    Duet 6HC bed heater with SSR
    881
    • daniundefined
      dani
      @droftarts
      3/16/2021, 1:20:39 PM m122
      RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 version 3.01-RC2 running on Duet 3 MB6HC
      Board ID: 08DJM-956L2-G43S8-6JTD4-3S06M-TA22D
      Used output buffers: 1 of 40 (10 max)
      Static ram: 153912
      Dynamic ram: 159032 of which 44 recycled
      Exception stack ram used: 512
      Never used ram: 79716
      Tasks: NETWORK(ready,440) ETHERNET(blocked,328) HEAT(blocked,1120) CanReceiv(suspended,3820) CanSender(suspended,1436) CanClock(blocked,1432) TMC(blocked,76) MAIN(running,4360) IDLE(ready,76)
      Owned mutexes: LwipCore(NETWORK)
      Last reset 00:20:47 ago, cause: software
      Last software reset at 2021-03-16 12:59, reason: User, spinning module GCodes, available RAM 79716 bytes (slot 2)
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0444a000 BFAR 0x00000000 SP 0xffffffff Task 0x4e49414d
      Error status: 0
      Free file entries: 10
      SD card longest block write time: 29.0ms, max retries 0
      MCU temperature: min 35.7, current 36.7, max 36.9
      Supply voltage: min 23.6, current 23.9, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
      12V rail voltage: min 12.0, current 12.1, max 12.2, under voltage events: 0
      Driver 0: standstill, reads 5378, writes 43 timeouts 0, SG min/max 0/448
      Driver 1: standstill, reads 5379, writes 43 timeouts 0, SG min/max 0/416
      Driver 2: standstill, reads 5379, writes 43 timeouts 0, SG min/max 0/280
      Driver 3: standstill, reads 5380, writes 43 timeouts 0, SG min/max 0/241
      Driver 4: standstill, reads 5380, writes 43 timeouts 0, SG min/max 0/1023
      Driver 5: standstill, reads 5413, writes 11 timeouts 0, SG min/max 0/0
      Date/time: 2021-03-16 13:20:37
      Slowest loop: 107.01ms; fastest: 0.12ms
      Hiccups: 0(0), FreeDm: 375, MinFreeDm: 371, MaxWait: 167882ms
      === MainDDARing ===
      === AuxDDARing ===
      Heater 0 is on, I-accum = 0.0
      Heater 1 is on, I-accum = 0.1
      Heater 2 is on, I-accum = 0.1
      Segments left: 0
      Movement lock held by null
      http is idle in state(s) 0
      telnet is idle in state(s) 0
      file is idle in state(s) 0
      serial is idle in state(s) 0
      aux is assembling a command in state(s) 0
      daemon is idle in state(s) 0
      queue is idle in state(s) 0
      lcd is idle in state(s) 0
      spi is idle in state(s) 0
      Code queue is empty.
      === Network ===
      Slowest loop: 207.53ms; fastest: 0.03ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0)
      HTTP sessions: 1 of 8
      • Ethernet -
        State: 5
        Error counts: 0 0 0 0 0
        Socket states: 5 5 2 2 2 0 0 0
        === CAN ===
        Messages sent 5010, longest wait 0ms for type 0
        === Linux interface ===
        State: 0, failed transfers: 0
        Last transfer: 1247403ms ago
        RX/TX seq numbers: 0/1
        SPI underruns 0, overruns 0
        Number of disconnects: 0
        Buffer RX/TX: 0/0-0
      What do you mean by removing the SD card and resetting please? Will I lose all data by doing so? Sorry for asking but I am new to 3D printers.
      Firmware: RepRapFirmware for Duet 3 MB6HC v0.6 or 1.0 3.01-RC2 (2020-02-18b1)
      jay_s_ukundefined droftartsundefined 2 Replies Last reply Reply Quote 0
        jay_s_uk @dani
        @dani just remove the sd card, turn the board on and see if the LED for out0 comes on
        • daniundefined
          dani @dani
          @dani said in Duet 6HC bed heater with SSR:
          @Phaedrux
          With the SSR disconnected as shown in the picture, the LED light still switches on and voltage is 24V across OUT_0.
          When removing the bridging (green wires) the LED switches off and the voltage is 0 across OUT_0 terminals.
          (The SD card is still inside the board)
          @jay_s_uk with the sd card removed I still got the same result as above^
            droftarts administrators @dani
            version 3.01-RC2
            You are running some early firmware, so it's just possible this is a firmware bug. Please can you download the firmware bundle called "Duet2and3Firmware-3.2.2.zip" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2 and upload to the Duet via Duet Web Console > System tab > Upload System Files. This should update the firmware on the board, and DWC. Then check if the Out_0 LED is still on all the time power is applied.
            • daniundefined
              dani
              @droftarts I tried to update the firmware as instructed. I managed to upload the zip file to DWC. I read that I am supposed to be asked to install the firmware. However this did not happen.
                @dani The System page says that the SD card is not mounted; the SD card is needed to save the firmware files, before installing them. I don't think you're running with a Raspberry Pi attached (doesn't say so in M122 response). Did you remove the SD card? If so, put it back in, and send M21 to initialise the SD card, or reset the board. Then re-upload the firmware binary only, this file: "Duet3Firmware_MB6HC.bin" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.2.2
                If it doesn't install, you may need the correct IAP (In-App Programmer) file (which does the job of flashing the firmware) for 3.01-RC2, which I think is: "Duet3iap_sd_MB6HC.bin" from https://github.com/Duet3D/RepRapFirmware/releases/tag/3.0
                Upload that, too. Both files should appear in the sys folder.
                If it doesn't ask you if you want to update the firmware, send M997 S0.
                If you get any errors, or this doesn't work, let me know.
                • daniundefined
                  dani
                  @droftarts thanks a lot for your reply.
                  The SD card was inserted in the board when I uploaded the fzip fila and still is. I have tried to run M21 but DWC seems to keep on buffering and the g-code is not sent. "Drive is unmounted" message is still displayed.
                  What do you mean by reset the board please? Do I need to restart it by switching it off and on again? Or do I need to actually press the reset button on the board?
                    Yes, either of those.
                    • daniundefined
                      dani
                      @droftarts ok so I managed to successfully update the firmware, thanks a lot. However no luck with the heater problem. I am using the wiring as described below. The bed heater still heats up immediately as soon as I switch on the board 😞 any other suggestions of what I can do?
                      I am trying to connect the bed heater using an SSR. The connections so far are as attached below. My problem is that whenever I switch on the power supply, the RED LED of OUT_0 switches on and remains on. Also, the bed heater starts to heat up immediately. Is there someone who can help me with this problem please?
                      I also tried to set a temperature for the bed heater from the interface but the temperature continued increasing beyond this set temperature.
                        @dani Unfortunately, it looks like the bed MOSFET has failed open. Please contact the reseller you bought it from, and initiate a warranty return, using this thread as authorisation. Apologies for the inconvenience.
