    printer movement on startup
    575
    • Orang_undefined
      Orang_
      How do I disable printer z+ movement when I turn on the printer?
      PCRundefined 1 Reply Last reply Reply Quote 0
      • PCRundefined
        PCR @Orang_
        @Orang_ Please post the config.g and config-override.g
        Normally there is no movement
        • Orang_undefined
          Orang_
          G90                                            ; send absolute coordinates...
          M83                                            ; ...but relative extruder moves
          M669 K10 U170 L319 R55.94 A-45:52 B135 H439.2 X-60,Y60,Z180
          M666 X0 Y0 Z0
          M579 X1.0171 Y1.0309
          M552 S1                                        ; enable network
          M586 P0 S1                                     ; enable HTTP
          M586 P1 S0                                     ; disable FTP
          M586 P2 S0                                     ; disable Telnet
          M569 P0 S1                                     ; physical drive 0 goes forwards using default driver timings |D3 stealthChop2
          M569 P1 S1                                     ; physical drive 1 goes forwards using default driver timings
          M569 P2 S1                                     ; physical drive 2 goes forwards using default driver timings
          M569 P3 S0                                     ; physical drive 3 goes forwards using default driver timings
          M584 X0 Y1 Z2 E3                               ; set drive mapping
          M350 X64 Y64 Z64 E64                           ; configure microstepping with interpolation
          M92 X1761. Y1761. Z1761. E1488.59           ; set steps per mm 1761.5 1488.59
          M566 X1200.00 Y1200.00 Z1200.00 E1200.00       ; set maximum instantaneous speed changes (mm/min)
          M203 X18000.00 Y18000.00 Z18000.00 E1200.00    ; set maximum speeds (mm/min)
          M201 X500.00 Y500.00 Z500.00 E1000.00       ; set accelerations (mm/s^2)
          M906 X500 Y500 Z500 E600                       ; set motor currents (mA) and motor idle factor in per cent
          M84 S30                                        ; Set idle timeout
          M208 Z-40:300                                 ; set minimum Z
          M574 X2 S1 P"!xstopmax"                            ; configure active-high endstop for low end on X via pin xstop
          M574 Y2 S1 P"!ystopmax"                            ; configure active-high endstop for low end on Y via pin ystop
          M574 Z2 S1 P"!zstopmax"                            ; configure active-high endstop for low end on Z via pin zstop
          M558 P5 C"^zstop" H10  F1200 T1000 A3			;
          M557 R130 S20                                   ; define mesh grid
          G31 X0 Y0 Z3.67 P500 h10
          M308 S0 P"bedtemp" Y"thermistor" T100000 B4600 ; configure sensor 0 as thermistor on pin bedtemp
          M950 H0 C"bed" T0                              ; create bed heater output on bed and map it to sensor 0
                  ; disable bang-bang mode for the bed heater and set PWM limit
          M307 H0 R0.826 C133.9 D1.46 S1.00 V0.0
          M140 H0                                        ; map heated bed to heater 0
          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
          M308 S1 P"e0temp" Y"thermistor" T100000 B4072  ; configure sensor 1 as thermistor on pin e0temp
          M950 H1 C"e0heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
          M307 H1 R2.707 C226.1 D3.97 S1.00 V0.0         ; disable bang-bang mode for heater  and set PWM limit
          M143 H1 S260                                   ; set temperature limit for heater 1 to 280C
          M570 H1 P5 T15
          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
          M563 P0 D0 H1 F0                               ; define tool 0
          G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
          M563 P2 S"2rr" D0 H1 F0                     ; define tool 2
          G10 P2 X0 Y0 Z-23.3                                ; set tool 2 axis offsets
          G10 P2 R0 S0
          M563 P5 S"TEST" D0 H1 F0                     ; define tool 2
          G10 P2 X0 Y0 Z-29.3                                ; set tool 2 axis offsets
          G10 P2 R0 S0
          T2
          M575 P1 B57600 S0
          Stephen6309undefined 1 Reply Last reply Reply Quote 0
            jay_s_uk
            whats in your tool change files for T2?
            Orang_undefined 1 Reply Last reply Reply Quote 0
            • Orang_undefined
              Orang_ @jay_s_uk
              @jay_s_uk said in printer movement on startup:
              • Orang_undefined
                Orang_
                tfree2, tpost2, tpre2 - I removed them because they were not needed
                • Stephen6309undefined
                  Stephen6309 @Orang_
                  @Orang_ Change the T2 to T0 in config.g? From those differing tool Z heights, you do have a tool changer?
                  • Orang_undefined
                    Orang_ @Stephen6309
                    @Stephen6309 said in printer movement on startup:
                    at t0 the same thing,
                    • Orang_undefined
                      Orang_ @Orang_
                      @Orang_ I figured it out, it is the effect of the tool offset in Z. But how to make the printer not react when loading
                      • taconiteundefined
                        taconite
                        good question I have the same effect and always wondered what it is
                        Custom ANET A8
                        Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
                        All I do here is under this license: CC BY-NC-SA
                        • Orang_undefined
                          Orang_ @taconite
                          @taconite Well, apparently, after loading the initial settings, the tool is loaded with an offset
                            Stephen6309 @Orang_
                            @Orang_ You have different heights above the bed for you nozzle. T0 will reach the bed, but T1 and T2, won't.
                            • Orang_undefined
                              Orang_ @Stephen6309
                              @Stephen6309 Thank you. I know. I set the correct offset value at t0. tool t1,t2 are experimental, but still if the tool offset is set, the printer raises the Z-axis when it is turned on
