    G29S1 not loading during print and G32 not leveling properly
    IR Height Sensor
    2.4k
      Phaedrux Moderator @moe.adams9093
      @moe-adams9093 said in G29S1 not loading during print and G32 not leveling properly:
      Bed compensation in use: mesh
      So it is active.
      If you put a piece of tape on the Z axis motor shafts or lead screw do you see it move during the first layer?
      moe.adams9093undefined 1 Reply Last reply Reply Quote 0
      • moe.adams9093undefined
        moe.adams9093 @Phaedrux
        I took the bottom plate off to see if my Z motors are compensating and they do move but they move very slow so I don't know if there's an option where I can make my Zmotors to compensate equivalent with the same speed of the X&Y axis while printing
          Your Z accelerations are very slow. M201 Z80 but the jerk is very high. M566 Z800. Try swapping those two values.
          Such a high jerk is making the firmware think the z axis is able to keep up to rapid changes in z position, but it can't actually. So the z movement is probably lagging behind where it thinks it is.
            moe.adams9093
            Ok I will try to change these settings and see how’s it going to behavior. Thank you
              How is the Z axis setup? What kind of speeds can we realistically expect from it?
                moe.adams9093
                the Zaxis runs by 4 gearbox motors belt-driven. Expecting 100mm high-quality print speed
                  Did swapping those values help?
                    moe.adams9093
                    Yes it did little bit I also ran a quick print test and the results not really promising. Looks like some vibration issues from the X&Y Im note sure if it’s my external driver or maybe my linear rail. 2D8E8A6C-B11F-458A-920B-A18DECB57192.jpeg 980EAAA2-9104-4FA3-812B-2DBFD261EC5E.jpeg 02A225C9-B0A1-498A-8A0C-6C43D596F17C.jpeg
                      M566 X10000 Y10000
                      your jerk on the X and Y is insanely high. Try reduce that to 1000.
                        moe.adams9093
                        Ok I will do that over the weekend do you have any resources regarding the T parameters for external driver I need to understand what each number represent and how it can affect. I’m using theses motors they are Nema 23 with integrated rotary encoder. I order today RS232 Cable so I can connect them to my pc and se if I can change so of the settings to match with my config.g FAB41018-5AE5-486D-A777-2C06BCCAFC18.jpeg 807FEEA7-F873-4A87-8927-3B3837D69D1A.jpeg . Thanks for all your help I really appreciate it
                        • fcwiltundefined
                          fcwilt @moe.adams9093
                          @moe-adams9093
                          If you do not have the specs for those drivers try T2:2:10:10 for starters.
                            moe.adams9093
                            So I did some lots of tweaking and here some results for a first full print it’s ABS print speed 3600mm/min Zaxis at 600mm/min print size 40x40x40 simplify 3D gave 1:18 hr/min estimate print time and it took about 1:40 hr/min. Bedtemp set at 100C and extruded at 235C But the quality is awful.
                            Here’s my new motor settings.
                            M569 P10  R1  T3:3:6:10 S1   ; physical drive 0 goes forwards
                            M569 P11  R1  T3:3:6:10 S1   ; physical drive 1 goes forwards
                            M569 P3 S1                                             ; physical drive 3 goes forwards
                            M569 P4 S0                                               ; physical drive 4 goes forwards
                            M569 P5 S1                                               ; physical drive 5 goes Backwards
                            M569 P6 S1 ; physical drive 6 goes Backwards
                            M569 P8 S1           ; physical drive 7 goes Backwards
                            M569 P2 S1                                               ; physical drive 9 goes backwards
                            M584 X10 Y11 Z5:6:8:2 E3:4                               ; set drive mapping
                            M671 X50.0:480.0:480.0:50.0 Y50.0:50.0:460.0:460.0 S5   ; ZBelts Near Locations
                            M350 X16 Y16 Z16 E16:16 I1                               ; configure microstepping with interpolation
                            M92 X160 Y160 Z412.00 E420.00:420.00 ; set steps per mm
                            M566 X500 Y500 Z60 E500:500               ; set maximum instantaneous speed changes (mm/min)
                            M203 X6000 Y6000 Z800 E6000:6000     ; set maximum speeds (mm/min)
                            M201 X1000 Y1000 Z400 5000:5000     ; set accelerations (mm/s^2)
                            M906 X2600 Y2600 Z1100 E800:800 I30                     ; set motor currents (mA) and motor idle factor in per cent
                            M84 S30                                                 ; Set idle timeout
                            Here’s a picture of the actual print.
                            1FC79C11-5292-40AB-9769-5D08AA07FC15.jpeg C1C7AA38-AACA-4DC9-853E-50643010BC50.jpeg 81B5C307-93AF-47C0-AAC4-6BE85FF12D24.jpeg 1C372A95-0AF7-4E4D-B37E-11FB0902623B.jpeg
                            Even with that low jerk settings the printer is shaking from the external driver. Printer weights about 270 Ib I don’t know if I need to go lower value on any of the settings or maybe the external driver not override Correct value from the config. G file or any other suggestions
                              You're missing an E on the extruder values.
                              Can you send M98 P"config.g" and post any errors that come up?
                                moe.adams9093
                                3/17/2021, 2:10:30 PM	M98 P"config.g"
                                HTTP is enabled on port 80
                                FTP is disabled
                                TELNET is disabled
                                this is before I changed it didn't give me any error.
                                  I think it may have messed up your expected Z and E accelerations. With the E missing you could send M201 by itself to see what it reports as the current values.
                                    moe.adams9093
                                    ok I'm going to run another test and see the results. thank you
