    Duet3 doesn't always heat hotend
    Duet Web Control
    723
    • BlueDustundefined
      BlueDust @Phaedrux
      @Phaedrux said in Duet3 doesn't always heat hotend:
      M122 B1
      I am using a 1LC board, but I want to say (can't remember forsure) that this issue was happening before I connected the board. It is really hard to say when I first noticed the problem as it has been going on for months. It generally only occurs once and resolved after hitting the Emergency Stop button. Just today, it happened a few consecutive times after hitting the Emergency Stop button and decided this was no longer a fluke.
      M122 B10
      Diagnostics for board 10:
      Duet TOOL1LC firmware version 3.2 (2021-01-05)
      Bootloader ID: SAMC21 bootloader version 2.2 (2021-01-16b1)
      Never used RAM 4012, free system stack 50 words
      HEAT 86 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64
      Last reset 04:52:46 ago, cause: software
      Last software reset data not available
      Driver 0: position 13470175, 830.9 steps/mm, ok, SG min/max 0/52, read errors 0, write errors 1, ifcnt 42, reads 1335, writes 14, timeouts 0, DMA errors 0
      Moves scheduled 146126, completed 146125, in progress 1, hiccups 0
      Next step interrupt due in 315 ticks, enabled
      VIN: 23.6V
      MCU temperature: min 34.7C, current 51.4C, max 52.4C
      Ticks since heat task active 133, ADC conversions started 17558804, completed 17558803, timed out 0
      Last sensors broadcast 0x00000001 found 1 137 ticks ago, loop time 0
      CAN messages queued 210921, send timeouts 0, received 304378, lost 0, free buffers 36
      Fun, that 3 letter word with "u" in the middle.
      • engikeneerundefined
        engikeneer @BlueDust
        @BlueDust I guess the printer goes into 'busy' or 'changing tool' state because there is an M116 called during a tool change (even if that is only activating/deactivating T0. Do you have a Tpre0.g, Tpost0.g etc in your /sys directory? If so, check their contents and remove any M116. If not, create them and keep them empty to override any default behaviour.
        FWIW, I get something similar every now and then where I type a temperature into DWC, hit enter on my PC and it doesn't react to it. Using D2Wifi on RRF3.2.2 (and DWC3.2.2). Sometimes I see a notification in DWC for 'invalid number' (or something similar I can't quite remember...), bit not always. If it helps I'll try and grab a screenshot next time it happens to me
        i3 clone with a bunch of mods
        BlueDustundefined 1 Reply Last reply Reply Quote 0
        • BlueDustundefined
          BlueDust @engikeneer
          @engikeneer
          Tpre0.g already exists and basically empty.
          ; tpre0.g
          ; called before tool 0 is selected
          ; generated by RepRapFirmware Configuration Tool v3.1.4 on Sun Nov 15 2020 19:29:35 GMT-0500 (Eastern Standard Time)
          ; tpre1.g
          ; called before tool 1 is selected
          engikeneerundefined 1 Reply Last reply Reply Quote 0
            @BlueDust and tfree0.g & tpost0.g? my tpost0.g has an M116 in it (though not sure if that was in by default or I added...)
              Can you share your config.g please?
              • BlueDustundefined
                BlueDust @Phaedrux
                @Phaedrux
                I have a lot of config currently commented out as I still have to add my 2nd 1LC board and attach my 2nd hotend to it for IDEX.
                ; generated by RepRapFirmware Configuration Tool v3.2.1 on Sun Jan 10 2021 20:45:03 GMT-0500 (Eastern Standard Time)
                G90                                                   ; send absolute coordinates...
