    RailCore II corexy
    My Duet controlled machine
    27
    118
    41.0k
    • kraegarundefined
      kraegar
      So, I'm printing. I still have some tidying up to do on the electronics (need to box up that side once I'm sure the wiring is all settled). Need to wrap the wires up, etc. Print a paneldue enclosure and attach it. Little miscellaneous items like that. There's a slight bit of tweaking to be done to get the plane of the bed completely flat. It's close, but it can be better.
      So the click of "print" on the first test, a 20mmx20x10 cube, gave a very nice result with mesurements 20.04 x 19.98 x 9.99.
      Here's the second print, the traditional benchy.
      I've printed enough of them to say I can look at this one and not see anything that stands out as needing drastic improvement. There was no appreciable stringing - just 3 or 4 fine wisps. The surface is even, the cooling was excellent (the line of the bow shows zero sights of any curling) and all the thin walls meet nicely. That was printed at 75mm/s. Edit: the last pic seems to show a layer or two that bulge in the bottom right. They don't in person - I checked after I saw them in the pic. I think it's a trick of the filament and the lighting)
      • kraegarundefined
        kraegar
        I did fight with Z motion for a while yesterday, was really weird. I'd get double, half, no movement, or even movement in the opposite direction from sending a simple G1 Z10 / G1 Z-10. Reflashing the firmware resolved that one.
        • jstevewhiteundefined
          jstevewhite
          @Whitewolf:
          Beautiful! I am curios to know what the best achievable speed while maintaining quality is.
          Kraegar printed the benchy at 75mm/s; I've gone as high as 90mm/s with .4 nozzle at lower layer heights with only slight ringing. Kraegar's build seems to be performing a bit better than my prototype "alpha" model, so we'll have to wait for his high-speed tests. 😄
          • kraegarundefined
            kraegar
            Noticing some variation in the IR probe trigger heights across the bed. Trying to figure out what's causing that - square printers are new to me so there's some learning curve there. I like to chase perfection on these things. Everything's within .1mm across the bed currently, but I'd like to get that down around 0.1, the oddball trigger height variation is making it tough, though.
            • Whitewolfundefined
              Whitewolf
              looking good
              • kraegarundefined
                kraegar
                Current status: Everything is done on my build. Tested with a BLTouch, and will be tinkering with a piezo just to try one on it (love it on my delta). I need to work on the documentation, and a couple STL's on Thingiverse. I have a ton of photos of the build to process for the documentation.
                The great news: this thing prints fantastically. Essentially zero problems with it since the build was completed.
                Here's a print from last night.
                  T3P3Tony administrators
                  That is a great looking printer and print!
                    deckingman
                    Yes, very impressive!
                    • kraegarundefined
                      kraegar
                      Thanks guys. Spent a couple days out of town for work. I hope to put some time in on the documentation this weekend.
                      • kraegarundefined
                        kraegar
                        A short video of a 0.05mm layer print, at 75mm/s print speed:
                        https://www.youtube.com/watch?v=z3Zicibib8c
                        • kraegarundefined
                          kraegar
                          The results of the print. 0.01mm print on the left, 0.05mm layer on the right. Both at 75mm/s (no other changes aside from layer height)
                            Whitewolf
                            Nice
                            • kraegarundefined
                              kraegar
                              0.02, 0.05
                              0.02
                              The 0.02 needed a bit more infill / top layers, there are a couple small gaps on the top surfaces around the outside. The thin layers just don't cover 20% infill terribly well. All were printed with the same settings other than layer height. 20% infill, 3 bottom, 5 top, 3 perimeter. 75mm/s. Atomic gold PLA
                              • kraegarundefined
                                kraegar
                                Reprint with 40% infill , 6 top, 4 bottom layers. 0.02mm layers @ 75mm/s.
                                  awesome prints!
                                  • kraegarundefined
                                    kraegar
                                    The railcoreII will be at Detroit Maker Faire all this weekend (July 28 - 30), in the 713maker booth.
                                    • kraegarundefined
                                      kraegar
                                      Had a good weekend showing and talking about the RailCoreII at the Detroit Maker Faire, thanks to 713maker.com for letting me share their booth.
                                      • kraegarundefined
                                        kraegar
                                        I've begun adding assembly drawings to the docs. I'd welcome any feedback on the clarity of the drawings.
                                        • jkflorekundefined
                                          jkflorek
                                          Looks great! Any reason why the idlers aren't aligned to remove the belt crossover (similar to http://i.imgur.com/IAgrbDp.png)?
                                          • saffiundefined
                                            saffi
                                            Are the main benefits of a CoreXY against something like a Prusa i3 mainly a speed increase due to increased stability?
                                            Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
