    Object model help please
    924
    • appjawsundefined
      appjaws @OwenD
      @OwenD said in Object model help please:
      move.axes[0].machinePosition
      I would have expected the U move position to be updated with the X position but your suggestion of G92 U{move.axis[0].machinePosition} didn't update U which remained ar 0.
      This is what I get from the console
      Error: Bad command: move.axes[0].machinePosition
      appjaws - Core XYUV Duet Ethernet Duex5
      firmware 3.5.0-rc.4 Web Interface 3.5.0-rc.4
      Ormerod 1-converted to laser engraver, Duet wifi
      OpenSCAD version 2024.03.18
      Simplify3D 5.1.2
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @appjaws
        @appjaws
        Apologies
        Should be
        echo move.axes[0].machinePositiion
        It should return where X is at the time. If that's 0 then I'd expect G92 U... to set it thus
        appjawsundefined 1 Reply Last reply Reply Quote 0
        • appjawsundefined
          appjaws @OwenD
          Error: meta command: unknown value 'machinePositiion'
          Simplify3D 5.1.2
          OwenDundefined jay_s_ukundefined 2 Replies Last reply Reply Quote 0
          • OwenDundefined
            OwenD @appjaws
            @appjaws
            😂 can't win. Try without the extra "i" in position
            One finger typing on a phone here.. gimme a break
              jay_s_uk @appjaws
              @appjaws theres too many i's in Position
              • appjawsundefined
                appjaws @OwenD
                @OwenD Thanks again.
                Yes that worked but then why isn't G92 U{move.axis[0].machinePosition} working?
                just realised that axes is spelt axes not with an i
                So G92 U{move.axes[0].machinePosition} works.
                Will do some testing, thanks
                Simplify3D 5.1.2
                fcwiltundefined OwenDundefined 2 Replies Last reply Reply Quote 1
                  T3P3Tony administrators
                  @appjaws if you are running at least DWC 3.2 then navigate to
                  Settings->general->plugins and turn on "Object Model Browser"
                  then you can explore the object model as it is on your board. (use refresh to update to see things change). use echo <object model key, value> as you have done with the move.axes[0].machinePosition to check you have a specific path correct. then you can use that in commands of meta commands as you need.
                  • fcwiltundefined
                    fcwilt @appjaws
                    @appjaws said in Object model help please:
                    You likely know this but I will mention it just to be sure. Axis is singular, Axes is plural.
                      deckingman @appjaws
                      @deckingman Ha Ha. I don't have a stop.g or cancel.g so I assume the machine just uses whatever is the default.
                      What have you in your stop and cancel and where are they located?
                      Thanks for the help
                      Hi Paul,
                      Looks like your getting the help you need with object model commands.
                      Ref pause.g, cancel.g etc. These macros all go in the sys folder (along with the homing macros, tool change macros etc). They might or might not be "auto generated" so they might or might not exist. They might also exist but be empty of any commands.
                      "pause.g" runs if you hit the pause button during a print in DWC (or otherwise send pause command). What you do inside that macro is entirely up to you. Similarly, cancel.g runs if you hit cancel (after already having paused the print).
                      Here is an example of my cancel.g
                      G10 ; retract
                      M98 P"0:/macros/ToolTemps/ToolTemps0.g" ; set the tool temperatures to zero
                      G91 ; set relative
                      G1 Z5 F240 ; move bed down 5mm
                      G90 ; back to absolute
                      G1 X165 U165 A165 Y300 V300 B300 F9000 ; move to rear
                      M140 S0 ; turn off bed
                      M106 S0 ; turn off part fan
                      Note the additional UV commands that I had to add (and also AB commands in my case).
                      So check those files, and if they contain any XY moves, then make sure to add UV moves to those lines. It's not much work and will save you having nasty experiences like I had when I stupidly forgot about them.
                      • OwenDundefined
                        OwenD @appjaws
                        @appjaws
                        Apologies again.
                        Yes, should be axes, not axis.
                        Not sure if that was me or autocorrect
                        As stated above, always check the exact syntax using the object model browser.
                        e.g. "machinePosition" would work, but "machineposition" would not.
                        • appjawsundefined
                          appjaws
                          Thank you for all the help, everything is now working correctly and my printer has a lot less vibration.
                          Simplify3D 5.1.2
