    Custom Heat Pad and thermistor question
    2.8k
    • wingtipundefined
      wingtip @mrehorstdmd
      @mrehorstdmd
      What were you trying to print abs or something extreme like that? Im not... as i said, this method has worked on my other printer for years and is how ive made this one... The problem i usually have is the prints stick to well and i have trouble getting them to release.
      Im not changing it all now after its been built as the alum bed is designed with the adjustment wheels in mind. mounting it directly to the alum sheet would require ordering another heat pad slightly smaller and restrict my building area even further after losing 20+ mm in x axis already due to binder clips.
      It is what it is at this point and if there are issues then i will address it then. But the same setup has worked for me already for several years...
      Highly modified FT5 R1, ATX supply, mosfet w/silicone heat pad, bmg ext, TMC2600 drivers, and my custom quad z mod with 4 lead screws and custom cut new upper panels and bed, and using the dual z endstop mod. New project is 800x500x500z printer.
      • mrehorstdmdundefined
        mrehorstdmd @mrehorstdmd
        The OP's aluminum is not a cast plate, but an extruded or rolled sheet which will not be flat enough to print on. That also means that if you were to put the thick glass on that aluminum, the glass will not heat evenly because of air gaps between the glass and the aluminum and the poor thermal conductivity of the air and glass. A thinner, more flexible piece of glass would be better in this case, at least for heat transfer, but then you have the problem of unflatness (which can be solved with flatness compensation and a sensor on the extruder carriage).
        A closer to ideal situation is to put a piece of glass, probably not especially thick, on a piece of cast tooling plate with the heater attached to the bottom of the plate. The flat aluminum will contact the glass surface with fewer and thinner air gaps and do a better job of transferring the heat. This way you get flatness and good heat transfer.
        Do you want to ride a bike with square wheels?
        https://www.youtube.com/watch?v=FlvjWpWu99A
          It's untraditional, but I think it will work. I guess I'm most worried there will be hot spots on the heater if it's not making great contact with the glass. It is 1500w afterall. Glass isn't a great heat conductor but the traces on the heater pad look pretty evenly spread out and close together. And that glass is thick as hell.
          Don't forget to PID tune the bed heater.
          wingtipundefined 1 Reply Last reply Reply Quote 0
          • wingtipundefined
            wingtip @Phaedrux
            @phaedrux
            its 6061 t5 alum sheet that a machine shop drilled and milled to accept 4mm nuts in place. As for the airgaps its sandwiched with giant Fing binder clips to clamp it all together. Again this is the exact same method that is working on my other printer just fine.
              Phaedrux Moderator @wingtip
              @wingtip hey I'm on your side! fire it up and show us! 😉
              • wingtipundefined
                wingtip @Phaedrux
                @phaedrux Im getting there....
                • wingtipundefined
                  wingtip
                  Looking here at the link suggested for setting up the bltouch, https://duet3d.dozuki.com/Wiki/Test_and_calibrate_the_Z_probe , it says on step 10
                  Open config-override.g and check that there are no G31 commands in it. If you find any, delete those lines and save the file.
                  I do not have a config-override.g file. Should I?
                  • Board: Duet 2 WiFi (2WiFi)
                    Firmware: RepRapFirmware for Duet 2 WiFi/Ethernet 3.2.2 (2021-02-11)
                    Duet WiFi Server Version: 1.25
                    @wingtip said in Custom Heat Pad and thermistor question:
                    It will get created after sending M500 to save any measured values. If it doesn't exist, don't worry about it. When you do the bed and nozzle heater tuning you'd usually send M500 to save those results. You'd also need to put M501 at the end of config.g to load that file again at startup.
                    https://duet3d.dozuki.com/Wiki/Gcode#Section_M500_Store_parameters
                    • wingtipundefined
                      wingtip
                      ok, i have the z offset set (not perfect till i try a print), and have the x,y offsets in. I have not done any pid tuning yet. should i wait to put the m501 into the config.g till i do the pid tuning?
                      and with the bl touch working now can i try some sort of mesh leveling to try to dial in the bed mechanical adjustments??
                        Yes if you've got the BLtouch working with G30 now you can do mesh leveling if you wanna see you the bed surface looks.
                        M557 controls the area to probe and the density of points.
