    M307 in startup gcode gives heater over-powered warnings
    1.7k
    • DanS79undefined
      DanS79 @Phaedrux
      @Phaedrux said in M307 in startup gcode gives heater over-powered warnings:
      Does the seatbelt light in your car annoy you too?
      Yes, and while i can't disable the light I did disable the annoying chime....
        A Former User
        did you even try M143 or are you confident enough to complain without trying it?
        DanS79undefined 2 Replies Last reply Reply Quote 0
        • Vetiundefined
          Veti
          he just wants to complain
          DanS79undefined 1 Reply Last reply Reply Quote 0
          • DanS79undefined
            DanS79 @A Former User
            This post is deleted!
            • DanS79undefined
              @bearer said in M307 in startup gcode gives heater over-powered warnings:
              I did the math and that would require raising the HE limit to 582°C. That's well above even the theoretical maximum recommended by the manufacture, so i disregarded that as an option.
              dc42undefined A Former User? 2 Replies Last reply Reply Quote 0
              • DanS79undefined
                DanS79 @Veti
                @Veti said in M307 in startup gcode gives heater over-powered warnings:
                You can shove off!
                  dc42 administrators @DanS79
                  @DanS79 said in M307 in startup gcode gives heater over-powered warnings:
                  In that case, the estimated hot end temperature reached if you were unlucky enough to get a stuck heater would be even more above the manufacturer's recommended limit, probably enough to melt the heater block if it is aluminium.
                    A Former User @DanS79
                    lol, its not gonna change the teperature to set the m413 before and after m307 ... you'll still have an overpowered heater if you do or you don't.
                    think of it like printing a dummy seatbelt clip to get rid of the pesky sounds in the car...
                    • DanS79undefined
                      DanS79 @dc42
                      @dc42 said in [M307 in startup gcode gives heater over-powered warnings]
                      It's an E3D copper block, so its recommended max is 500°C.
                        deckingman @Phaedrux
                        Everytime they get loaded is almost like annoyware imo.
                        A better analogy would be a smoke alarm going off when the OP burns the toast. Methinks the OP has removed the batteries from said alarm (if he has any).
                        • DanS79undefined
                          DanS79 @deckingman
                          @deckingman Are you still crying because new features are being added?
                          1 Reply Last reply Reply Quote -1
                            A Former User
                            sad state of this forum these days - ciao.
                            • DanS79undefined
                              @bearer said in [M307 in startup gcode gives heater over-powered warnings]
                              You know most cars have a series of steps (put in the cars software by the manufacture) you can follow to disable the alarm right?
                              • DanS79undefined
                                well, if some people didn't make posts just to be a smart***, maybe they wouldn't get an equivalent response.
                                  A Former User
