DWC 3.1.1
Post the full contents of your config.g
Java is required for it to work. That's just the way it's made.
SCUSA AMICO , NON HO CAPITO COSA DEVO FARE
; generated by RepRapFirmware Configuration Tool v3.2.2 on Wed Jan 20 2021 16:02:24 GMT+0100 (Ora standard dell’Europa centrale); General preferences
M550 P"TATONA" ; set printer name
M665 R165.29 L334 B130 H501.5 ; Set delta radius, diagonal rod length, printable radius and homed height
M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them; Network
M540 PBE:EF:DE:AD:FE:ED ; set custom MAC address
M552 S1 ; enable network
M586 P0 S1 ; enable HTTP
M586 P1 S0 ; disable FTP
M92 X80.00 Y80.00 Z80.00 E663.00 ; set steps per mm
M566 X1200.00 Y1200.00 Z1200.00 E1200.00 ; set maximum instantaneous speed changes (mm/min)
M203 X18000.00 Y18000.00 Z18000.00 E1200.00 ; set maximum speeds (mm/min)
M201 X1000.00 Y1000.00 Z1000.00 E1000.00 ; set accelerations (mm/s^2)
M906 X1000 Y1000 Z1000 E800 I30 ; set motor currents (mA) and motor idle factor in per cent
M208 Z-0.1 S1 ; set minimum Z; Endstops
M574 X2 S1 P"xstop" ; configure active-high endstop for high end on X via pin xstop
M574 Y2 S1 P"ystop" ; configure active-high endstop for high end on Y via pin ystop
M574 Z2 S1 P"zstop" ; configure active-high endstop for high end on Z via pin zstop; Z-Probe
M950 S0 C"exp.heater7" ; create servo pin 0 for BLTouch
M558 P9 C"^zprobe.in" H10 F120 T2400 ; set Z probe type to bltouch and the dive height + speeds
M558 H30 ;*** Remove this line after delta calibration has been done and new delta parameters have been saved
G31 P500 X11 Y0 Z2 ; set Z probe trigger value, offset and trigger height
M557 R130 S20 ; define mesh grid; Heaters
M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
M143 H2 S280 ; set temperature limit for heater 2 to 280C; Fans
M106 P1 S1 H-1 ; set fan 1 value. Thermostatic control is turned off; Tools
M563 P1 S"1" D0 H1 F0 ; define tool 1
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0C; Custom settings
m501; Miscellaneous
M501 ; load saved parameters from non-volatile memory -
@luca-Massimiliano said in DWC 3.1.1:
G10 P1 R0 S0 ; set initial tool 1 active and standby temperatures to 0CYou only have one tool defined, so only one tool will show in the web interface.
You have the heater configured, but it needs to be associated with a tool to be controlled.
GRAZIE VERAMENTE PRECISO E PREPARATISSIMO FUNZIONA , (NON HO PROVATO L ESTRUSIONE PER ORA)
HO UN PROBLEMA INVECIE PanelDue Firmware. CON QUALE Firmware DIVENTA COMPATIBILE? -
What version of firmware is on the PanelDue? Check in the Setup page on the Panel.
It should be at least 1.24
https://duet3d.dozuki.com/Wiki/PanelDue_Firmware_update
What baud rate is it set to? It should be 57600 to match what you have set in config.g
3.28
Your baud rate doesn't match. In PanelDue it shows 115200 baud. Press that button until it shows 57600.
GRANDIOSO I BAUD GRAZIE MILLE . SONO A BUON PUNTO DIREI COME POSSO RICAMBIARE IL TUO ENORME AIUTO
NON HO FATTO CON A NUOVA CONFIGURAZIONE SONDAGGIO AUTOMATICO . IO HO UNA DELTA KOSSEL CIRCOLARE E RIPORTA I VALORI APPROSIMATICI E NORMALE CHE USI UNA BASE QUADRATA? SCUSA NON VORREI AVER DIMETICATO DELLE CONFIGURAZIONI.
CIAO
non ho mai capito una cosa :
perche' se MODIFICO IL VALORE NEL CONFIG .G DI H506.5 NON CAMBIA MAI E DEVO CAMBIARLO SU RepRapFirmware Configuration Tool ?
M665 R165.29 L334 B130 H506.5 ; Set delta radius, diagonal rod length, printable radius and homed height -
I think that would be handled with delta calibration. I'm not very savvy with deltas, but those two links to configure and calibrate should get you going.
SI HAI RAGIONE POSSO CAMBIARLO SOLO CON Configuration Tool MA LO CALCOLCO PRIMA MEDIANTE I SOLITI SISEMI , MA SOLO Configuration Tool RIESCE A SALVARE IL VALORE ,IL CHE RENDE TUTTO MOLTO PIU' LABORIOSO, GRAZIE
Just edit the config.g file in the web interface. It's in the system tab. You do not need to go back to the configuration tool every time.
I DO NOT UNDERSTAND n the web interface.
Plugins tab (built-in) HEIGHT MAP = START OK CAMBIA H TOTAL DOPO RIAVVIO MA USANDO M665 H565.85 NON CONFIG.G TUTTO BENE . UNA COSA CHE NON CAPISCO E' PERCHE' L ALTEZZA IMPOSTATA NON E' UGUALE ALLA HOM HO PENSATO AL DISTIAMENTO IMPOSTATO SUI FINE CORSA ALTI . TI RINGRAZIO ANCORA HO RISOLTO UN SACCO DI PROBLEMI GRAZIE A TE
mi da questo errore , ma il comando viene ,fatto dalla macchina
g 30 g30
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)
