M307 in startup gcode gives heater over-powered warnings
@Veti said in M307 in startup gcode gives heater over-powered warnings:
he just wants to complain
You can shove off!
@DanS79 said in M307 in startup gcode gives heater over-powered warnings:
I did the math and that would require raising the HE limit to 582°C. That's well above even the theoretical maximum recommended by the manufacture, so i disregarded that as an option.
In that case, the estimated hot end temperature reached if you were unlucky enough to get a stuck heater would be even more above the manufacturer's recommended limit, probably enough to melt the heater block if it is aluminium.
@bearer said in M307 in startup gcode gives heater over-powered warnings:
did you even try M143 or are you confident enough to complain without trying it?
lol, its not gonna change the teperature to set the m413 before and after m307 ... you'll still have an overpowered heater if you do or you don't.
think of it like printing a dummy seatbelt clip to get rid of the pesky sounds in the car...
@dc42 said in [M307 in startup gcode gives heater over-powered warnings]
It's an E3D copper block, so its recommended max is 500°C.
@Phaedrux said in M307 in startup gcode gives heater over-powered warnings:
Everytime they get loaded is almost like annoyware imo.
Does the seatbelt light in your car annoy you too?
A better analogy would be a smoke alarm going off when the OP burns the toast. Methinks the OP has removed the batteries from said alarm (if he has any).
@deckingman Are you still crying because new features are being added?
sad state of this forum these days - ciao.
@bearer said in [M307 in startup gcode gives heater over-powered warnings]
You know most cars have a series of steps (put in the cars software by the manufacture) you can follow to disable the alarm right?
well, if some people didn't make posts just to be a smart***, maybe they wouldn't get an equivalent response.
This post is deleted!
