    Error: bad Command XXX W/RRF 3.2 and leveling issue
    147
    10.3k
    • 3DPrintingWorldundefined
      3DPrintingWorld
      hey @martin7404 , just spoke to Gui and he experimented with his Z axis acceleration and turned it up to 1000 but noticed he started to see inconsistency's with the level. He lowered it back down to 600 and the issue went away. He's thinking that he was getting missteps from the reduction and having such low voltage on the steppers,(300) so not to damage anything should the probe fail.
      I noticed that my accel was only 35 mms^2 so not a issue for me... I think I slowed it down at one point to test something but forgot to put it back. I thought I would let you know If you turned the acceleration way up, it might be the cause for inconsistent leveling.
      martin7404undefined 1 Reply Last reply Reply Quote 0
      • martin7404undefined
        martin7404 @3DPrintingWorld
        @3DPrintingWorld I checked , my Z stepper voltage is 900 left from 5:1 reduction steppers. And my acceleration Z is 35 , I did not change that from initial setup
        Muldex IDEX Duet2+Duex5
        Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
        Sapphire Pro with Duet2, with closed-loop motors
        custom high temp E3D tool changer with Duet2+Duex
        3DPrintingWorldundefined 1 Reply Last reply Reply Quote 0
          martin7404
          One more thing for G29
          SO I made the following made bed probing with G29 and left the machine with motors energized idle for the night. In the morning I made G29 s2 and G32 with S3 and S-1, then again, then G29 S1 to activate mesh correction and G32 Again. What I see during the night for some reason the left side have 0.1mm + deviation, and with or without G29 mesh correction activated or not, there is almost no difference in G32 results
          2/16/2021, 9:53:33 AM	G32 bed probe heights: -0.007 -0.007 0.008, mean -0.002, deviation from mean 0.007
          2/16/2021, 9:53:09 AM	g32
          Leadscrew adjustments made: 0.008 -0.010 -0.029, points used 3, (mean, deviation) before (-0.009, 0.011) after (-0.000, 0.000)
          2/16/2021, 9:50:59 AM	g29 s1
          2/16/2021, 9:50:37 AM	G32 bed probe heights: -0.002 -0.015 0.005, mean -0.004, deviation from mean 0.008
          2/16/2021, 9:50:13 AM	g32
          Leadscrew adjustments made: -0.011 -0.003 0.016, points used 3, (mean, deviation) before (-0.000, 0.008) after (0.000, 0.000)
          2/16/2021, 9:49:40 AM	g29 s2
          2/16/2021, 9:49:10 AM	G32 bed probe heights: -0.009 0.014 0.001, mean 0.002, deviation from mean 0.009
          2/16/2021, 9:48:47 AM	g32
          Leadscrew adjustments made: 0.129 0.001 -0.028, points used 3, (mean, deviation) before (0.043, 0.052) after (-0.000, 0.000)
          2/16/2021, 9:47:36 AM	G32 bed probe heights: 0.080 0.005 0.003, mean 0.029, deviation from mean 0.036
          2/16/2021, 9:47:12 AM	g32
          Leadscrew adjustments made: -0.194 -0.050 -0.020, points used 3, (mean, deviation) before (-0.098, 0.058) after (0.000, 0.000)
          2/15/2021, 6:12:01 PM	224 points probed, min error -0.109, max error 0.084, mean 0.005, deviation 0.035
          Height map saved to file 0:/sys/heightmap.csv
            @3DPrintingWorld I am interested if the test with the steel bar get any effect
              3DPrintingWorld @martin7404
              @martin7404 I guess you would need more power with a little less reduction, I just tried to keep it low as possible incase of a crash. I would turn up the acceleration, that was a typo. Its saves a couple seconds homing.
