    Dual Markforged :idle IDEX carriage is not still during print
    892
    • martin7404undefined
      martin7404 @sebkritikel
      @sebkritikel i tried 100 % idle current, no change
      Muldex IDEX Duet2+Duex5
      Custom CoreXY 600x400 Hemera , Duet3+Toolboard+1HCL closed loop
      Sapphire Pro with Duet2, with closed-loop motors
      custom high temp E3D tool changer with Duet2+Duex
        martin7404 @Phaedrux
        @Phaedrux
        M98 P"config.g"
        HTTP is enabled on port 80
        FTP is disabled
        TELNET is disabled
        Warning: Heater 0 appears to be over-powered. If left on at full power, its temperature is predicted to reach 365C
        The M568 command is no longer needed
        Warning: Heater 1 appears to be over-powered. If left on at full power, its temperature is predicted to reach 723C
        Warning: Heater 2 appears to be over-powered. If left on at full power, its temperature is predicted to reach 528C
          @Phaedrux ```
          m906
          Motor current (mA) - X:700, Y:700, Z:500, U:700, E:1000:1000, idle factor 50%
          3/8/2021, 11:35:56 PM	M98 P"config.g"
            Phaedrux Moderator @martin7404
            @martin7404 said in Dual Markforged :idle IDEX carriage is not still during print:
            m906
            How bout for the other commands? M92 M305 M201 M203 etc etc
            martin7404undefined 1 Reply Last reply Reply Quote 0
              @Phaedrux
              m203
              Max speeds (mm/min): X: 12000.0, Y: 12000.0, Z: 1000.0, U: 12000.0, E: 4200.0:4200.0, min. speed 30.00
              3/9/2021, 7:12:00 AM	m201
              Accelerations (mm/sec^2): X: 800.0, Y: 800.0, Z: 350.0, U: 800.0, E: 600.0:600.0
              3/9/2021, 7:11:43 AM	m950
              Error: M950: exactly one of FHJPS must be given
              3/9/2021, 7:11:32 AM	m308
              Error: M308: missing parameter 'S'
              3/9/2021, 7:11:21 AM	m305
              Error: M305: M305 has been replaced by M308 and M950 in RepRapFirmware 3
              3/9/2021, 7:05:16 AM	m92
              Steps/mm: X: 100.000, Y: 100.000, Z: 799.200, U: 100.000, E: 813.070:830.000
              3/9/2021, 7:03:45 AM	Connection established
                martin7404
                I have a solution of the problem by chance.
                I am still waiting for my new Duet wifi , and the setup is the strange one with Z on duet and X,y and U on Duex.
                Because the machine is working somehow I continued with the commissioning I started Dual material print with both tools and in the begining of gcode both tools are defined temps with G10 and then with Tn P0 , both are activated for a moment in order to reach standby temp. Then G28 G29 etc....
                It happens that when both tools are activated and the idle is on standby there is no movement in stanby tool
                  martin7404
                  My new duet wifi is here , installed, updated firmware to 3.2.2, X,Y,U axes are back on mainboard, first print ongoing
                    martin7404
                    So it is printing with U carriage at the moment an the X carriage that is standby is dead still during print
                      dc42 administrators @martin7404
                      Assuming you home both carriages before doing a print, then both motors should have current flowing in them, unless you subsequently use M18 or M84 to set one or more motors idle.
                        martin7404 @dc42
                        @dc42 in the start G code there is always homing X U Y Z. But when I enable only Left or Right extruder with G10 in the beginning, during print the tool that was not active was moving a little back and forth with Y-axis changing direction.
                        Then I found a faulty mainboard
                        The whole time there was no unactivated axis motor
                        So I think it is now sorted with new mainboard
