
                        Vasan
                        Good judgement comes from experience but experience comes from bad judgements
                          GeckoBox3D
                          @SM3D:
                          Hi Geckobox,
                          Regards,
                          Vasan
                          Unfortunately black craft paper wont work for me as I use print bite directly on aluminium tooling plate with no glass. I will get hold of some just to test the probe, but it seems the IR probe is not for me. Disappointing really given that many of DC42's posts in the past have pointed to it working with printbite. Not his fault, but the wiki/blogposts really need editing to reflect this change.
                          • TwoToneundefined
                            TwoTone
                            Reflect what change? The IR probe worked for me when I had Printbite.
                              I think the formulation of PrintBite has changed. The small sample that I originally tested was opaque to IR. A more recent sample I have been given appears to be transparent to IR, which would account for the difference in results.
                              I will update the fitting instructions.
                              • okerchoundefined
                                okercho
                                @CaLviNx:
                                @okercho:
                                Cheers
                                https://vgy.me/9P928h.jpg
                                im cheesily grinning at getting a hold of one, they never seem to stay in stock long !!! 🙂
                                I received mine last Thursday 😛
                                Cheers!
                                Okercho