                @martin7404 so you are saying, if mesh bed is on or off it doesn't make a difference?
                  martin7404
                  I just went to PRF 3.2 again and it is the same
                  2/16/2021, 1:27:27 PM	G32 bed probe heights: 0.004 -0.006 -0.020, mean -0.007, deviation from mean 0.010
                  2/16/2021, 1:27:02 PM	g32
                  Leadscrew adjustments made: 0.067 0.023 -0.004, points used 3, (mean, deviation) before (0.032, 0.022) after (-0.000, 0.000)
                  2/16/2021, 1:25:25 PM	G32 bed probe heights: 0.040 0.024 0.011, mean 0.025, deviation from mean 0.012
                  2/16/2021, 1:25:01 PM	g32
                  Leadscrew adjustments made: -0.160 -0.085 -0.057, points used 3, (mean, deviation) before (-0.106, 0.032) after (-0.000, 0.000)
                  2/16/2021, 1:15:15 PM	G29
                  30 points probed, min error -0.122, max error 0.006, mean -0.044, deviation 0.036
                    @martin7404 The weight did not have any effect on leveling, It was still out of level. The Z height was .25mm lower but I think that's because the arm that holds the BL touch was flexing from the weight I put on it.
                      @3DPrintingWorld Yes NO difference if G29 is on or off
                        @martin7404 Is your bed actual level or is it just saying that it is?
                          martin7404
                          Using steel 10.5 gauge and panel due to steps I am within what G29 probing says les than 0.15
                          3DPrintingWorldundefined 2 Replies Last reply Reply Quote 0
                            @martin7404 Ok, not perfect but acceptable. Seems like your configuration is working properly. This about of error could be caused by the head tilting. A second bearing could help with that but would also increase the weight.
                            If you used the same base config as me, I don't understand my issues. I'm thinking about ordering a new board just to see because I don't see how it can be on my end.
                              @martin7404 Instead of two bearings, what about a option to upgrade to the wide series, mgw9h. This should reduce the tilt, and would result in less binding then two bearings mounted on different planes would.
                                martin7404
                                @3DPrintingWorld said in Error: bad Command XXX W/RRF 3.2 and leveling issue:
                                mgw9h
                                Yes , but you have to switch to 4020 profile for the X and the mass would not be less
                                I took a look at hiwin pdf's . So LDO rails must light clearance type ZF (4 to 10 microns clearence between block adn rail) so 0.06-0.07 mm on 25 mm cantilever seems normal too. Maybe we can switch to light to slight preload blocks
                                  @martin7404 Why would we have to switch to a 4020? I have not placed it in the model yet but I think it would fit on the 2020 just fine. As you say a preload would be an improvement too, especially considering there is only a single bearing. It would probably will have to get a genuine Hiwini though for a preload option.
                                    martin7404
                                    Sorry I missed that 09MGW is a single row of bolts.
                                    MGW is better I agree X momentum is about 3 times bigger
                                      3DPrintingWorld @Phaedrux
                                      @Phaedrux There really is not much I can omit from the config as most of it is needed for homing. I can remove heaters, fans, and filament sensors but I don't see how that is going to help.
                                      Have you seen any documentation to recover from the firmware being deleted?
                                        @Phaedrux neverminded, I found fallback procedure 3.
                                          @3DPrintingWorld more likely due to the magnetic mat not flat within 0.15 mm. I tried pushing the X head lightly with my finger during G32, no diference
                                            martin7404
                                            So found a major problem with Muldex and PRF 3.2
                                            Started a print with T1 ( right , not main extruder) and all of suden the machine is printing in thin air , a few mm up, looked at paneldue and it shows of Z layer + my T1 offset - Z+2.85. Canceled the print.
                                            In manual when I entrer T0 or T1 in the console , both heads come to exact position , measured with 10.5 mm steel gauge .
                                            I do not understan what is hapening . With PRF 3.0 it was printing like a charm
                                            Here is my config
                                            G90                                             ; send absolute coordinates...
