    Duet WiFi always starting and will not connect to WiFi
    2.4k
      dc42 administrators @S_Mabe
      @s_mabe said in Duet WiFi always starting and will not connect to WiFi:
      This is after Uploading Wifiserver-1.22.bin
      By "Uploading", I presume you mean that you copied it to the SD card in a PC, because WiFi is not working. After you copied it to the SD card, did you rename it to exactly DuetWiFiServer.bin, deleting the existing file of the same name first?
      • S_Mabeundefined
        S_Mabe
        Yes I took off the -1.22 from the file so it was identical to the one I removed, and uploaded, I guess I mean flashed with an M997 S1 command using Yat.
        • S_Mabeundefined
          S_Mabe
          The date it displays for the wifi firm is identical to the WifiServer-1.22.bin file when sending an M115 command.
          • S_Mabeundefined
            S_Mabe
            0_1553100539075_YAT - [[Terminal1] - COM27 - Open - Connected] 3_20_2019 10_48_40 AM.png
            And still just get this
            • S_Mabeundefined
              S_Mabe
              Would it be better to erase the board and try it all over? I have tried original sd for stock, to updating the the wifi firm, to trying a fresh sd card with different firmwares from 2.0-2.03 betas and it always returns the same on these commands. I never get an idle message.
                I don't think that will help. It looks like either there is a communication failure between the WiFi module and the Duet main processor, or the wifi firmware failed to upload, or the wifi firmware you are installing is corrupt. Please try downloading and installing the wifi firmware here https://www.dropbox.com/s/gkb6rulcayiqjcm/DuetWiFiServer.bin?dl=0.
                Is your Duet still under warranty?
                • S_Mabeundefined
                  S_Mabe
                  I just bought it from Filastruder. Finally got the rest of the stuff needed and have begun to set it up. I bought it Febuary 28th, so I think I am still in the return window. Seems everything else works. I have not connected any heaters yet, but the motors are running properly, and controllable from the Panel due. Config changes are working. Had to reverse some motors. Just no wifi.
                  I have checked it after putting the different firms and it returns as 2.03 or whatever I flash to it. The wifi module lights up when flashing firm.
                  • S_Mabeundefined
                    S_Mabe
                    Tried that firmware and does the same thing.
                      It's time to ask Filastruder to replace your Duet then.
                      • S_Mabeundefined
                        S_Mabe
                        Thank you for your time!!
                        • teteleundefined
                          tetele
                          Having the exact same problem on a Duet 2 WiFi immediately after updating from RRF 3.2 to 3.2.2.
                          Before the update it worked perfectly.
                          Where can I get the WiFi firmware and how do I update it?
                            @tetele, I suggest you first send M997 S1 from USB or PanelDue to reinstall the WiFi firmware. That usually fixes this type of issue. The WiFi firmware file should already be on your SD card. If you need a fresh copy, you can find it here https://github.com/Duet3D/RepRapFirmware/releases/download/3.2/DuetWiFiServer.bin.
                            teteleundefined 1 Reply Last reply Reply Quote 1
                            • teteleundefined
                              tetele @dc42
                              @dc42 worked like a charm. Thanks!
                              • faazundefined faaz referenced this topic
