Duet WiFi always starting and will not connect to WiFi
The date it displays for the wifi firm is identical to the WifiServer-1.22.bin file when sending an M115 command.
And still just get this
Would it be better to erase the board and try it all over? I have tried original sd for stock, to updating the the wifi firm, to trying a fresh sd card with different firmwares from 2.0-2.03 betas and it always returns the same on these commands. I never get an idle message.
@s_mabe said in Duet WiFi always starting and will not connect to WiFi:
I don't think that will help. It looks like either there is a communication failure between the WiFi module and the Duet main processor, or the wifi firmware failed to upload, or the wifi firmware you are installing is corrupt. Please try downloading and installing the wifi firmware here https://www.dropbox.com/s/gkb6rulcayiqjcm/DuetWiFiServer.bin?dl=0.
Is your Duet still under warranty?
I just bought it from Filastruder. Finally got the rest of the stuff needed and have begun to set it up. I bought it Febuary 28th, so I think I am still in the return window. Seems everything else works. I have not connected any heaters yet, but the motors are running properly, and controllable from the Panel due. Config changes are working. Had to reverse some motors. Just no wifi.
I have checked it after putting the different firms and it returns as 2.03 or whatever I flash to it. The wifi module lights up when flashing firm.
Tried that firmware and does the same thing.
It's time to ask Filastruder to replace your Duet then.
Thank you for your time!!
Having the exact same problem on a Duet 2 WiFi immediately after updating from RRF 3.2 to 3.2.2.
Before the update it worked perfectly.
Where can I get the WiFi firmware and how do I update it?
@tetele, I suggest you first send M997 S1 from USB or PanelDue to reinstall the WiFi firmware. That usually fixes this type of issue. The WiFi firmware file should already be on your SD card. If you need a fresh copy, you can find it here https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.bin.
@dc42 worked like a charm. Thanks!
undefined faaz referenced this topic
