    Diode laser installation on duet 2 workbee cnc
    Laser Cutters
    1.2k
    • g0rgundefined
      g0rg @Beickybeer
      @beickybeer
      You need a small board that inverts the signal
      https://forum.duet3d.com/topic/19842/weird-laser-mode/28?_=1618486087095
      I actualy get my laser wired on heater3 and i use rrf3 on my duet2 wifi
      I was able to order that board online , i need to double check to find out the link and i'll post it here
      Duet 2 wifi , Ooznest Worbee CNC 1510 , Neje Laser 20w. Ruida 100w Co2 Laser 6090. Some homemade laser cnc grbl 1515.
      chimaeraghundefined 1 Reply Last reply Reply Quote 0
      • chimaeraghundefined
        chimaeragh @g0rg
        @g0rg Did you order a fully assembled board or just the components and assembled yourself?
        Duet 2 Wifi, Ooznest Workbee CNC 1510
        g0rgundefined 1 Reply Last reply Reply Quote 0
        • g0rgundefined
          g0rg @chimaeragh
          @chimaeragh
          Just the boards and the components on the same website and i soldered the comps afterward.
          I should buy 5 pieces minimum but for for a very cheap price
            chimaeragh @g0rg
            @g0rg Okay, thanks. Can you provide the link?
            • g0rgundefined
              g0rg @chimaeragh
              @chimaeragh
              https://easyeda.com/keyz182/laserpwmduet
              click on open in editor.
              from that editor you can purchase the board and components
                chimaeragh @g0rg
                @g0rg Seems some of the components are discontinued or out of stock 😞
                  dc42 administrators @chimaeragh
                  If you mean the LTV-814H, Digikey is showing no stock, but Mouser has some, and so does RS.
                    chimaeragh @dc42
                    @dc42 Actually, I was trying to have the board on your wiki built and assembled for me.
                    https://duet3d.dozuki.com/Wiki/Laser_PWM_control
                    The 74HCT02D,653 is out of stock on jlcpcb.com so have I to explore other options
                      @chimaeragh said in Diode laser installation on duet 2 workbee cnc:
                      The 74HCT02D,653 is out of stock on jlpcb.com so have I to explore other options
                      Any other 74HCT02 in SOIC-14 package should do.
                        chimaeragh @dc42
                        @dc42 Thanks
