DWC 3.1.1
Do you have a file called mesh.g in the system folder?
no non ho la mesh.g G29 Esegui il file sys / mesh.g, o se quel file non viene trovato, esegui G29 S0 ho fatto cosi errore:
G29 S0
Error: Bad command: Configuration Tool v3.2.3 on Sun Mar 14 2021 01:38:34 GMT+0100 (Ora standard dell’Europa centrale)...ora confronto ifail detti da te config files. config.g homeall.g homex.g homey.g homez.g homedelta.g bed.g deployprobe.g retractprobe.g con i vecchi senza problema se non risolvo li posto ,
@luca-Massimiliano said in DWC 3.1.1:
RISOLTO
COME DICEVI TE NO ERA NASCOSTO NEL FILE DELOYPROBLE.G -
non penso sia correto,
VORREI USARE REPETIER HOST TRAMITE WIFI , NON SO COME FARE , MI PUOI INDIRIZZARE ?
I WOULD LIKE TO USE REPETIER HOST VIA WIFI, I DON'T KNOW HOW TO DO IT, CAN YOU ADDRESS ME?
I do not know how to use repetier host.
COSA USI PER STAMPARE?
I upload the sliced file directly from the slicer to the Duet over the network.
@luca-Massimiliano You upload gcode files to the 'Jobs' screen in DWC, print from there!
See: https://duet3d.dozuki.com/Wiki/Duet_Web_Control_v2_and_v3_(DWC)_Manual#Section_JobsIan
@droftarts STL OK?
@luca-Massimiliano No. You need to 'slice' the stl first, with something like Cura or PrusaSlicer, to make a gcode file, then upload that. I think Repetier Server does this for you, but then it transfers the gcode to the Duet by USB (or Telnet over Ethernet/WiFi, which should be faster), as it's printing, which can cause pausing problems.
Most people prefer to have control over the slicing of the stl to gcode, so use a separate program to do this. Repetier Server takes away this control, to make it easier to use. Up to you.
TI RINGRAZIO MA RIPRENDERO DOPO LA STAMPA DIRETTA
IL MIO INIZIALE PROBLEMA PRIMA DI ADGIORNARE TUTTA LA MACCHINA COSA CHE SONO CONTENTISSIMO E RINGRAZIO TUTTI MA IN PARTICOLAR MODO PHAEDRUX PHAEDRUX. E' IL SEGUENTE , IL RISCALDATORE T1 NON VIENE RICONOSCIUTO REPETIER NE DA PRONTERFACE
This post is deleted! -
@leblond are you available for some italian translation?
NON RIESCO INSERIRE PIU' FOTO
