help with config.g
1.4k
    jay_s_uk @patterson6
    @patterson6 said in help with config.g:
    @jay_s_uk
    tried both 0 and 1 no go...
    ;****************************************** Hotend ********************************************************************
    M308 S1 P"spi.cs0" Y"rtd-max31865" ; configure sensor 0 as thermistor // Smart effector // pt 100 // on daugherboard
    M950 H0 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
    M307 H0 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
    M143 H0 S380 ; set temperature limit for heater 0 to 380C
    you should be using H1 rather H0 otherwise the heater won't be created correctly for the tool
    undefined 1 Reply Last reply 12 Mar 2021, 16:33 Reply Quote 0
      patterson6 @Veti
      @Veti what do you mean its not a result of a delta calibration? what am i missing? Where would the M501 go? Yeah i didnt pid tune anything yet. Just trying to get it all working first. I am not great with Gcode.
      undefined 1 Reply Last reply 12 Mar 2021, 14:00 Reply Quote 0
        Veti @patterson6
        @patterson6
        please read https://duet3d.dozuki.com/Wiki/Calibrating_a_delta_printer#Section_Auto_calibration
          patterson6 @jay_s_uk
          @jay_s_uk what does the S do in M308? reprap says sensor number but idk whats what. i was just matching the heater number. also still dont work. i tried both spi.cs1 and spi.cs0
          ;HEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERSHEATERS
          M308 S3 P"spi.cs1" Y" rtd-max31865" ; define temperature sensor number 3 as a PT100 on the first port of a temperature daughter board plugged into mainboard
          M950 H1 C"out1" T0 ; create nozzle heater output on out1 and map it to sensor 0
          M307 H1 A498.0 C324.4 D4.2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
          M143 H1 S350 ; set temperature limit for heater 0 to 350C
          ;****************************************** Chamber/Radiator heater ****************************************************
          M308 S1 P"temp2" Y"thermistor" T50000 B3950 ; configure sensor 1 as thermistor on pin temp2 two sensors wired together
          M570 H0 P10000 T15 ; Set heater fault detection for out 3, 1,000 second anomaly, 10c excursion
          M950 H0 C"out3" T1 ; create chamber heater output on out3 and map it to sensor 1
          M307 H0 A72.0 C71.5 D1.4 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
          M141 H0 ; map chamber to heater 1
          M143 H0 S90 ; set temperature limit for heater 1 to 90C
          ***************************************** Bed Heater ****************************************************************
          M308 S2 P"temp0" Y"thermistor" T100000 B4138 ; configure sensor 2 as thermistor on pin temp0
          M950 H2 C"out0" T2 ; create bed heater output on out0 and map it to sensor 2
          M307 H2 A183.1 C1561.5 D.7 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
          M140 H2 ; map heated bed to heater 2
          M143 H2 S120 ; set temperature limit for heater 2 to 120C
            Here's what a sane setup for heaters looks like right out of the config tool.
            M308 S0 P"temp0" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
            M950 H0 C"out0" T0                           ; create bed heater output on out0 and map it to sensor 0
            M307 H0 B0 S1.00                             ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                      ; map heated bed to heater 0
            M143 H0 S120                                 ; set temperature limit for heater 0 to 120C
            M308 S1 P"spi.cs0" Y"rtd-max31865"           ; configure sensor 1 as thermocouple via CS pin spi.cs0
            M950 H1 C"out1" T1                           ; create nozzle heater output on out1 and map it to sensor 1
            M307 H1 B0 S1.00                             ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S280                                 ; set temperature limit for heater 1 to 280C
            M308 S2 P"temp1" Y"thermistor" T100000 B3950 ; configure sensor 2 as thermistor on pin temp1
            M950 H2 C"out2" T2                           ; create chamber heater output on out2 and map it to sensor 2
            M307 H2 B0 S1.00                             ; disable bang-bang mode for the chamber heater and set PWM limit
            M141 H2                                      ; map chamber to heater 2
            M143 H2 S280                                 ; set temperature limit for heater 2 to 280C
            I didn't duplicate your fans or tools though.
            undefined 1 Reply Last reply 13 Mar 2021, 22:56 Reply Quote 1
              patterson6 @Phaedrux
              @Phaedrux I found that at the bottom H1 was not declared under tools. So now my hotend pops up on dwc but under current for temp i am reading 2000.0c before it was just n/a. so then i changed the spi.cs0 to spi.cs1 even spi.cs2 even spi.cs3. nothing worked and all said 2000c. I checked all my connections and everything seems right.
              The bright side my expansion board came today and i wired up the rgb led and found the extension on the out.6 pin just need an 1.out.6. So those work and i also added some more thermistors in extra. Pretty cool. I wish the trend chart was bigger.