                        You can add M501 now or wait until after you do the tuning. Up to you. BTW, be prepared to wait a while for the bed tuning to complete. It can take a long time with large beds. It'll be interesting to see how it deal with the unorthodox setup.
                        • wingtipundefined
                          wingtip
                          I think i am ready to try to heat up the bed.... Bare with me for all the dumb questions because 1) this is my first duet/reprap (coming from marlin), 2) My first AC powered bed with SSR..
                          I will post the config g below if someone can take a look at the heater section and make sure all looks good. If so i think the first command i want to enter to the console would be something like:
                          • M303 T0 S100 ; where T0 is the bed and S80 is the cutoff or target temp??? Is this correct?
                           Configuration file for Duet WiFi (firmware version 3)
                          ; generated by RepRapFirmware Configuration Tool v3.2.3 on Wed Mar 03 2021 15:26:56 GMT-0600 (Central Standard Time)
                          G90                                            ; send absolute coordinates...
                          M83                                            ; ...but relative extruder moves
                          M550 P"The Big One"                             ; set printer name
                          M552 S1                                        ; enable network
                          M586 P0 S1                                     ; enable HTTP
                          M586 P1 S0                                     ; disable FTP
                          M586 P2 S0                                     ; disable Telnet
                          M569 P0 S0                                     ; physical drive 0 goes reverse
                          M569 P1 S0                                     ; physical drive 1 goes reverse
                          M569 P2 S1                                     ; physical drive 2 goes forwards
                          M569 P3 S0                                     ; physical drive 3 goes reverse
                          M569 P4 S1                                     ; physical drive 4 goes forwards
                          M569 P5 S0                                     ; physical drive 5 goes reverse
                          M584 X0:3 Y1 Z2:5 E4                               ; set drive mapping
                          M350 X16 Y16 Z16 E16 I1                        ; configure microstepping with interpolation
                          M92 X395.52 Y80.00 Z400.00 E420.00              ; set steps per mm
                          M566 X300.00 Y900.00 Z180.00 E120.00            ; set maximum instantaneous speed changes (mm/min)
                          M203 X4000.00 Y4000.00 Z400.00 E1200.00        ; set maximum speeds (mm/min)
                          M201 X400.00 Y500.00 Z20.00 E250.00            ; set accelerations (mm/s^2)
                          M906 X1400 Y1000 Z1200 E800 I30                   ; set motor currents (mA) and motor idle factor in per cent
                          M84 S30                                        ; Set idle timeout
                          M208 X0 Y0 Z0 S1                               ; set axis minima
                          M208 X655 Y440 Z400 S0                         ; set axis maxima
                          M574 X1 S1 P"!xstop+!e0stop"                            ; configure active-high endstop for low end on X via pin xstop
                          M574 Y1 S1 P"!ystop"                            ; configure active-high endstop for low end on Y via pin ystop
                          M574 Z1 S2                                     ; configure Z-probe endstop for low end on Z
                          M950 S0 C"duex.pwm3"                           ; create servo pin 0 for BLTouch
                          M558 P9 C"^zprobe.in" H5 F120 T6000            ; set Z probe type to bltouch and the dive height + speeds
                          G31 P500 X0 Y-35 Z2.757                            ; set Z probe trigger value, offset and trigger height
                          M557 X15:215 Y15:195 S20                       ; define mesh grid
                          M308 S0 P"bedtemp" Y"thermistor" T100000 B3950 ; configure sensor 0 as thermistor on pin bedtemp
                          M950 H0 C"bedheat" T0                          ; create bed heater output on bedheat and map it to sensor 0
                          M307 H0 B0 S1.00                               ; disable bang-bang mode for the bed heater and set PWM limit
                          M140 H0                                        ; map heated bed to heater 0
                          M143 H0 S120                                   ; set temperature limit for heater 0 to 120C
                          M308 S1 P"e1temp" Y"thermistor" T100000 B4725 C7.06e-8 ; define E1 temperature sensor
                          M950 H1 C"e1heat" T1                           ; create nozzle heater output on e0heat and map it to sensor 1
                          M307 H1 B0 S1.00                               ; disable bang-bang mode for heater  and set PWM limit
                          M143 H1 S280                                   ; set temperature limit for heater 1 to 280C
                          M950 F0 C"fan0" Q500                           ; create fan 0 on pin fan0 and set its frequency
                          M106 P0 S0 H-1                                 ; set fan 0 value. Thermostatic control is turned off
                          M950 F1 C"fan1" Q500                           ; create fan 1 on pin fan1 and set its frequency
                          M106 P1 S1 H1 T45                              ; set fan 1 value. Thermostatic control is turned on
                          M563 P0 D0 H1 F0                               ; define tool 0
                          G10 P0 X0 Y0 Z0                                ; set tool 0 axis offsets
                          G10 P0 R0 S0                                   ; set initial tool 0 active and standby temperatures to 0C
                          M575 P1 S1 B57600                              ; enable support for PanelDue
                          T0
                            M303 T0 S100 would tune the hotend heater on tool0 to 100c. T0 = tool0. This will also control the part cooling fan automatically to take it's cooling of the nozzle into account.