                                            M83                                             ; ...but relative extruder moves
                                            M550 P"Muldex"                                  ; set printer name
                                            M552 S1                                        ; enable network
                                            M586 P0 S1                                      ; enable HTTP
                                            M586 P1 S0                                      ; disable FTP
                                            M586 P2 S0                                      ; disable Telnet
                                            M569 P0 S0                                      ; X physical drive 0 goes backwards
                                            M569 P1 S0                                      ; Y right physical drive 1 goes backwards
                                            M569 P2 S1                                      ; Y left physical drive 2 goes forwards
                                            M569 P3 S1                                      ; U physical drive 3 goes forwards
                                            M569 P4 S1                                     ; E1 physical drive 4 goes backwards
                                            M569 P5 S1                                      ; Z left physical drive 5 goes backwards
                                            M569 P6 S1                                     ; Z center physical drive 6 goes backwards
                                            M569 P7 S0                                      ; Z right physical drive 7 goes forwards
                                            M569 P8 S1                                      ; E2 physical drive 8 goes forwards
                                            M584 X0 Y1:2 U3 Z5:6:7 E4:8                     ; set drive mapping
                                            M350 X16 U16 Y16 Z16 E16:16 I1                                                           ; configure microstepping with interpolation
                                            M92 X199.7 U200 Y199.8:199.8 Z799.2:799.2:799.2 E813.07:830.00                        ; set steps per mm (1760nimble)
                                            M566 X1000.00 U1000.00 Y1000.00:1000.00 Z80.00:80.00:80.00 E100.00:100.00                ; set maximum instantaneous speed changes (mm/min)(Nimble 40)
                                            M203 X12000.00 U12000.00 Y12000.00:12000.00 Z1000.00:1000.00:1000.00 E4200.00:4200.00    ; set maximum speeds (mm/min)
                                            M201 X1310.00 U1310.00 Y1310.00:1310.00 Z35.00:35.00:35.00 E800.00:800.00                    ; set accelerations (mm/s^2)(500)(Nimble 120)
                                            M906 X900 U900 Y900:900 Z900:900:900 E1000:1000 I30                                        ; set motor currents (mA) and motor idle factor in per cent(Nimble 500)
                                            M84 S120        ; Set idle timeout
                                            M208 X-18 Y0 U40 Z0 S1                          ; set axis min - adjust X to align nozzle
                                            M208 X350 U422.7 Y333 Z300 S0                   ; set axis max
                                            M669 K0 Y1:-1:0:1				                ; select Markforged Kinematics Y to react with X and U
                                            M574 X1 S1 P"xstop"                             ;X axis active high endstop switch
                                            M574 Y2 S1 P"ystop+e1stop"                      ;Y Double max active high endstop switch
                                            ;M574 Y1 S4 ; configure sensorless endstop for low end on Y
                                            M574 U2 S1 P"e0stop"                            ;U axis active high endstop switch
                                            ;M574 Z2 S4
                                            ;Stall Detection(no used)
                                            ;M574 Y1 S4                                     ; Y axis stall detection
                                            ;M915 P1:9 S3 F1 R0                             ; Y axis stall detection
                                            M671 X-20.6:200:420.6 Y14.3:333.3:14.3 S10       ; Locations left, center, right
                                            M950 S0 C"duex.e6heat"                          ; create servo pin 0 for BLTouch
                                            M558 P9 C"zprobe.in+zprobe.mod" H8 F600 A1 T12000   ; set Z probe type to bltouch and the dive height + speeds
                                            G31 P25 X-29 Y0 Z1.42                           ; set Z probe trigger value, offset and trigger height(lower number farther away)1.8build 1.7glass
                                            M557 X10:320 Y20:290 S60                       ; probe from X=10 to 390, Y=10 to 290mm with a mesh spacing of 20mm
                                            M308 S0 P"bedtemp" Y"thermistor" T100000 B4534 C9.565227e-8      ; configure sensor 0 as thermistor on pin bedtemp
                                            M950 H0 C"bedheat" T0                                            ; create bed heater output on bedheat and map it to sensor 0