                M83                                                   ; ...but relative extruder moves
                M550 P"Duet 3"                                        ; set printer name
                ;M569 P0.0 S1                                          ; physical drive 0.0 goes forwards
                M569 P0.0 S0
                ;M569 P10.0 S0
                M569 P0.3 S0
                M569 P0.1 S1                                          ; physical drive 0.1 goes forwards
                M569 P0.2 S1                                          ; physical drive 0.2 goes forwards
                M569 P10.0 S1                                        ; physical drive 121.0 goes forwards
                ;M569 P11.0 S1                                        ; physical drive 122.0 goes forwards - Right Extruder
                ;M584 X0.0 Y0.1 Z0.2 E10.0                      		; set drive mapping
                M584 X0.1 U0.4 Y0.5 Z0.0 E10.0:11.0
                ;M584 X0.0 Y0.1 Z0.2 E10.0:11.0                      ; set drive mapping - Right Extruder
                M350 X16 U16 Y16 Z16 E16:16 I1                            ; configure microstepping with interpolation
                M92 X160.00 U160 Y160.00 Z800.00 E830.9:830.9           ; set steps per mm
                M566 X400.00 U400 Y400.00 Z40.00 E1000.00:1000.00            ; set maximum instantaneous speed changes (mm/min)
                M203 X4000.00 U4000 Y4000.00 Z200.00 E1200.00:1200.00       ; set maximum speeds (mm/min)
                M201 X400.00 U400 Y400.00 Z40.00 E1000.00:1000.00            ; set accelerations (mm/s^2)
                M906 X1000 U1000 Y1000 Z1800 E1000:1000 I30                      ; set motor currents (mA) and motor idle factor in per cent
                M84 S30                                               ; Set idle timeout
                M208 X-53 U0 Y0 Z0 S1                                      ; set axis minima
                M208 X300 U353 Y300 Z370 S0                                ; set axis maxima
                M574 X1 S3                                            ; configure sensorless endstop for low end on X
                M574 U1 S3
                M574 Y1 S3                                            ; configure sensorless endstop for low end on Y
                M574 Z1 S2                                            ; configure Z-probe endstop for low end on Z
                M950 S0 C"10.io0.out"                                ; create servo pin 0 for BLTouch
                ;M950 S4 C"10.io0.out"
                ;M558 P9 C"^10.io0.in" H5 F120 T6000                  ; set Z probe type to bltouch and the dive height + speeds
                ;M558 P9 C"^10.io0.in" H5 F100 R0.2 T6000 A5 B0
                M558 P9 C"^10.io0.in" H5 F100 R0.2 T6000 A5 B1
                ;G31 P500 X0 Y0 Z2.5                                   ; set Z probe trigger value, offset and trigger height
                G31 P500 X-30 Y-12 Z3.58
                ;M557 X15:275 Y15:275 S20                              ; define mesh grid
                M557 X30:270 Y30:270 P2
                M308 S0 P"10.temp0" Y"thermistor" T100000 B4138      ; configure sensor 0 as thermistor on pin 121.temp0
                M950 H0 C"10.out0" T0                                ; create nozzle heater output on 121.out0 and map it to sensor 0
                M307 H0 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                M143 H0 S280                                          ; set temperature limit for heater 0 to 100C
                ;M308 S1 P"11.temp0" Y"thermistor" T100000 B4138      ; configure sensor 1 as thermistor on pin 122.temp0
                ;M950 H1 C"11.out0" T1                                ; create nozzle heater output on 122.out0 and map it to sensor 1
                ;M307 H1 B0 S1.00                                      ; disable bang-bang mode for heater  and set PWM limit
                ;M143 H1 S280                                          ; set temperature limit for heater 1 to 280C
                M308 S2 P"temp2" Y"thermistor" T100000 B4138          ; configure sensor 2 as thermistor on pin temp3
                M950 H2 C"out3" T2                                    ; create bed heater output on out3 and map it to sensor 2
                M307 H2 B0 S1.00                                      ; disable bang-bang mode for the bed heater and set PWM limit
                M140 H2                                               ; map heated bed to heater 2
                M143 H2 S100                                          ; set temperature limit for heater 2 to 280C
                M572 D0:1 S0.07											; Pressure Advanced for extruders 0 and 1
                M950 F0 C"10.out1" Q500                              ; create fan 0 on pin 121.out1 and set its frequency
                M106 P0 C"PartFanLeft" S0 H-1                         ; set fan 0 name and value. Thermostatic control is turned off
                M950 F1 C"10.out2" Q500                              ; create fan 1 on pin 121.out2 and set its frequency
                M106 P1 C"HotendFanLeft" S1 H0 T40                    ; set fan 1 name and value. Thermostatic control is turned on
                ;M950 F2 C"11.out1" Q500                              ; create fan 2 on pin 122.out1 and set its frequency
                ;M106 P2 C"PartFanRight" S0 H-1                        ; set fan 2 name and value. Thermostatic control is turned off
                ;M950 F3 C"11.out2" Q500                              ; create fan 3 on pin 122.out2 and set its frequency
                ;M106 P3 C"HotendFanRight" S1 H1 T40                   ; set fan 3 name and value. Thermostatic control is turned on
                M563 P0 S"LeftExtruder" D0 H0 F0                      ; define tool 0
                G10 P0 X0 Y0 Z0                                       ; set tool 0 axis offsets
                G10 P0 R0 S0                                          ; set initial tool 0 active and standby temperatures to 0C
                ;M563 P1 S"RightExtruder" D1 H1 F2                     ; define tool 1
                ;G10 P1 X0 Y0 Z0                                       ; set tool 1 axis offsets
                ;G10 P1 R0 S0                                          ; set initial tool 1 active and standby temperatures to 0C
                ;M563 P2 S"Copy" D0:1 H1:2 F0:2                        ; define tool 2
                ;G10 P2 X0 Y0 Z0                                       ; set tool 2 axis offsets
                ;G10 P2 R0 S0                                          ; set initial tool 2 active and standby temperatures to 0C
                ;M568 P2 S1                                            ; enable mixing for tool 2
                ;M567 P2 E0.5:0.5                                      ; set mixing ratios for tool 2
                ;M563 P3 S"Mirror" D0:1 H1:2 F0:2                      ; define tool 3
                ;G10 P3 X0 Y0 Z0                                       ; set tool 3 axis offsets
                ;G10 P3 R0 S0                                          ; set initial tool 3 active and standby temperatures to 0C
                ;M568 P3 S1                                            ; enable mixing for tool 3
                ;M567 P3 E0.5:0.5                                      ; set mixing ratios for tool 3
                M575 P1 S1 B57600                                     ; enable support for PanelDue
                M501                                                  ; load saved parameters from non-volatile memory
                M911 S10 R11 P"M913 X0 U0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
                ;T0                                                    ; select first tool
                Not that I think it matters, but do have a M116 command in there.... But also sharing my Auto Ready Macro I run before each print. (originally created for and copied from another printer running on a Duet2) This macro does work most of the time on the Duet3, and everytime on Duet2 (still running on 2.x)
                M290 R0 S0			;Clear Baby Stepping
                M140 R60 S60 		;Bed Temp
                T0					;Enable Hotend - Active.
