    RailCore II corexy
    My Duet controlled machine
    27
    118
    41.4k
    • jstevewhiteundefined
      jstevewhite
      @Whitewolf:
      Beautiful! I am curios to know what the best achievable speed while maintaining quality is.
      Kraegar printed the benchy at 75mm/s; I've gone as high as 90mm/s with .4 nozzle at lower layer heights with only slight ringing. Kraegar's build seems to be performing a bit better than my prototype "alpha" model, so we'll have to wait for his high-speed tests. 😄
      • kraegarundefined
        kraegar
        Noticing some variation in the IR probe trigger heights across the bed. Trying to figure out what's causing that - square printers are new to me so there's some learning curve there. I like to chase perfection on these things. Everything's within .1mm across the bed currently, but I'd like to get that down around 0.1, the oddball trigger height variation is making it tough, though.
        • Whitewolfundefined
          Whitewolf
          looking good
          • kraegarundefined
            kraegar
            Current status: Everything is done on my build. Tested with a BLTouch, and will be tinkering with a piezo just to try one on it (love it on my delta). I need to work on the documentation, and a couple STL's on Thingiverse. I have a ton of photos of the build to process for the documentation.
            The great news: this thing prints fantastically. Essentially zero problems with it since the build was completed.
            Here's a print from last night.
              T3P3Tony administrators
              That is a great looking printer and print!
                deckingman
                Yes, very impressive!
                • kraegarundefined
                  kraegar
                  Thanks guys. Spent a couple days out of town for work. I hope to put some time in on the documentation this weekend.
                  • kraegarundefined
                    kraegar
                    A short video of a 0.05mm layer print, at 75mm/s print speed:
                    https://www.youtube.com/watch?v=z3Zicibib8c
                    • kraegarundefined
                      kraegar
                      The results of the print. 0.01mm print on the left, 0.05mm layer on the right. Both at 75mm/s (no other changes aside from layer height)
                        Whitewolf
                        Nice
                        • kraegarundefined
                          kraegar
                          0.02, 0.05
                          0.02
                          The 0.02 needed a bit more infill / top layers, there are a couple small gaps on the top surfaces around the outside. The thin layers just don't cover 20% infill terribly well. All were printed with the same settings other than layer height. 20% infill, 3 bottom, 5 top, 3 perimeter. 75mm/s. Atomic gold PLA
                          • kraegarundefined
                            kraegar
                            Reprint with 40% infill , 6 top, 4 bottom layers. 0.02mm layers @ 75mm/s.
                              awesome prints!
                              • kraegarundefined
                                kraegar
                                The railcoreII will be at Detroit Maker Faire all this weekend (July 28 - 30), in the 713maker booth.
                                • kraegarundefined
                                  kraegar
                                  Had a good weekend showing and talking about the RailCoreII at the Detroit Maker Faire, thanks to 713maker.com for letting me share their booth.
                                  • kraegarundefined
                                    kraegar
                                    I've begun adding assembly drawings to the docs. I'd welcome any feedback on the clarity of the drawings.
                                    • jkflorekundefined
                                      jkflorek
                                      Looks great! Any reason why the idlers aren't aligned to remove the belt crossover (similar to http://i.imgur.com/IAgrbDp.png)?
                                      • saffiundefined
                                        saffi
                                        Are the main benefits of a CoreXY against something like a Prusa i3 mainly a speed increase due to increased stability?
                                        Prusa i3 Style Printer with Duet WiFi, E3D Volcano, Bondtech BMG
                                        • kraegarundefined
                                          kraegar
                                          @saffi:
                                          The bed on a corexy only has to move in Z, not in X or Y. This makes it easier to keep your bed level (in theory, the practice varies by implementation) and you only have to move your carriage in x/y. That leads to more consistent movement in X/Y, and by making your carriage lighter, you can print faster than a typical cartesian.
                                          There are other advantages and better explanations, I'm sure. But that's the quick overview as I understand them.
                                            jstevewhite
                                            @jkflorek:
                                            To arrange the idlers in that way would have required a much larger frame and weird motor mounts, and smaller idlers. The RailCore's motors are outside the build volume. The illustration you've provided is only one end of the belt path, but is topologically identical to the RailCore's belt path. RailCore is a duo-planar corexy design, not a crossing belt design. The "crossover" you see doesn't cross belt planes, so there's no compelling reason to eliminate it.
                                            That said, I've got both sitting here; the original RailCore (the one kraegar is showing is RailCore2) which is a crossing-belt design, and RailCore2, which is a duo-planar belt design. There's no observable difference in performance. It's not difficult to make a 'crossing belt design' where the belts don't rub (the main reason folks worry about belt crossover), but neither RailCore has that issue.
