    Which tool is enabled after startup?
    2.2k
    • taconiteundefined
      taconite
      @dc42 okay this is super strange
      have you had a look at the video?
      I will try it again but just have no idea why that is
      Custom ANET A8
      Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
      All I do here is under this license: CC BY-NC-SA
      • taconiteundefined
        taconite
        holy moly! I finally made it work. Thank you for all your support. In my tpreX.g macros I had an abort command which aborted the tool change when there was still a tool in the effector. I removed it and now it is working.
        The strange thing is that it was working when manually selecting a tool on PanelDue or on the DWC and I have no idea what kept it from working when running a macro with Tn
        Custom ANET A8
          T3P3Tony administrators @taconite
          @taconite what was the abort command?
          • taconiteundefined
            taconite
            I use the abort command (https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands) to abort things that should not occur (e.g. tool still there after parking) - maybe there is a better way to do that
            EDIT: @T3P3Tony
            Custom ANET A8
              @taconite so you had some "if <expression> ... abort" logic to check for certain conditions and then abort if they were true or false? Maybe the issue was the expression was evaluating to true (or false) when it should not have been.
              • taconiteundefined
                taconite
                I had it this way (tpre.g)
                if no tool in effector
                      pick tool
                else {}
                	display message "Sill tool in effector"
                	abort
                I removed the abort. Everything was correct but the execution of a macro with a Tpren.g just did not work with the abort
                Custom ANET A8
                  jay_s_uk
                  @taconite try it with break rather than abort
                  • K01571N3Nundefined
                    K01571N3N
                    Hi, this is what i have been thinking and i need this for my toolchanger.
                    Duet 3 6HC, 3HC and Raspberry pi.
                    If i write to console
                    M560 P"0:/sys/test"
                    or run macro like that
                    M560 P"/sys/test"
                    <!-- **EoF** -->
                    or whatever else, "Error: M560: Can't open file test for writing" appears...
                    If i write
                    M98 P"0:/sys/test
                    it will run that macro.
                    Is Raspberry pi somehow causing the trouble here or what?
                    K01571N3Nundefined 1 Reply Last reply Reply Quote 0
                      K01571N3N @K01571N3N
                      @dc42 @T3P3Tony Do you have any idea for my problem?
                        Phaedrux Moderator @K01571N3N
                        @K01571N3N Might be better idea to start a new thread with exactly what you're trying to do. Include firmware version details etc.