                G10 P0 R130 S150	;Hotend Temp
                M116 				;Wait for heater teamps
                G28					;Home
                G28
                G29					;Auto Compensation
                G0 X-100 U400 Y-100 Z25 F6000		;Go here, this fast
                G10 P0 R130 S200
                M140 R60 S70
                M290 S-0.10			;Baby Stepping
                • BlueDustundefined
                  @engikeneer said in Duet3 doesn't always heat hotend:
                  tfree0
                  ; tfree0.g
                  ; called when tool 0 is freed
                  ;Duet IDEX Example Code
                  M83 ; relative extruder movement
                  ;G1 E-2 F3600 ; retract 2mm
                  M106 S0           ; turn off our print cooling fan
                  G91 ; relative axis movement
                  G1 Z3 F500 ; up 3mm
                  G90 ; absolute axis movement
                  ;G1 S2 X-52 F6000 ; park the X carriage at -52mm
                  G1 H2 X-52 F6000 ; park the X carriage at -52mm
                  ; tfree1.g
                  ; called when tool 1 is freed
                  G1 Z3 F500 ; up 3mm
                  ;G1 S2 U248 F6000 ; park the U carriage at +248mm
                  G1 H2 U248 F6000 ; park the U carriage at +248mm
                    Can you try adding G4 S2 near the start of your config.g? This will add a 2 second pause to give the boards time to initialize before commands are sent.
                    BlueDustundefined 1 Reply Last reply Reply Quote 1
                    • BlueDustundefined
                      BlueDust @Phaedrux
                      Added it. It seems to only occur 20% of the time. I will follow up after a few prints.
                      Any idea why the Duet3 doesn't give an error for thermal protection? I know the hotend isn't actually heating up at all, and I assume something in the logic seems to know that, otherwise it would have. But I wonder if there is an odd glitch or edge case where the thermal protection may fail.
                      Thanks for the help!
                        dc42 administrators @BlueDust
                        @BlueDust said in Duet3 doesn't always heat hotend:
                        The thermal protection is handed on the board with the heater; so if it doesn't execute the heating command for any reason, protection won't cut in.
                        • BlueDustundefined
                          BlueDust
                          @Phaedrux
                          It happened again. It says Busy and doesn't react to any clicks on Heater0.
                          Also, appears it is still trying to wait for the hotend to reach the set temp as the Macro is still in process.
                          I will keep the Duet3 in this state for a little while in hopes you are able to respond and have anything you would like me to do before I hit Emergency Stop and start the next print.
