    Missing Steps - Cant Print SpreadCycle StealthChop tuning help
    286
    35.3k
      droftarts administrators @oc_geek
      @oc_geek what exact motors do you have?
      oc_geekundefined 1 Reply Last reply Reply Quote 0
      • oc_geekundefined
        oc_geek @droftarts
        @droftarts said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
        OMC Steppers On Line
        17HM19-2004S (0,9 deg) - on 4xZ, A and B
        17HS08-1004S (1.8 deg) for the Extruder in Afterburner (aka Clockwork)
        P.S. These are the ones used by folks which have 0.9 OMC in Voron 2.4
        • Argoundefined
          Argo @oc_geek
          @oc_geek
          ; Accelerations and speed are set in a file
          M98 P"/macros/speed_printing.g"
          What speeds are you using to force the layer shift?
          I'm going to do a test print with LDO-42STH48-MAC 0.9 motors at 200 mm/s travel speed and 3000 mm/s acceleration forced into SpreadCycle.
          Are those speeds high enough to force the error on your side?
          oc_geekundefined 2 Replies Last reply Reply Quote 0
          • oc_geekundefined
            oc_geek @Argo
            @argo said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
            @oc_geek
            Yust to be clear ...
            i'm not forcing anything... i'm just trying to print...without success
            • speed_printing
            • speed_probing
            • oc_geekundefined
              oc_geek @Argo
              @oc_geek
              these are normal Voron 2 speeds and accelerations
                dc42 administrators @oc_geek
                @oc_geek, please load the firmware at https://www.dropbox.com/sh/dupd9u1xppr1om5/AADYg4guuj2n8LJokVqtK-C7a?dl=0. When you observe the problem, pause the print and run the following command for values of # from 0 to 4:
                M569.2 P# E0
                Post the results here.
                • oc_geekundefined
                  oc_geek @dc42
                  @dc42 said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                  M569.2 P# E0
                  I'm sorry but i moved away from the beta
                  and went back in 3.3 beta 1 without mesh....
                  At some point also homing went crazy and
                  G1 X... F360 H1
                  was stopping in the middle of the rail without the sensor beeng actually triggered... i had to power off twice to get it back to normal....
                  droftartsundefined carcamerarigundefined 2 Replies Last reply Reply Quote 0
                    @oc_geek fair enough, thanks for your help. Can you post the Gcode and I’ll try and replicate on my machine.
                    I had a quick look at the OMC stepper specification, seems very similar to E3D/Wantai motors I have, and the LDO.
                    Argoundefined oc_geekundefined 2 Replies Last reply Reply Quote 0
                    • Argoundefined
                      Argo @droftarts
                      @droftarts
                      I tested a small print on my machine at 300 mm/s travel speed and 4000 mm/s acceleration (LDO-42STH48-MAC 0.9 motors) in SpreadCycle mode without issues.
                      Unfortunately I don't have a Duet 3 Mini 2+ Dual-stepper Expansion Board but the issue might only occur when using all stepper channels at once (just a guess).
                      Could you also replicate that part?
                      • oc_geekundefined
                        oc_geek @droftarts
                        g code file exceeds the max allowed size for attachment
                        I revert sending you the STL(s), both were printed on same plate at once
                        • Part 1.stl
                        • Part 2.stl
                        thanks
                        • oc_geekundefined
                          oc_geek @Argo
                          @droftarts Argo might be right
                          Two (of four) of my Z steppers are on the Mini 2+ expansion (there were issues on those channels looking at the fixes done)
                          It might be that + mesh creates a bad combination... and destabilize calculations on X/Y/Z don't know what to think else
                          (Voron 2 has a four Z steppers gantry with autoleveling)
                            @oc_geek said in Missing Steps - Cant Print SpreadCycle StealthChop tuning help:
                            1. What fixes?
                            2. What motor currents have you set, and are you using fan cooling of the Duet? With so many stepper drivers in use, I am wondering whether you might be getting over-temperature cutout of some of the stepper drivers.
                            • oc_geekundefined
                              oc_geek @dc42
                              1. What fixes?
                              this (3.3 beta3)
                              The 2-driver expansion board on a Duet Maestro or Duet 3 Mini used a separate channel to make it available as a pseudo temperature sensor, however that channel was not accessible. Those drivers are now included in the main channel.
                              1. What motor currents have you set,
                              1200 mA on all X/Y/Z
                              indeed it is cooled there are two fans pointed on the drivers by design
                              Question: as i'm going to transplant the new Mini 5+ v1.0 soon
                              Is it better to have all four Z steppers on the 5+ drivers
                              and A/B on the 2+
                              or is it irrelevant ?
                                and A/B on the 2+
                                If they are all moving most of the time (as they are when you are using bed compensation) and they all run at the same current, then it should make no difference.
                                The correct way to cool the drivers is to use a fan to blow air along the line of drivers, in particular cooling the underside of the PCBs.
                                • oc_geekundefined
                                  oc_geek @dc42
                                  Would this do ? or better rotated ACW 90*
                                    @oc_geek, this is where I would put an electronics cooling fan:
                                    However, 1200mA per driver isn't a high current. Are the driver chips getting hot?
                                    • oc_geekundefined
                                      oc_geek @dc42
                                      Honestly hard to say those are sitting upside down in the electronic bay below 35Kg of metal and plastic enclosure...
                                      I may rotate the card 90 degrees if that helps... but again... i do print in 3.3beta1 without mesh and without forcing any modes and so on...
                                      the issues comes when mesh get enabled ...then axis go crazy
                                        @oc_geek, if you print with mesh bed compensation turned off then standstill current reduction will kick in on the Z axis.
                                        Can you hold your finger on the Z driver chips while the machine is printing with bed compensation enabled? If you can't because they are too hot, then you probably need better cooling or lower current.
                                        • oc_geekundefined
                                          oc_geek @dc42
                                          there are 1000(s) Voron 2 out there (made at spec) and none have these issues... perhaps those use different hw though...
                                          SputnikOC3dundefined 1 Reply Last reply Reply Quote 0
                                          • carcamerarigundefined
                                            carcamerarig @oc_geek
                                            M569.2 P# E0
                                            G1 X... F360 H1
                                            @droftarts I encountered this and also on Thursday, how did we overcome it?
