    Dead duet?
    3.3k
      The resistance should be no more than about 5 ohms.
      • MrBlomundefined
        MrBlom
        seting the multimeter to 200
        and doing the mesaur i have a value of 0.03
        good or bad ?
        soory dont know mush about this
        • MrBlomundefined
          MrBlom
          just tried a new thermistor it get a
          "Temperature reading fault on heater 1: sensor open circuit"
          2000c
          but the rest works , motors ,web ui , fans
            0.03 ohms sound suspiciously low. Are you measuring between a VSSA pin and a ground pin? Did you disconnect all the thermistors from the Duet first?
            The "Thermistor open circuit" message is typical of a VSSA fuse failure.
            The picture at https://duet3d.com/wiki/Connector_and_spare_part_numbers#VSSA_fuse shows a GND pin and a VSSA pin. You can measure the resistance between them, with the thermistors disconnected.
            • MrBlomundefined
              MrBlom
              this good new 🙂 i think
              i did measure from the top of the board where the thermistor gose in and the vssa on the back
              igusses that was wrong
              measuring again from the 2 pins in the picture i have "OL" = broken fuse ?
              im thinking of doing the
              "Bypass the original fuse with an external cartridge fuse, fitted between one of the VSSA connections and one of the ground connections."
              just to dubble check can i use any ground on the board?
              Thanks dc42 for a fast and grate support
                Yes you can use any ground, but for the lowest thermistor noise level I suggest you use one of the endstop connector grounds.
                • MrBlomundefined
                  MrBlom
                  it was the fuse !
                  1000 thansk again for greate support DC42!!!!!
                  • MrBlomundefined
                    MrBlom
                    grrr still broken
                    gose from normal values to 2000 to -2
                    random spikes
                    https://www.dropbox.com/s/1fbatrcs0sx5us9/Screenshot%202017-07-30%2017.14.28.png?dl=0
                    Hmmm may be the fuse holder …..
                      The 2000C spikes suggest a bad connection somewhere.
                      • MrBlomundefined
                        MrBlom
                        yes it was a faluty fuse holder
                        solder it on the holder and now its been stable the last 5 min 🙂
                        thanks again!
                        • MrBlomundefined
                          MrBlom
                          well its just not my week this week 😞
                          run 2 print with out problem
                          one on each extruder
                          after that i tried to start a dual print
                          left the room and came back after 5 min and the duet is dead all light is black
                          and no i cant turn it on by the psu
                          it works by usb but not by normal power
                          i also did see a smal spark by the heater led light in the left corner
                          so my guess this time is that its somthing wrong with the heater
                          can i fix this also ?
                          sorry for being a pain but is just not my lycky week 😞
                            I'm not sure what you mean by the "left corner" - do you mean the bed heater LED or the E1 heater LED?
                            See the note at https://duet3d.com/wiki/Mounting_and_cooling_the_board about not using metal washers.
                            • MrBlomundefined
                              MrBlom
                              its E0 heat lead i think
                              and im not using metal washer
                              what can i do now to fix this
                                If all the LEDs on the Duet are off, then no power is reaching the board. Either your PSU has stopped working, or the VIN terminal block screws are no longer tight, or something is shorting the PSU out.
                                • MrBlomundefined
                                  MrBlom
                                  you have right again 🙂
                                  the psu dont provide 24v any more
                                  thank for the fast support !
                                  • MrBlomundefined
                                    MrBlom
                                    one of the v+ port has gone bad on the psu
                                    the other works finne now
                                    duet is up and runing again
                                    thanks again!
                                    hopfully this is the end for all my problems for now 🙂
                                    • MrBlomundefined
                                      MrBlom
                                      how bad is this ?
                                      Supply voltage: min 20.8, current 23.7, max 24.5, under voltage events: 0, over voltage events: 0
                                      do i need to get a new psu ?
                                        You might want to measure the voltage with the bed heater fully on and with it off.
                                        • Cinproundefined
                                          Cinpro
                                          DC42 I think this may be what has happened to meas well. I got a reading of 1.4-1.7 ohms from the VSSA to GRD, too low? I have 2000c on the hot end connections, but the bed reads normal room temp.
                                            Check your M305 P1 parameters. If they are correct at least approximately, then a reading of 2000c on a thermistor channel normally means you have a shorted thermistor, or a short between the thermistor and ground.
