    Duet WiFi always starting and will not connect to WiFi
    2.4k
    • aidarundefined
      aidar
      Hi.
      Have you seen this? : https://duet3d.dozuki.com/Guide/1.)+Getting+Connected+to+your+Duet/7
        dc42 administrators @Victor
        @victor said in Duet WiFi always starting and will not connect to WiFi:
        using USB and YAT to send M552 I get
        M552<LF>
        WiFi module is being started<LF>
        ok<LF>.
        It said starting but never does. this was solved for someone else on the forum by installing a file in config.g but I didn't understand how that was done.
        If the WiFi module is stuck in the Starting state, that may mean that the main firmware and WiFi firmware versions are out of step. Did you do a firmware upgrade, and if so, which version of main firmware are you using? Send M115 to find out.
        • S_Mabeundefined
          S_Mabe
          Having the same problem. M552 says Module is being started. Have switch to different firmwares, updated wifi firmware, and still fails to start. It will not store ssid information, and an M552 S1 says Turn off the current WiFi mode before selecting a new one
          M552 S0 says ok, Been at this for days and cannot get it to connect. I only get a single blue flash on WIFI led on power up. I get blue lights flashing when uploading WIFI firmware.
            Neither of you have said which main firmware version you are running (send M115 to check), or which WiFi firmware version you think you are running and how you tried to install it.
            • S_Mabeundefined
              S_Mabe
              I am back to trying the 2.02 (RTOS) I put these on a blank sd card along with the WIfiServer-1.22bin. Extracted Webcontrol to WWW folder. I sent a M997 S0, then a M997 S1. Said upload complete.
              • S_Mabeundefined
                S_Mabe
                Both displayed progress on my panel due when uploading.
                • S_Mabeundefined
                  S_Mabe
                  0_1553098284978_YAT - [[Terminal1] - COM27 - Open - Connected] 3_20_2019 10_10_43 AM.png
                  This is after Uploading Wifiserver-1.22.bin
                    dc42 administrators @S_Mabe
                    @s_mabe said in Duet WiFi always starting and will not connect to WiFi:
                    By "Uploading", I presume you mean that you copied it to the SD card in a PC, because WiFi is not working. After you copied it to the SD card, did you rename it to exactly DuetWiFiServer.bin, deleting the existing file of the same name first?
                    • S_Mabeundefined
                      S_Mabe
                      Yes I took off the -1.22 from the file so it was identical to the one I removed, and uploaded, I guess I mean flashed with an M997 S1 command using Yat.
                      • S_Mabeundefined
                        S_Mabe
                        The date it displays for the wifi firm is identical to the WifiServer-1.22.bin file when sending an M115 command.
                        • S_Mabeundefined
                          S_Mabe
                          0_1553100539075_YAT - [[Terminal1] - COM27 - Open - Connected] 3_20_2019 10_48_40 AM.png
                          And still just get this
                          • S_Mabeundefined
                            S_Mabe
                            Would it be better to erase the board and try it all over? I have tried original sd for stock, to updating the the wifi firm, to trying a fresh sd card with different firmwares from 2.0-2.03 betas and it always returns the same on these commands. I never get an idle message.
                              I don't think that will help. It looks like either there is a communication failure between the WiFi module and the Duet main processor, or the wifi firmware failed to upload, or the wifi firmware you are installing is corrupt. Please try downloading and installing the wifi firmware here https://www.dropbox.com/s/gkb6rulcayiqjcm/DuetWiFiServer.bin?dl=0.
                              Is your Duet still under warranty?
                              • S_Mabeundefined
                                S_Mabe
                                I just bought it from Filastruder. Finally got the rest of the stuff needed and have begun to set it up. I bought it Febuary 28th, so I think I am still in the return window. Seems everything else works. I have not connected any heaters yet, but the motors are running properly, and controllable from the Panel due. Config changes are working. Had to reverse some motors. Just no wifi.
                                I have checked it after putting the different firms and it returns as 2.03 or whatever I flash to it. The wifi module lights up when flashing firm.
                                • S_Mabeundefined
                                  S_Mabe
                                  Tried that firmware and does the same thing.
                                    It's time to ask Filastruder to replace your Duet then.
                                    • S_Mabeundefined
                                      S_Mabe
                                      Thank you for your time!!
                                      • teteleundefined
                                        tetele
                                        Having the exact same problem on a Duet 2 WiFi immediately after updating from RRF 3.2 to 3.2.2.
                                        Before the update it worked perfectly.
                                        Where can I get the WiFi firmware and how do I update it?
                                          @tetele, I suggest you first send M997 S1 from USB or PanelDue to reinstall the WiFi firmware. That usually fixes this type of issue. The WiFi firmware file should already be on your SD card. If you need a fresh copy, you can find it here https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.bin.
                                          teteleundefined 1 Reply Last reply Reply Quote 1
                                          • teteleundefined
                                            tetele @dc42
                                            @dc42 worked like a charm. Thanks!
                                            • faazundefined faaz referenced this topic
