    Dead duet?
    3.3k
      If the VSSA fusa blows then usually all the thermistors normally show -273C.
      You can test the VSSA fuse by using a multimeter to measure the resistance between the VSSA pin of one of the thermistor connectors, and the ground pin of one of the endstop connectors - with power off, of course.
      Which version Duet WiFi is it? The version number (1.0, 1.01 or 1.02) is printed on the top side of the board.
      • MrBlomundefined
        MrBlom
        its a 1.01
        sorry but can you show exat where to measure and what the correct value is?
        i thinks its a short in the heater that did it
        • MrBlomundefined
          MrBlom
          i found the vssa pin
          what is a good value on the multimeter?
            The resistance should be no more than about 5 ohms.
            • MrBlomundefined
              MrBlom
              seting the multimeter to 200
              and doing the mesaur i have a value of 0.03
              good or bad ?
              soory dont know mush about this
              • MrBlomundefined
                MrBlom
                just tried a new thermistor it get a
                "Temperature reading fault on heater 1: sensor open circuit"
                2000c
                but the rest works , motors ,web ui , fans
                  0.03 ohms sound suspiciously low. Are you measuring between a VSSA pin and a ground pin? Did you disconnect all the thermistors from the Duet first?
                  The "Thermistor open circuit" message is typical of a VSSA fuse failure.
                  The picture at https://duet3d.com/wiki/Connector_and_spare_part_numbers#VSSA_fuse shows a GND pin and a VSSA pin. You can measure the resistance between them, with the thermistors disconnected.
                  • MrBlomundefined
                    MrBlom
                    this good new 🙂 i think
                    i did measure from the top of the board where the thermistor gose in and the vssa on the back
                    igusses that was wrong
                    measuring again from the 2 pins in the picture i have "OL" = broken fuse ?
                    im thinking of doing the
                    "Bypass the original fuse with an external cartridge fuse, fitted between one of the VSSA connections and one of the ground connections."
                    just to dubble check can i use any ground on the board?
                    Thanks dc42 for a fast and grate support
                      Yes you can use any ground, but for the lowest thermistor noise level I suggest you use one of the endstop connector grounds.
                      • MrBlomundefined
                        MrBlom
                        it was the fuse !
                        1000 thansk again for greate support DC42!!!!!
                        • MrBlomundefined
                          MrBlom
                          grrr still broken
                          gose from normal values to 2000 to -2
                          random spikes
                          https://www.dropbox.com/s/1fbatrcs0sx5us9/Screenshot%202017-07-30%2017.14.28.png?dl=0
                          Hmmm may be the fuse holder …..
                            The 2000C spikes suggest a bad connection somewhere.
                            • MrBlomundefined
                              MrBlom
                              yes it was a faluty fuse holder
                              solder it on the holder and now its been stable the last 5 min 🙂
                              thanks again!
                              • MrBlomundefined
                                MrBlom
                                well its just not my week this week 😞
                                run 2 print with out problem
                                one on each extruder
                                after that i tried to start a dual print
                                left the room and came back after 5 min and the duet is dead all light is black
                                and no i cant turn it on by the psu
                                it works by usb but not by normal power
                                i also did see a smal spark by the heater led light in the left corner
                                so my guess this time is that its somthing wrong with the heater
                                can i fix this also ?
                                sorry for being a pain but is just not my lycky week 😞
                                  I'm not sure what you mean by the "left corner" - do you mean the bed heater LED or the E1 heater LED?
                                  See the note at https://duet3d.com/wiki/Mounting_and_cooling_the_board about not using metal washers.
                                  • MrBlomundefined
                                    MrBlom
                                    its E0 heat lead i think
                                    and im not using metal washer
                                    what can i do now to fix this
                                      If all the LEDs on the Duet are off, then no power is reaching the board. Either your PSU has stopped working, or the VIN terminal block screws are no longer tight, or something is shorting the PSU out.
                                      • MrBlomundefined
                                        MrBlom
                                        you have right again 🙂
                                        the psu dont provide 24v any more
                                        thank for the fast support !
                                        • MrBlomundefined
                                          MrBlom
                                          one of the v+ port has gone bad on the psu
                                          the other works finne now
                                          duet is up and runing again
                                          thanks again!
                                          hopfully this is the end for all my problems for now 🙂
                                          • MrBlomundefined
                                            MrBlom
                                            how bad is this ?
                                            Supply voltage: min 20.8, current 23.7, max 24.5, under voltage events: 0, over voltage events: 0
                                            do i need to get a new psu ?