                                            M143 H0 S120                                                     ; set temperature limit for heater 0 to 120C
                                            M307 H0 B0 S1.00                                                 ; disable bang-bang mode for the bed heater and set PWM limit
                                            M140 H0                                                          ; map heated bed to heater 0
                                            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C0 R4700  ; configure sensor 1 as thermistor on pin e0temp
                                            M950 H1 C"e0heat" T1                                             ; create nozzle heater output on e0heat and map it to sensor 1
                                            M143 H1 S280                                                     ; set temperature limit for heater 1 to 280C
                                            M307 H1 B0 S1.00                                                 ; disable bang-bang mode for heater  and set PWM limit
                                            M308 S2 P"e1temp" Y"thermistor" T100000 B4725 C0 R4700 ; configure sensor 2 as thermistor on pin e1temp
                                            M950 H2 C"e1heat" T2                                             ; create nozzle heater output on e1heat and map it to sensor 2
                                            M143 H2 S280                                                     ; set temperature limit for heater 2 to 280C
                                            M307 H2 B0 S1.00                                                 ; disable bang-bang mode for heater  and set PWM limit
                                            M950 F0 C"fan0" Q500                             ; create fan 0 on pin fan0 and set its frequency
                                            M106 P0 S0 H-1                               ; set fan 0 value. Thermostatic control is turned off
                                            M950 F1 C"fan1" Q500                             ; create fan 1 on pin fan1 and set its frequency
                                            M106 P1 S1 H1 T45                                ; set fan 1 value. Thermostatic control is turned on
                                            M950 F2 C"fan2" Q500                             ; create fan 2 on pin fan2 and set its frequency
                                            M106 P2 S0 H-1                                   ; set fan 2 value. Thermostatic control is turned off
                                            M950 F3 C"duex.fan8" Q500                        ; create fan 3 on pin duex.fan8 and set its frequency
                                            M106 P3 S1 H2 T45                                ; set fan 3 value. Thermostatic control is turned on
                                            ; LEDs
                                            M950 F4 C"duex.fan6" ;Q500                       ; create LED 4 on pin duex.fan6 and set its frequency
                                            M106 P4 S128 H-1                                 ; set LED 4 value. Thermostatic control is turned OFF
                                            M950 F5 C"duex.fan7" ;Q500                       ; create LED 5 on pin duex.fan7 and set its frequency
                                            M106 P5 S128 H-1                                 ; set LED 5 value. Thermostatic control is turned OFF
                                            M563 P0 D0 H1 F0 S"Left"                         ; define tool 0 Left
                                            G10 P0 X0 Y0 Z0                                  ; set tool 0 axis offsets y was .45
                                            G10 P0 R0 S0                                     ; set initial tool 0 active and standby temperatures to 0C
                                            M563 P1 D1 H2 X3 F2 S"Right"                     ; define tool 1 Right
                                            G10 P1 X0 Y0 Z2.55                          ; set tool 1 axis offsets - adjust Y to alignn nozzle
                                            G10 P1 R0 S0                                     ; set initial tool 1 active and standby temperatures to 0C
                                            M563 P2 D0:1 H1:2 X0:3 F0:2 S"Copy"              ; define tool 2 Copy
                                            G10 P2 X90 Y0 U-90 S0 R0                         ; set tool 2 axis offsets (WAS 105)
                                            M567 P2 E1:1
                                            M568 P2 S1 ; turn on mixing for tool 2           ; set mix ratio 100% on both extruders
                                            ;G10 L1 P1 X0.0 Y0.0 Z2.55
                                            M501                                             ; Record
                                            M593 F66.6
                                            M575 P1 S1 B57600                                ;Panel due
                                            ;G92 Z150
                                            ;G91
                                            ;G1 Z0.1 f100
                                            ;G90
                                            There is more , while printing in the air I pushed baybysteping up to - 2.5 , as a result the Z on panel due become almost +6 mm and the nozzle was still printing in air
