    Which tool is enabled after startup?
    2.2k
      Yes, that part I gather. I don't understand why the macro writing isn't working for you. Can you post the exact files you are using?
      • taconiteundefined
        taconite
        toolchange_set_tool
        if state.currentTool==0
        	M560 P"/sys/tool_active"
        	T0
        	<!-- **EoF** -->
        elif state.currentTool==1
        	T1
        	<!-- **EoF** -->
        elif state.currentTool==2
        	T2
        	<!-- **EoF** -->
        	T3
        	<!-- **EoF** -->
        elif state.currentTool==4
        	T4
        	<!-- **EoF** -->
        else
        	<!-- **EoF** -->
        tfree0.g
        M98 P"toolchange_set_tool"
        tpost0.g
        e.g. tool_active (The T1 is indent because of how the macro toolchange_set_tool is built)
        	T1
        in config.g last command
        M98 P"tool_active"
        Custom ANET A8
        Custom Delta: D-PATCH (Delta Printer with Automatic Tool CHanging) https://forum.duet3d.com/topic/16082/d-patch?_=1596131234754
        All I do here is under this license: CC BY-NC-SA
        • taconiteundefined
          taconite
          @Phaedrux
          The core problem is, that when I run a macro that has e.g. only a "T0" command in there - the tool is not activate.
          So the base question is: What happens in the background if I click "Tool0" in DWC or on Panel due? Because then the Tool is set active and the tpre0.g macro runs
          Custom ANET A8
            Phaedrux Moderator @taconite
            @taconite said in Which tool is enabled after startup?:
            When using the DWC or Panel to select a tool it would be the same as sending the tool command itself and would behave as described here: https://duet3d.dozuki.com/Wiki/Gcode#Section_T_Select_Tool
            • taconiteundefined
              taconite
              @Phaedrux Makes total sense but why is there a different behavior?
              see:
              https://youtu.be/cAUnC5YKdW8
              Custom ANET A8
              • taconiteundefined
                taconite
                @Phaedrux @dc42 can you explain the different behavior?
                I am running FW 3.2
                Custom ANET A8
                  Thanks for the video, I'm not sure what is going on under the hood here. Hopefully DC42 can get a chance to look more closely soon.
                  • taconiteundefined
                    taconite
                    @dc42 any idea of the behavior?
                    Custom ANET A8
                      A macro containing just a T0 or T1 command works for me. Tested on two machines.
                      • taconiteundefined
                        taconite
                        @dc42 okay this is super strange
                        have you had a look at the video?
                        I will try it again but just have no idea why that is
                        Custom ANET A8
                        • taconiteundefined
                          taconite
                          holy moly! I finally made it work. Thank you for all your support. In my tpreX.g macros I had an abort command which aborted the tool change when there was still a tool in the effector. I removed it and now it is working.
                          The strange thing is that it was working when manually selecting a tool on PanelDue or on the DWC and I have no idea what kept it from working when running a macro with Tn
                          Custom ANET A8
                            T3P3Tony administrators @taconite
                            @taconite what was the abort command?
                            • taconiteundefined
                              taconite
                              I use the abort command (https://duet3d.dozuki.com/Wiki/GCode_Meta_Commands) to abort things that should not occur (e.g. tool still there after parking) - maybe there is a better way to do that
                              EDIT: @T3P3Tony
                              Custom ANET A8
                                @taconite so you had some "if <expression> ... abort" logic to check for certain conditions and then abort if they were true or false? Maybe the issue was the expression was evaluating to true (or false) when it should not have been.
                                • taconiteundefined
                                  taconite
                                  I had it this way (tpre.g)
                                  if no tool in effector
                                        pick tool
                                  else {}
                                  	display message "Sill tool in effector"
                                  	abort
                                  I removed the abort. Everything was correct but the execution of a macro with a Tpren.g just did not work with the abort
                                  Custom ANET A8
                                    jay_s_uk
                                    @taconite try it with break rather than abort
                                    • K01571N3Nundefined
                                      K01571N3N
                                      Hi, this is what i have been thinking and i need this for my toolchanger.
                                      Duet 3 6HC, 3HC and Raspberry pi.
                                      If i write to console
                                      M560 P"0:/sys/test"
                                      or run macro like that
                                      M560 P"/sys/test"
                                      <!-- **EoF** -->
                                      or whatever else, "Error: M560: Can't open file test for writing" appears...
                                      If i write
                                      M98 P"0:/sys/test
                                      it will run that macro.
                                      Is Raspberry pi somehow causing the trouble here or what?
                                      K01571N3Nundefined 1 Reply Last reply Reply Quote 0
                                        K01571N3N @K01571N3N
                                        @dc42 @T3P3Tony Do you have any idea for my problem?
                                          Phaedrux Moderator @K01571N3N
                                          @K01571N3N Might be better idea to start a new thread with exactly what you're trying to do. Include firmware version details etc.