              ;NETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORKNETWORK***NETWORK
              M586 P0 S1 ; enable HTTP
              M586 P1 S0 ; disable FTP
              M586 P2 S0 ; disable Telnet
              ;GENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCESGENERAL PREFERENCES
              M550 P"Duet 3" ; set printer name
              M665 R316 L616.42 B215 H989.4 ; Set delta radius, diagonal rod length, printable radius and homed height
              M666 X0 Y0 Z0 ; put your endstop adjustments here, or let auto calibration find them
              ;DRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVESDRIVES
              ;X,Y,Z stepper motors 23HM22-2804S https://www.omc-stepperonline.com/nema-23-bipolar-0-9deg-1-26nm-178-4oz-in-2-8a-2-5v-57x57x56mm-4-wires.html
              ;E steper motor 42BYGHW811 on Nimble 2
              M569 P0.3 S0 ; physical drive 0.3 goes backwards
              M584 X0.0 Y0.1 Z0.2 E0.3 ; set drive mapping
              M350 X64 Y64 Z64 E16 I1 ; configure microstepping with interpolation
              M92 X640.00 Y640.00 Z640.00 E1775.00 ; set steps per mm
              M566 X72000.00 Y72000.00 Z72000.00 E2400.00 ; set maximum instantaneous speed changes (mm/min)
              M203 X330000.00 Y330000.00 Z330000.00 E216000.00 ; set maximum speeds (mm/min)
              M201 X5400.00 Y5400.00 Z5400.00 E120.00 ; set accelerations (mm/s^2)
              M906 X2800 Y2800 Z2800 E1800 I40 ; set motor currents (mA) and motor idle factor in per cent
              M84 S30 ; Set idle timeout
              ;AXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITSAXIS LIMITS***AXIS LIMITS
              M208 Z0 S1 ; set minimum Z
              ;ENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPSENDSTOPS***ENDSTOPS
              M574 X2 S1 P"io0.in" ; configure active-high endstop for high end on X via pin io0.in
              M574 Y2 S1 P"io1.in" ; configure active-high endstop for high end on Y via pin io1.in
              M574 Z2 S1 P"io2.in" ; configure active-high endstop for high end on Z via pin io2.in
              ;Z-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBEZ-PROBE
              M558 P5 R0.4 C"io3.in+io3.out" H5 F500 T1500 ; set Z probe type to effector and the dive height + speeds
              G31 P100 X0 Y0 Z4 ; set Z probe trigger value, offset and trigger height
              M557 R215 S25 ; define mesh grid
              M308 S1 P"spi.cs0" Y"rtd-max31865" A"Hotend" ; define temperature sensor number 1 as a PT100 on the first port of a temperature daughter board plugged into mainboard
              M143 H1 S280 ; set temperature limit for heater 0 to 280C
              M308 S2 P"temp2" Y"thermistor" A"Radiator" T50000 B3950 R2300 ; configure sensor 2 as thermistor on pin temp2 two sensors wired parallel
              M570 H2 P10000 T15 ; Set heater fault detection for out 3, 1,000 second anomaly, 10c excursion
              M950 H2 C"out3" T2 ; create chamber heater output on out3 and map it to sensor 2
              M307 H2 A72.0 C71.5 D1.4 B0 S1.00 ; disable bang-bang mode for the chamber heater and set PWM limit
              M143 H2 S90 ; set temperature limit for heater 2 to 90C
              M308 S0 P"temp0" Y"thermistor" A"Bed" T100000 B3950 ; configure sensor 0 as thermistor on pin temp0
              M307 H0 A183.1 C1561.5 D.7 B0 S1.00 ; disable bang-bang mode for the bed heater and set PWM limit
              M143 H0 S120 ; set temperature limit for heater 2 to 120C
              ;EXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRASEXTRAS
              ;****************************************** Recirc air temp from hepa ****************************************************
              M308 S5 P"temp3" Y"thermistor" A"Filter air temp" T100000 B3950 R2500 ; configure sensor 5 as thermistor on pin temp3
              ;****************************************** MCU Temp *****************************************************************
              M308 S6 Y"mcu-temp" A"MCU" ; configure sensor 6 as mcu temp on motherboard
              ;****************************************** Air temp above effector ****************************************************
              M308 S7 P"temp1" Y"thermistor" A"Effector air temp" T100000 B3950 ; configure sensor 6 as thermistor on pin temp3
              ;COOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLINGCOOLING
              ;****************************************** Water pump for hotend ****************************************************