                          G4 S2   			;adds a 2 second pause to give the boards time to initialize before commands are sent.  May fix random hotend not heating up
                          M122
                          RepRapFirmware for Duet 3 MB6HC version 3.2.2 running on Duet 3 MB6HC v1.01 or later (SBC mode)
                          Board ID: 08DJM-956L2-G43S4-6JTDJ-3SD6S-9S5YD
                          Used output buffers: 1 of 40 (18 max)
                          Static ram: 149788
                          Dynamic ram: 62796 of which 104 recycled
                          Never used RAM 146144, free system stack 178 words
                          Tasks: Linux(ready,101) HEAT(blocked,297) CanReceiv(blocked,824) CanSender(blocked,371) CanClock(blocked,352) TMC(blocked,50) MAIN(running,1183) IDLE(ready,19)
                          Owned mutexes: Telnet(MAIN)
                          Last reset 00:09:44 ago, cause: power up
                          Last software reset at 2021-03-11 21:55, reason: User, none spinning, available RAM 145852, slot 2
                          Software reset code 0x0012 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task Linu Freestk 0 n/a
                          Error status: 0x00
                          Aux0 errors 0,0,0
                          Aux1 errors 0,0,0
                          MCU temperature: min 9.9, current 28.9, max 29.1
                          Supply voltage: min 24.0, current 24.0, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                          12V rail voltage: min 12.1, current 12.2, max 12.2, under voltage events: 0
                          Driver 0: position 0, standstill, reads 2086, writes 14 timeouts 0, SG min/max 0/0
                          Driver 1: position 0, standstill, reads 2086, writes 14 timeouts 0, SG min/max 0/0
                          Driver 2: position 0, standstill, reads 2089, writes 11 timeouts 0, SG min/max 0/0
                          Driver 3: position 0, standstill, reads 2089, writes 11 timeouts 0, SG min/max 0/0
                          Driver 4: position 0, standstill, reads 2086, writes 14 timeouts 0, SG min/max 0/0
                          Driver 5: position 0, standstill, reads 2086, writes 14 timeouts 0, SG min/max 0/0
                          Date/time: 2021-03-12 08:59:09
                          Slowest loop: 54.70ms; fastest: 0.03ms
                          === Storage ===
                          Free file entries: 10
                          DMs created 125, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                          === MainDDARing ===
                          === AuxDDARing ===
                          Bed heaters = 2 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamberHeaters = -1 -1 -1 -1
                          Heater 0 is on, I-accum = 0.0
                          Heater 2 is on, I-accum = 0.0
                          Segments left: 0
                          Movement lock held by HTTP
                          HTTP* is doing "M116" in state(s) 0 0, running macro
                          Telnet* is doing "M122" in state(s) 0
                          File is idle in state(s) 0
                          USB is idle in state(s) 0
                          Aux is idle in state(s) 0
                          Queue is idle in state(s) 0
                          LCD is idle in state(s) 0
                          SBC is idle in state(s) 0
                          Daemon is idle in state(s) 0
                          Aux2 is idle in state(s) 0
                          Code queue is empty.
                          === CAN ===
                          Messages queued 2251, send timeouts 0, received 6684, lost 0, longest wait 2ms for reply type 6049, free buffers 48
                          === SBC interface ===
                          State: 4, failed transfers: 0
                          Last transfer: 2ms ago
                          RX/TX seq numbers: 20017/20017
                          SPI underruns 0, overruns 0
                          Number of disconnects: 0, IAP RAM available 0x2c884
                          Buffer RX/TX: 72/352-0
                          === Duet Control Server ===
                          Duet Control Server v3.2.2
                          HTTP:
                          Buffered code: M116 ;Wait for heater teamps
                          Buffered code: G28 ;Home
                          Buffered code: G28
                          Buffered code: G29 ;Auto Compensation
                          Buffered code: G0 X-100 U400 Y-100 Z25 F6000 ;Go here, this fast
                          Buffered code: G10 P0 R130 S200
                          Buffered code: M140 R60 S70
                          Buffered code: M290 S-0.10 ;Baby Stepping
                          ==> 280 bytes
                          Executing macro 0:/macros/Auto Ready Printer, started by M98 P"0:/macros/Auto Ready Printer"
                          > Next stack level
                          Pending code: T-1
                          Pending code: T-1
                          Code buffer space: 3744
                          Full transfers per second: 0.50
                          Maximum length of RX/TX data transfers: 3024/960
                          ok
                            What are the responses if you send M308 S0 and then M950 H0 ?
                            What does M122 B10 respond with this time?
                            • BlueDustundefined
                              BlueDust @dc42
                              Trying to send M308 S0... Waited a few minutes and it still hasn't completed.
                              M122 B10
                              Never used RAM 4012, free system stack 96 words
                              HEAT 90 CanAsync 89 CanRecv 83 TMC 54 MAIN 218 AIN 64
                              Last reset 02:30:32 ago, cause: power up
                              Driver 0: position 0, 830.9 steps/mm, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 13, reads 59793, writes 13, timeouts 0, DMA errors 0
                              Moves scheduled 0, completed 0, in progress 0, hiccups 0
                              No step interrupt scheduled
                              VIN: 23.8V
                              MCU temperature: min 20.7C, current 36.2C, max 36.6C
                              Ticks since heat task active 39, ADC conversions started 8996572, completed 8996571, timed out 0
                              Last sensors broadcast 0x00000001 found 1 42 ticks ago, loop time 0
                              CAN messages queued 108066, send timeouts 0, received 81195, lost 0, free buffers 36
                              ok
                                Try reloading DWC (i.e. browser tab refresh), then send the M308 command again.
                                • BlueDustundefined
                                  BlueDust @dc42
                                  No change.
