    DWC 3.1.1
    Duet Web Control
    6.1k
    • luca Massimilianoundefined
      luca Massimiliano
        luca Massimiliano
        ORA OK , MANCA IL SECONDO RISCALDATORE , SONO NOMINITA 0 E 1 ANCHE REPETIER LI NOMINA COSI' E NON SETE LA TEMPERATURA DEL PRIMO RISCALDATORE . HO RISOLTO GRAZIE A TE LA VERSIONE TE NE SONO GRATO MA NON CAPISCO PERCHE' FUNZIONA SOLO CON JAVA.
        1 IL PRIMO RISCALDATORE ASSENE
        2 PERCHE' JAVA ?
          luca Massimiliano
            luca Massimiliano
              luca Massimiliano
              M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
              M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
              M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
              M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
              M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
              M143 H2 S280 ; set temperature limit for heater 2 to 280C
                Post the full contents of your config.g
                Java is required for it to work. That's just the way it's made.
                luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
                  luca Massimiliano
                  SCUSA AMICO , NON HO CAPITO COSA DEVO FARE
                    luca Massimiliano @Phaedrux
                    ; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 16:02:24 GMT+0100 (Ora standard dell’Europa centrale)
                    M550 P"TATONA" ; set printer name
                    M665 R165.29 L334 B130 H501.5 ; Set delta radius, diagonal rod length, printable radius and homed height
                    M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
                    M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
                    M552 S1 ; enable network
                    M586 P0 S1 ; enable HTTP
                    M586 P1 S0 ; disable FTP
                    M586 P2 S0 ; disable Telnet
                    M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
                    M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
                    M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
                    M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
                    M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
                    M84 S30 ; Set idle timeout
                    M208 Z-0.1 S1 ; set minimum Z
                    M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
                    M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
                    M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop
                    M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
                    M558 P9 C"^zprobe.in" H10 F120 T2400 ; set Z probe type to bltouch and the dive height + speeds
                    M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
                    G31 P500 X11 Y0 Z2 ; set Z probe trigger value, offset and trigger height
                    M557 R130 S20 ; define mesh grid
                    M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off
                    M563 P1 S"1" D0 H1 F0 ; define tool 1
                    ; Custom settings
                    m501
                      Phaedrux Moderator @luca Massimiliano
                      @luca-Massimiliano said in DWC 3.1.1:
                      You only have one tool defined, so only one tool will show in the web interface.
                      You have the heater configured, but it needs to be associated with a tool to be controlled.
                        luca Massimiliano
                        GRAZIE VERAMENTE PRECISO E PREPARATISSIMO FUNZIONA , (NON HO PROVATO L ESTRUSIONE PER ORA)
                        HO UN PROBLEMA INVECIE PanelDue Firmware. CON QUALE Firmware DIVENTA COMPATIBILE?
                          What version of firmware is on the PanelDue? Check in the Setup page on the Panel.
                          It should be at least 1.24
                          https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
                          What baud rate is it set to? It should be 57600 to match what you have set in config.g
                            luca Massimiliano
                              Your baud rate doesn't match. In PanelDue it shows 115200 baud. Press that button until it shows 57600.
                                luca Massimiliano
                                GRANDIOSO I BAUD GRAZIE MILLE . SONO A BUON PUNTO DIREI COME POSSO RICAMBIARE IL TUO ENORME AIUTO
                                  luca Massimiliano
                                  NON HO FATTO CON A NUOVA CONFIGURAZIONE SONDAGGIO AUTOMATICO . IO HO UNA DELTA KOSSEL CIRCOLARE E RIPORTA I VALORI APPROSIMATICI E NORMALE CHE USI UNA BASE QUADRATA? SCUSA NON VORREI AVER DIMETICATO DELLE CONFIGURAZIONI.37d73ebb-0588-46af-8e97-7f30d097d871-image.png
                                    https://duet3d.dozuki.com/Wiki/ConfiguringRepRapFirmwareDeltaPrinter
                                    https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer
                                      luca Massimiliano
                                      CIAO
                                      non ho mai capito una cosa :
                                      perche' se MODIFICO IL VALORE NEL CONFIG .G DI H506.5 NON CAMBIA MAI E DEVO CAMBIARLO SU RepRapFirmware Configuration Tool ?
                                      M665 R165.29 L334 B130 H506.5 ; Set delta radius, diagonal rod length, printable radius and homed height
                                        I think that would be handled with delta calibration. I'm not very savvy with deltas, but those two links to configure and calibrate should get you going.
                                          luca Massimiliano
                                          SI HAI RAGIONE POSSO CAMBIARLO SOLO CON Configuration Tool MA LO CALCOLCO PRIMA MEDIANTE I SOLITI SISEMI , MA SOLO Configuration Tool RIESCE A SALVARE IL VALORE ,IL CHE RENDE TUTTO MOLTO PIU' LABORIOSO, GRAZIE
                                            Just edit the config.g file in the web interface. It's in the system tab. You do not need to go back to the configuration tool every time.