              M950 F0 C"out5" Q500 ; create fan 0 on pin out5 and set its frequency
              M106 P0 C"water pump " S1 H1:1 T35 ; set fan 0 name and value. Thermostatic control is turned on
              ;****************************************** Chamber fan blowing on radiator*******************************************
              M950 F1 C"out8" Q500 ; create fan 1 on pin out8 and set its frequency
              M106 P1 C"radiator fan" S1 H1:1 T35 ; set fan 1 name and value. Thermostatic control is turned on
              ;****************************************** Recirc/hepa filter fan ****************************************************
              M950 F2 C"out7" Q500 ; create fan 2 on pin out7 and set its frequency
              M106 P2 C"recirc/hepa fan" S1 H1:1 T35 ; set fan 2 value. Thermostatic control is turned on
              ;****************************************** Berd air ******************************************************************
              M950 F3 C"out4" Q500 ; create fan 3 on pin out4 and set its frequency
              ;M106 P3 C"berd air" S1 H3 T35 ; set fan 3 value. Thermostatic control is turned on // Not needed at this time
              ;LEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLEDLED
              ;***************************************** RGBW led strip on build area **********************************************
              M950 F4 C"out9" ; create white led on mainboard pin out9
              M950 F5 C"1.out6" ; create red led on expansion pin out 6
              M950 F6 C"1.out7" ; create green led on expansion pin out 7
              M950 F7 C"1.out8" ; create blue led on expansion pin out 8
              ;TOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLSTOOLS***TOOLS
              ;MiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneousMiscellaneous
              undefined 1 Reply Last reply 13 Mar 2021, 23:48 Reply Quote 0
                Phaedrux Moderator @patterson6
                Photo of your wiring at the daughterboard?
                undefined 1 Reply Last reply 14 Mar 2021, 00:18 Reply Quote 0
                  from the duet 2 to duet 3 the rest of the hardware has been untouched. Its been a year but i think the pt100 was working at that time.
                    Can you get a closer show of the daughterboard itself? Can you remove it and reseat it?
                    undefined 1 Reply Last reply 14 Mar 2021, 00:24 Reply Quote 0
                      @Phaedrux i removed it and checked the pins. seems to be seated properly. i have an extra smart effector i can try that i guess. if not i can buy another pt100. seems more like software.
                        Can you do this test on the daughterboard?
                        https://duet3d.dozuki.com/Wiki/Connecting_PT100_temperature_sensors#Section_To_test_the_functionality_of_one_of_the_PT100_channels
                        undefined 2 Replies Last reply 14 Mar 2021, 00:28 Reply Quote 0
                          @Phaedrux pretty sure i can. give me a little bit
                            @Phaedrux so i found a 100ohm in my bin and wired it up. On channel P"spi.cs0". I am now getting 4.3c on the hotend. So i am going to put in the new smart effector when i can and order a new pt100 to be safe. thanks
                              The daughter board comes with a 100Ω resistor that you can wire in place of a two wire sensor to check the board is working correctly. With the resistor in place, the reading should be 0°C.
                              If the reading at room temperature is higher than it should be, then you probably have a bad connection between the RTD interface board and the sensor, or the wires to the sensor are too long or too thin. Each additional ohm of wiring resistance will increase the temperature reading by 2.5C. Using a 4 wire solution PT100 sensor will improve this. If you only have a 2 wire P100 sensor you can still improve the accuracy by using 4 wires for the majority of the distance
                              undefined 1 Reply Last reply 24 Mar 2021, 14:21 Reply Quote 0
                                @Phaedrux You mind checking my starting and ending scripts? The starting script seems to work like it should. let me know if you see anything out of place or odd. The ending script does not work like it really should. One of the main problems was the color Teal would not even show in the cool down period. It would just go to green as showing finished.
