    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    32.1k
      dc42 administrators @droftarts
      @droftarts said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
      @oc_geek do you change the mode after config.g is run? @dc42 is not sure that M569 reports the current state of the driver, but the one before.
      I have verified that M569 does report the correct state, at least in the firmware at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0.
      • oc_geekundefined
        oc_geek @droftarts
        No i don't.
        I had force spread-cycle in config.g (or to say i did but it got messed up...) via M569 D2
        I now restated it in config.g...
        will continue trying that mode and report if anything happens (hope not)
        I have a Voron 2.4, it doesn't run any stall homing thing...
        thanks
        • Argoundefined
          Argo @droftarts
          @droftarts
          So it does look like the main issue was solved with the new beta FW.
          Interesting that he needs V2 in his config to put the drivers into StealthChop. With my Mini5+ StealthChop mode is by default on and I do not have to set any “V” parameter.
          Still I’m curious why this hasn’t been in issue with my Mini5+ as we have quite similar Prusa Styles printer’s.
          Maybe revision of the MCU? I remember having a skipping extruder with 3.3b2 which after flashing and compiling firmwares back and forth wasn’t reproducible anymore. During that time I also had timeouts but the fact that I could not reproduce it was annoying from a debugging standpoint.
          I’m also glad you confirmed the capabilities of TMC2209s StealthChop (300 mm/s). Here and there you can hear voices that assume it’s only usable for low speeds but for belt driven 3D printer’s it’s well beyond what we need and what will also produce decent prints in terms of ringing.
          Nevertheless I’m glad we have a working firmware version now. I also will continue testing the LDO 0.9 motors with the new FW version but that’s maybe worth a new thread then?
          oc_geekundefined 1 Reply Last reply Reply Quote 0
          • oc_geekundefined
            oc_geek @Argo
            @argo working with SpreadCycle... which we are testing
            Stealthchop caused layers shifts to me tonight
            dc42undefined Argoundefined 2 Replies Last reply Reply Quote 0
              dc42 administrators @oc_geek
              @oc_geek said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
              Stealthchop can't react to sudden changes in load, such as when the print head hits a blob or overhang when travelling at speed. For this reason, I advise against using stealthChop at high speeds.
              • oc_geekundefined
                oc_geek @droftarts
                @oc_geek please post config.g. Looks like you have a low changeover speed to spreadcycle, does it mostly print in spreadcycle?
                Hi Ian,
                which speed do you suggest to set for the mode swicth over ?
                Currently i'm forcing D2 but i may try differently
                thanks
                • Argoundefined
                  Argo @oc_geek
                  @oc_geek
                  Though it’s not RRF but my printer with Klipper I use 200 mm/s travel speeds for draft prints and 160 mm/s infill speed for infill. External perimeter speed is slower (75 mm/s) because it’s just a bed slinger printer and would ring too much.
                  Bord is a cheap SKR 1.4 + TMC2209 in StealthChop mode.
                  Cornering velocity (comparable to jerk) is at 5mm/s as Klipper advises against going higher with input shapers and acceleration at 3.000 mm/s (going higher would be possible but then fine details get mushy because of too much input shaping).
                  Luckily so far I haven’t had any issues with shifted layers. During travel speed I use a Z hop height of 0.2mm so it does not hit anything.
                  The last time I had trouble with StealthChop having layer shifts was with the old 8bit Prusa EINSY board and TMC2130 drivers.
                  I do not remember but are you having layer shifts with 1.8 or 0.9 motors?
                  • oc_geekundefined
                    oc_geek @Argo
                    @argo ...sorry to say but all that it doesn't seem to be much relevant in here...let's please try to keep the replies on issues found on RRF / Duet
                    the tread is already long enough for the folks to work it with..
                    besides i have 0.9 OMC on A/B/Z
                    Argoundefined 1 Reply Last reply Reply Quote 0
                    • Argoundefined
                      Argo @oc_geek
                      @oc_geek
                      0.9 I see. I also had issues with 0.9 + TMC2209 on different boards and firmwares (Marlin, RRF).
                      At what speeds does the layer shift happen or is it somehow possible to easily reproduce it? I’m happy to add data to the matter with two sets of 0.9 motors from LDO and StepperOnline.
                      • oc_geekundefined
                        oc_geek @Argo
                        @argo said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                        @oc_geek
                        If you find issues on your end please report here.
                          droftarts administrators @oc_geek
                          Yesterday I tested at D3 V40 (I think), which was around 3mm/s from memory. This was below the jerk value, and seemed to work well, but I was running short air prints and fast test moves, not an actual print. Again, i set this in config and didn’t change it after reset.
                          • oc_geekundefined
                            oc_geek @droftarts
                            @droftarts @dc42
                            Configuration is :
                            • Rel 3.3 beta 2+2
                            • Forced SpreadCycle (D2)
                            • Mesh active
                            Still getting layer shifts
                            (see below at back after couple of layers)
                            I stopped the print - it produced a sound when that happened
                            Dumps:
                            • M569 report
                            • M122 report
                            • config.g
                            droftartsundefined Argoundefined 2 Replies Last reply Reply Quote 1
                              @oc_geek what exact motors do you have?
                              • oc_geekundefined
                                oc_geek @droftarts
                                OMC Steppers On Line
                                17HM19-2004S (0,9 deg) - on 4xZ, A and B
                                17HS08-1004S (1.8 deg) for the Extruder in Afterburner (aka Clockwork)
                                P.S. These are the ones used by folks which have 0.9 OMC in Voron 2.4
                                • Argoundefined
                                  Argo @oc_geek
                                  @oc_geek
                                  ; Accelerations and speed are set in a file
                                  M98 P"/macros/speed_printing.g"
                                  What speeds are you using to force the layer shift?
                                  I'm going to do a test print with LDO-42STH48-MAC 0.9 motors at 200 mm/s travel speed and 3000 mm/s acceleration forced into SpreadCycle.
                                  Are those speeds high enough to force the error on your side?
                                  oc_geekundefined 2 Replies Last reply Reply Quote 0
                                  • oc_geekundefined
                                    oc_geek @Argo
                                    @oc_geek
                                    Yust to be clear ...
                                    i'm not forcing anything... i'm just trying to print...without success
                                    • speed_printing
                                    • speed_probing
                                    • oc_geekundefined
                                      oc_geek @Argo
                                      @oc_geek
                                      these are normal Voron 2 speeds and accelerations
                                        @oc_geek, please load the firmware at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0. When you observe the problem, pause the print and run the following command for values of # from 0 to 4:
                                        M569.2 P# E0
                                        Post the results here.
                                        • oc_geekundefined
                                          oc_geek @dc42
                                          @dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                                          M569.2 P# E0
                                          I'm sorry but i moved away from the beta
                                          and went back in 3.3 beta 1 without mesh....
                                          At some point also homing went crazy and
                                          G1 X... F360 H1
                                          was stopping in the middle of the rail without the sensor beeng actually triggered... i had to power off twice to get it back to normal....
                                          droftartsundefined carcamerarigundefined 2 Replies Last reply Reply Quote 0
                                            @oc_geek fair enough, thanks for your help. Can you post the Gcode and I’ll try and replicate on my machine.
                                            I had a quick look at the OMC stepper specification, seems very similar to E3D/Wantai motors I have, and the LDO.
                                            Argoundefined oc_geekundefined 2 Replies Last reply Reply Quote 0