                            The bed would be M303 H0 S100. H0 = heater 0, which in your config is the bed.
                            But I think you should tune the hotend heater first so you can see what to expect. Just choose your normal printing temp.
                            • wingtipundefined
                              wingtip @Phaedrux
                              @phaedrux said in Custom Heat Pad and thermistor question:
                              M303 H0 S100.
                              I dont have a part cooler yet for this so should i still try a tune on the hotend? Then try the bed?
                              M303 H1 S236 ; for the hotend
                              M303 H0 S80 ; for the bed, should i use a p variable for the pwm setting or does it just default to full 100% pwm??
                                Yeah if you don't have a part fan at the moment you can just use M303 H1.
                                PWM is 100% by default.
                                • wingtipundefined
                                  wingtip
                                  M303 H1 S236
                                  I forgot to install the heater block sock but here are the results from the hotend pid tuning
                                  Auto tuning heater 1 completed after 3 idle and 5 tuning cycles in 395 seconds. This heater needs the following M307 command:
                                   M307 H1 R1.856 C216.2 D4.86 S1.00 V11.8
                                  Edit the M307 H1 command in config.g to match this. Omit the V parameter if the heater is not powered from VIN.
                                    @wingtip nozzle sock and tuning it as a tool will be a good idea once that's all in place, but that's a good first step. Show's it heats up anyway. If you set a temp does it hold steady?
                                    • wingtipundefined
                                      wingtip @Phaedrux
                                      @phaedrux yes but i already knew that when i heated it up to tighten the nozzle
                                      so im good to copy that m307 line in its entirety to the config file and save? then do pid tuning on the bed or should i do it now and enter both lines then save and restart?
                                        Either copy the line or just send M500 to automatically save the results to config-override.g. Then add M501 to the end of config.g to load that file. Whichever you prefer.
                                        • wingtipundefined
                                          wingtip
                                          Well I had some interesting things happen while trying to PID tune the bed. Being worried about heating up the glass to quickly as this was my first ac powered bed, when i sent the command to start the tune i also entered a P command to cut the pwm to 40% to ease into heating up the glass. It was very slow to say the least but it was heating up. When it first put power to the bed it had a slight odor to it that i just assumed was the new pad.
                                          Eventually it got up to about 60c (i set it to go to 80c) then failed saying that the temp couldnt be reached. Im unaware if it was at that moment is when the failure occured or when i tried again later after letting the bed cool fully and i then let it rip at full pwm In hopes that it just timed out the first time and would heat faster at 100%. But after noticing finally the power switch to the bed wasnt lit i removed the switch and found the fuse had melted the internal plastic around it and eventually blew. the fuse internally was only 5 amp. I need to find a new switch that can handle a little more amperage. I wouldnt trust re using this one with a new fuse since the housing got so hot.
                                          This is the switch i used (bought 2 years ago for this project) https://www.amazon.com/gp/product/B07C1567XW/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
                                          and here was the results
                                          • jens55undefined
                                            jens55
                                            Well let's see, you installed a switch/fuse/socket combo that has a 5A fuse installed with a switch that is rated at 10A and you run between 12 and 13A (depending on your line voltage) through it.
                                            Can you see a problem with this arrangement?
                                            Find yourself something that is rated at 20A and you will be golden.
                                            BTW, the power cords that plug into that particular plug are usually rated at between 5 and 10A and make for a nice heater when you draw that much power .... but then you like to do unconventional things so don't let me keep you from exploring this method of powering your printer. Like the arrangement of your print bed, it likely will work for a while before biting you in the rear.
