    DWC 3.1.1
    Duet Web Control
    6.1k
    • luca Massimilianoundefined
      luca Massimiliano
      COSA USI PER STAMPARE?
        I upload the sliced file directly from the slicer to the Duet over the network.
        luca Massimilianoundefined 1 Reply Last reply Reply Quote 0
          droftarts administrators @luca Massimiliano
          @luca-Massimiliano You upload gcode files to the 'Jobs' screen in DWC, print from there!
          See: https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_Jobs
            luca Massimiliano @Phaedrux
            @Phaedrux said in DWC 3.1.1:
            MI PERDO NELLA TERMINOLOGIA AFFETTAO ? SO CHE SI USA MA NON CAPISCO
              luca Massimiliano @droftarts
              @droftarts STL OK?
                @luca-Massimiliano No. You need to 'slice' the stl first, with something like Cura or PrusaSlicer, to make a gcode file, then upload that. I think Repetier Server does this for you, but then it transfers the gcode to the Duet by USB (or Telnet over Ethernet/WiFi, which should be faster), as it's printing, which can cause pausing problems.
                Most people prefer to have control over the slicing of the stl to gcode, so use a separate program to do this. Repetier Server takes away this control, to make it easier to use. Up to you.
                  luca Massimiliano
                  TI RINGRAZIO MA RIPRENDERO DOPO LA STAMPA DIRETTA
                    luca Massimiliano
                    IL MIO INIZIALE PROBLEMA PRIMA DI ADGIORNARE TUTTA LA MACCHINA COSA CHE SONO CONTENTISSIMO E RINGRAZIO TUTTI MA IN PARTICOLAR MODO PHAEDRUX PHAEDRUX. E' IL SEGUENTE , IL RISCALDATORE T1 NON VIENE RICONOSCIUTO REPETIER NE DA PRONTERFACE ![0_1616086549858_1111111.JPG](Uploading 100%)
                      luca Massimiliano
                      This post is deleted!
                        @leblond are you available for some italian translation? 🙂
                          luca Massimiliano
                          YES
                            luca Massimiliano
                            NON RIESCO INSERIRE PIU' FOTO
                              luca Massimiliano
                              IL RISCALDATORE T1 NON VIENE RICONOSCIUTO DA REPETIER NE DA PRONTERFACE ! ECCO LA FOTO DELLA SCHEDA https://duet3d.dozuki.com/Wiki/Hardware_Overview#Section_Firmware_notes
                              IL RISCALDATORI SONO NOMINATI E1 E0 E BED IN TUTTE LE APPLICAZIONI ,VENGONO NOMINATI E1 E2 E IL BED NOMINATO E0 QUINDI NON VORREI CHE SI CREI UN CONFLITTO ,
                                luca Massimiliano
                                QUI SONO GIUSTI:
                                M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                                M308 S1 P"e0temp" Y"thermistor" T100000 B4388 ; configure sensor 1 as thermistor on pin e0temp
                                M308 S2 P"e1temp" Y"thermistor" T100000 B4388 ; configure sensor 2 as thermistor on pin e1temp
                                M950 H2 C"e1heat" T2 ; create nozzle heater output on e1heat and map it to sensor 2
                                M307 H2 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit
                                M143 H2 S280 ; set temperature limit for heater 2 to 280C
                                  I don't know anything about proterface or repetier. I would suggest you use DWC to interact with the printer.
                                    luca Massimiliano
                                    PER ME NON E' NECESSARIO USARE QUESTE APPLICAZIONI , SOLO CHE VOLEVO FARE UNA PROVA E CON IL NOSTRO DUET NON SO ANCORA USARLO ORA MI METTERO' A STUDIARE E USERO' SOLO DUET . PER LE TRADUZIONI DISONIBILE
                                      This may be your best guide for learning the Duet interface.
                                        luca Massimiliano
                                        grazie 1000
                                          @luca-Massimiliano I think in your config.g you have two tools defined as T0 and T1. Maybe Repetier Server has the first tool as T1, and second tool as T2. So change your config.g so that M563 uses P1 and P2, not P0 and P1. For example:
                                          M563 P1 D0 H1 F0                                ; define tool 1
                                          G10 P1 X0 Y0 Z0                                 ; set tool 1 axis offsets
                                          G10 P1 R0 S0                                    ; set initial tool 1 active and standby temperatures to 0C
                                          M563 P2 D1 H2 F0                                ; define tool 2
                                          G10 P2 X0 Y0 Z0                                 ; set tool 2 axis offsets
                                          G10 P2 R0 S0                                    ; set initial tool 2 active and standby temperatures to 0C
                                            luca Massimiliano
                                            si p0 e p1 viene riconosciuto e letta la sonda ma il comando g10 p1 \p2 devo camiarli in g10 p0 e g10 p1?
