    Duet3D PCB delta printer effector sneak preview
    Smart effector for delta printers
    53
    367
    77.5k
      A Former User
      @W3DRK:
      Wow…I've just now noticed this topic. What a stunning design, I really love the concept!
      I was just planning on refitting my delta with wider rod spacing and a piezo Z-probe effector, but I really like this design better than any printable one. For folks with machines like my UltiBots 250 V-Slot...how would we go about mounting the carriage adapters to our existing wheeled carriages like these?
      https://github.com/UltiBots/K250VS/blob/master/Experimental/umbee_carriage_45.stl
      Also, if you haven't already is there any chance you could work with the Zesty Nimble crew so they can design a mount for this new heatsink/effector arrangement?
      Cheers!
      Just go buy linear rails and enjoy the precision 😛
      • W3DRKundefined
        W3DRK
        OpenBuilds precision V-Slot and Delrin rollers vs cheap Chinese linear rails? No thanks…
        @CaLviNx:
          The carriage adapters have the usual 4 mounting holes on a 20mm square to attach to standard linear rail sliders or Kossel wheeled carriage trucks. If the two holes on one side of that carriage are 20mm apart, then I guess you could drill another hole in the carriage adapter for the single hole on the other side of your carriage.
          Having first used wheeled carriages and then switched to linear rails, I prefer the rails too.
          We have a couple of beta users who are investigating how to mount the Nimble on top of the effector.
          • W3DRKundefined
            W3DRK
            Thanks David. Those 3 holes are for the wheels themselves.
            But it looks like switching to something like this could work if I can find a printable belt fastening mechanism:
            https://www.thingiverse.com/thing:1638410
            • SM3Dundefined
              SM3D
              Hi David,
              I have a linear rail carriage with mounting holes on a 26 mm square.
              Is it possible to have carriage adapters with no mounting holes so I can drill them using a printed jig?
              Regards,
              Vasan
              Good judgement comes from experience but experience comes from bad judgements
                I think it would be possible (just) to drill 2.9mm holes with 26m centres in the existing carriage adapters. You would have 1.5mm between the inner edges of your new holes and the outer edges of the existing ones.
                What size linear rails use 26mm mounting centres?
                • SM3Dundefined
                  SM3D
                  Thanks David for the reply! I might have to be extra careful.
                  I have ARC 15 MN carriage blocks. Here is the link:
                  https://www.dold-mechatronik.de/navi.php?a=45382⟨=eng
                  • SM3Dundefined
                    SM3D
                    I forgot to mention that the 26 mm square mounting holes are M4 in size instead of M3. So, I think only undrilled carriage adapter will work for me.
                      A Former User
                      @W3DRK:
                      @CaLviNx:
                      Who said anything about buying cheap Chinese ?
                      I got genuine hinwin rails through work
                      http://www.hiwin.co.uk/product-category/linear-guideways/hg-series/
                      • Rommieundefined
                        Rommie
                        Any more news on a release date for these. Very interested in one
                          Looking like early next month.
                          • Rommieundefined
                            Rommie
                            Sweet is there any preorder going on??
                            • MiRundefined
                              MiR
                              Please count me in, now that I am back to Haydn's rods instead of tricklaser rods I am very interested, too….
                              • Dougal1957undefined
                                Dougal1957
                                @W3DRK:
                                Cheers!
                                Has already been done as long as the Hole system on the production Hot-ends don't change but the Zesty guys will be able to mod that in about 30 sec's flat I reckon Lykle came up with the adaptor in about 30 mins.
                                see https://www.shapeways.com/product/62MB3QZJ7/nimble-mount-base-new-effector?optionId=62810434
                                  The hot end mounting hasn't changed. We managed to squeeze in 3 extra mounting holes in the production version, see https://duet3d.com/wiki/Smart_effector_and_carriage_adapters_for_delta_printer#Connectors_and_Wiring.
                                  • Whitewolfundefined
                                    Whitewolf
                                    Will this be compatible with the upcoming Pico hybrid hotend or will it only work with the special e3d mount?
                                    Would love to pair this with a pico hybrid and Zesty nimble cable extruder
                                      It has a 12mm diameter hole in the centre for mounting the hot end.
                                        Dougal1957
                                        David any idea when we will be able to order I am that impressed by the Beta that I will want to put a release one on the delta to take account of the changes that have been made?
                                        Doug
                                          We expect to have them available early next month.
                                          • fcwiltundefined
                                            fcwilt
                                            Hmm…
                                            No place for your IR z-probe device?
