    Diode laser installation on duet 2 workbee cnc
    Laser Cutters
    1.1k
    • Beickybeerundefined
      Beickybeer @Beickybeer
      Or can I install it like this?
      g0rgundefined 1 Reply Last reply Reply Quote 0
      • g0rgundefined
        g0rg @Beickybeer
        @beickybeer
        You need a small board that inverts the signal
        https://forum.duet3d.com/topic/19842/weird-laser-mode/28?_=1618486087095
        I actualy get my laser wired on heater3 and i use rrf3 on my duet2 wifi
        I was able to order that board online , i need to double check to find out the link and i'll post it here
        Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
        chimaeraghundefined 1 Reply Last reply Reply Quote 0
        • chimaeraghundefined
          chimaeragh @g0rg
          @g0rg Did you order a fully assembled board or just the components and assembled yourself?
          Duet 2 Wifi, Ooznest Workbee CNC 1510
          • g0rgundefined
            g0rg @chimaeragh
            @chimaeragh
            Just the boards and the components on the same website and i soldered the comps afterward.
            I should buy 5 pieces minimum but for for a very cheap price
              chimaeragh @g0rg
              @g0rg Okay, thanks. Can you provide the link?
              • g0rgundefined
                g0rg @chimaeragh
                @chimaeragh
                https://easyeda.com/keyz182/laserpwmduet
                click on open in editor.
                from that editor you can purchase the board and components
                  chimaeragh @g0rg
                  @g0rg Seems some of the components are discontinued or out of stock 😞
                    dc42 administrators @chimaeragh
                    If you mean the LTV-814H, Digikey is showing no stock, but Mouser has some, and so does RS.
                      chimaeragh @dc42
                      @dc42 Actually, I was trying to have the board on your wiki built and assembled for me.
                      https://duet3d.dozuki.com/Wiki/Laser_PWM_control
                      The 74HCT02D,653 is out of stock on jlcpcb.com so have I to explore other options
                        @chimaeragh said in Diode laser installation on duet 2 workbee cnc:
                        The 74HCT02D,653 is out of stock on jlpcb.com so have I to explore other options
                        Any other 74HCT02 in SOIC-14 package should do.
                          chimaeragh @dc42
                          @dc42 Thanks