                                starting script
                                ;*********************************** RED HEATING UP ********************************************
                                M106 P4 S0.0 ; Turn off white led
                                M106 P5 S1.0 ; Turn on red led
                                M106 P6 S0.0 ; Turn off green led
                                M106 P7 S0.0 ; Turn off blue led
                                G21 ; Set Units to Millimeters
                                G90 ; Set to Absolute Positioning
                                M82 ; Set extruder to absolute mode
                                G28 ; Home
                                M400 ; Finish all moves above first
                                M104 S140 ; Set extruder temperature
                                M141 H2 S70 ; Set chamber radiator temperature
                                ;M141 H2 S35 ; Set chamber recirc temperature *not in use at this time
                                M191 P70 ; Wait for chamber temperature to reach target temp
                                M109 S140 ; Wait for extruder temperature to reatch target temp
                                M400 ; Finish all moves above firrst
                                ;********************************** PURPLE * PRE HEATED and START CALI * **************************
                                M106 P7 S1.0 ; Turn on blue to make purple
                                G32 ; Auto Calibration
                                ;********************************** ORANGE Achieve final temps * ***********************************
                                M106 P6 S0.06 ; Turn on green led 6% to make orange
                                M104 S[extruder0_temperature] T0 ; Set extruder temperature
                                M109 S[extruder0_temperature] T0 ; Set extruder temperature to first layer temp
                                ;*********************************** WHITE * START PRINT* *****************************************
                                M106 P4 S1.0 ; Turn on white led
                                M106 P5 S0.0 ; Turn off red led
                                ending script
                                G28 ; Move home
                                M104 S0 ; Cool the extruder
                                M106 P3 S0.0 ; Turn off berd-air
                                ;*********************************** TEAL COOLING OFF *********************************************
                                M106 P6 S1.0 ; Turn on green led
                                M106 P7 S1.0 ; Turn on blue led
                                M191 S35 ; Wait for chamber temperature to reach target temp
                                M190 S35 ; Wait for bed temperature to reach target temp
                                M140 S0 ; Turn off bed
                                M141 H2 S0 ; Turn off chamber radiator
                                ;M141 H2 S0 ; Turn off chamber recirc heater *not in use at this time
                                ;*********************************** GREEN FINISHED **********************************************
                                M84 ; Disable motors
                                ;end
                                undefined 1 Reply Last reply 24 Mar 2021, 21:35 Reply Quote 0
                                  It's probably ignoring these commands because the target temp is too low.
                                  Note: M190 will not wait for temperatures below 40c because in many cases they may never be reached due to ambient temps. So if you want to wait for a bed to cool, use 41c or higher.
                                  This goes for all the other heater commands as well.
                                  undefined 1 Reply Last reply 2 Apr 2021, 15:15 Reply Quote 0
                                    @phaedrux
                                    ok so i really haven't been able to print anything yet. The problem i am having is the nozzle is pushing down on the bed at the start of the print. Added 2mm to Z-axis in S3D and im still getting the same effect. I tried just using auto cali, mesh and then both and same results in starting script. When i G32 i M500 and saved the info to config override. The height map is mostly green with a touch of blue after G29. Im not great at this part. What would you need to see to help me?
                                    Back on the duet 2 i had this bad boy printing anywhere with no prob using mesh. I dont have a mesh.g. Do i need one? Thanks
                                      Let's see your bed.g, homedelta.g for starters.
                                      undefined 2 Replies Last reply 2 Apr 2021, 15:57 Reply Quote 0
                                        This post is deleted!
                                          @phaedrux
                                          ; bed.g
                                          ; called to perform automatic delta calibration via G32
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Feb 28 2021 07:03:53 GMT-0600 (Central Standard Time)
                                          ; bed.g file for RepRapFirmware, generated by Escher3D calculator
                                          ; 16 points, 6 factors, probing radius: 215, probe offset (0, 0)
                                          G28
                                          G30 P0 X0.00 Y215.00 Z-99999 H0
                                          G30 P1 X138.20 Y164.70 Z-99999 H0
                                          G30 P2 X211.73 Y37.33 Z-99999 H0
                                          G30 P3 X186.20 Y-107.50 Z-99999 H0
                                          G30 P4 X73.53 Y-202.03 Z-99999 H0
                                          G30 P5 X-73.53 Y-202.03 Z-99999 H0
                                          G30 P6 X-186.20 Y-107.50 Z-99999 H0
                                          G30 P7 X-211.73 Y37.33 Z-99999 H0
                                          G30 P8 X-138.20 Y164.70 Z-99999 H0
                                          G30 P9 X0.00 Y107.50 Z-99999 H0
                                          G30 P10 X93.10 Y53.75 Z-99999 H0
                                          G30 P11 X93.10 Y-53.75 Z-99999 H0
                                          G30 P12 X0.00 Y-107.50 Z-99999 H0
                                          G30 P13 X-93.10 Y-53.75 Z-99999 H0
                                          G30 P14 X-93.10 Y53.75 Z-99999 H0
                                          G30 P15 X0 Y0 Z-99999 S6
                                          ; homedelta.g
                                          ; called to home all towers on a delta printer
                                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Sun Feb 28 2021 07:03:54 GMT-0600 (Central Standard Time)
                                          G91 ; relative positioning
                                          G1 H1 X1200 Y1200 Z1200 F2200 ; move all towers to the high end stopping at the endstops (first pass)
                                          G1 H2 X-5 Y-5 Z-5 F1800 ; go down a few mm
                                          G1 H1 X10 Y10 Z10 F360 ; move all towers up once more (second pass)
                                          G1 Z-5 F6000 ; move down a few mm so that the nozzle can be centred
                                          G90 ; absolute positioning
                                          G1 X0 Y0 F6000 ; move X+Y to the centre
