    What’s the stance on RRF on none Duet boards?
    2.8k
    • zaptaundefined
      zapta @jay_s_uk
      @jay_s_uk said in What’s the stance on RRF on none Duet boards?:
      For example, the LPC port won't be getting accelerometer support due to no floating point hardware.
      What is the reason for that? There are for example M4 LPCs with floating point hardware and FP hardware is very common these days.
        jay_s_uk @zapta
        @zapta
        the 1768/69 don't have it. And even if they did theres virtually 0 free ram to do anything.
        They only have 64kb which is the same amount the duet 0.6/0.85 have
        • sinned6915undefined
          sinned6915 @jay_s_uk
          @jay_s_uk out of curiosity, what is the relative cost between say :
          STM based board + SBC + display solution
          vs.
          Duet2 clone + display solution
          so we can compare it to OEM?
          • zaptaundefined
            zapta @jay_s_uk
            Got this week two SKR 1.4 'turbo' for an upcoming Voron 2 build but now that you mentioned I checked and indeed they use a measly LPC1769, but still better than the 8 bit Prusa MK3. 😉
            The Voron uses Klipper so the heavy lifting computation is done on the SBC so so I expect good performance.
            Do the Chineese manufactures upgrading now to STM32F4? E.g. the SKR pro and the FLY E3? Do they use STMicroelectronics chips or do they have local clones?
              jay_s_uk @sinned6915
              @sinned6915
              STM
              Wifi
              The STM doesn't need an SBC to function.
              The cheapest board is probably the SKR-RRF-E3 which can be had for around £30. It has built in 2209's and can't support an SBC. You can then use any one of the screens available, i.e. paneldue, fly scree, BTT TFT or 12864. So you could have a complete setup for around £40. It does however only have 4 drivers (there is an addon board that adds another 2 drivers which adds another £10 to the cost) but there are other boards that have 5 or more drivers (Fly-E3-Pro has 5 onboard, SKR 2 has 5 replaceable, Fly-CDYv2/SKR Pro have 6 replaceable, Fly-407ZG has 9 replaceable and SKR GTR + M5 has 11 replaceable).
              For some of the boards an additional wifi adapter is needed which is around another £8.
              We also don't currently offer any ethernet based boards, so if ethernet was required then an SBC setup would be needed.
              SBC
              To use an SBC, the boards require an additional set of adapters (you can roll your own), which are around £8-10.
              Clones
              The duet 2 wifi can be purchased for around £45 but you don't know what you're getting with those.
              zaptaundefined 2 Replies Last reply Reply Quote 1
                jay_s_uk @zapta
                @zapta
                I know fly/mellow uses original unused STM32F4 processors. Prices have also started to raise a lot recently.
                We believe BTT is using secondhand STM32F4 processors (hence the slightly cheaper prices) but we can't substantiate that either way.
                • zaptaundefined
                  zapta @jay_s_uk
                  SKR 2 has 5 replaceable...
                  I am not sure what I think about the replaceable vs soldered. On one hand, the replaceable are easier to replace when something goes wrong but on the other hand the connector is another thing that can go wrong and overall it looks as a 'ghetto' design. 😉
                  • zaptaundefined
                    zapta @jay_s_uk
                    @jay_s_uk, the new rave in Chinese boards is the Fysetc Spider. STM32F446 with 8 replaceable TMC2209 for $60 shipped. It has 5V and 12V buck converters for external devices and marlin and klipper support, and got design input from the Voron dev team with the goal to replace the two SKRs. I don't see anything about a wifi dongle.
                    https://wiki.fysetc.com/Spider/
                    What's the process of getting RRF support for a new board like this? Is it typically done by the vendor or by the community?
                    EDIT: The wiki page says this: "As RRF firmware requires more than 512KB of Flash space, the Spider equipped with 446 cannot meet its requirements. So Spider has another version dedicated to running RRF firmware, which uses STM32F407VGT6 MCU."
                      jay_s_uk @zapta
                      @zapta that board won't get added in its current form.
                      They've chosen an MCU with only 512kb of flash and the firmware as it stands is already bigger than that for a wifi build
                      They are releasing a 407 version I believe. Lets just hope they choose the right processor
                      zaptaundefined dc42undefined 2 Replies Last reply Reply Quote 0
                      • zaptaundefined
                        zapta @jay_s_uk
                        Just posted an EDIT. The RRF processor is STM32F407VGT6
                          jay_s_uk @zapta
                          @zapta thats the same processor used on the Fly-E3, E3-Pro, SKR-RRF-E3 and SKR 2.
                          The next challenge is getting the information for it or even getting a board for testing.
                          • zaptaundefined
                            zapta @jay_s_uk
                            @jay_s_uk, when I click on Compatible Boards at https://www.reprapfirmware.org/ it shows only Duet3d boards.
                            Have you tried discussing with reprapfirmware.org owners (Duet3d?) having a more vendor neutral page that lists all boards?
                            The boundary between RRF and Duet3d is confusing to me.
                              jay_s_uk @zapta
                              @zapta
                              Never even thought about that page.
                              I would have to approach duet3d about it.
                                dc42 administrators @jay_s_uk
                                Bigger than 512kb? Sounds odd to me. Duet2CombinedFirmware for the Duet WiFi and Ethernet is currently 500kb and has the code for both WiFi and Ethernet included. It's only the Duet 3 and 3 Mini builds with CAN support that are bigger than 512kb.
                                  jay_s_uk @dc42
                                  @dc42 Yep, this is from Andy
                                  The latest development WiFi build (which by default loads at address 0x08008000 (so we allow 32K for the bootloader) already uses flash memory up to 0x0808fecc which is a total of 543Kb of flash which means a total size (with the bootloader) of 575kBytes.
                                    @jay_s_uk I see, it's because 32kb is already taken up by the bootloader.
                                    jay_s_ukundefined gloomyandyundefined 2 Replies Last reply Reply Quote 0
                                      jay_s_uk @dc42
                                      @dc42 yep
                                      I also don't know how much the board.txt functionality and multiple board support takes up.
                                      We also produce separate builds for wifi and SBC
                                      • gloomyandyundefined
                                        gloomyandy @dc42
                                        @dc42 There is a further 32K that is used for NVM emulation to hold the stack/registers after a reset. This is rather wasteful but on the chips we currently support not really an issue.
                                        Some other things are also a little different in that we have additional code to support any mixture of TMC2208/2209/5160 drivers. A software based UART (for TMC drivers) and software SPI. I'm also pretty sure that our CoreN2G has rahter more in it than strictly needed.
                                        • achrnundefined achrn referenced this topic
