    Independent input shapers per axis
    Firmware wishlist
    2.5k
    • wescundefined
      wesc
      The current RRF documentation for M593 indicates that there's a single frequency selectable for the input shapers. Will this be changed to support independent frequencies and shapers per axis? Machines are far from iso-resonant, so choosing one frequency and shaper for both axis will yield a sub optimal result.
      Bedflingers in particular have radically different resonant frequencies.
      On my crossed gantry 500x330 printer, one axis is best served by a 46hz ZV and the other by 68hz MZV shaper (according to klipper recommendations).
      CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
      wescundefined CNCModellerundefined dc42undefined 3 Replies Last reply Reply Quote 1
      • wescundefined
        wesc @wesc
        Some before and after pix (ignore the schmoo near the bottom. i have a fan connection that is wonky). 2K to 14K accel at top. 200mm/s
        CCS86undefined wescundefined 2 Replies Last reply Reply Quote 0
        • CCS86undefined
          CCS86 @wesc
          This definitely seems worth the effort. I can't wait for input shaping to release in RRF!
          • wescundefined
            wesc @wesc
            I should try the same shaper and freq for both axis to see how that impacts print results. Away from printer until monday...
            • CNCModellerundefined
              CNCModeller @wesc
              @wesc I'd imagine that for "bed slinger" this is even more significant, and definitely will be for my polar printer. It's a perspective I hadn't properly thought through so far.
              Polar Duet3 Mini + 1HCL
              https://youtube.com/playlist?list=PLWjZVEdMv1BY82izahK45qKh-hp3NFkix
              Wanhao D4S: Duet2
              https://forum.duet3d.com/post/296755
              K40 Laser, Duet2
              https://forum.duet3d.com/post/312082
              Wanhao D5S
              https://www.youtube.com/CNCModellerUK
                dc42 administrators @wesc
                @wesc, we're leaving the option open to support different input shapers per axis. However, this brings with it two potential problems. The first is that RAM usage would be increased; so we may not be able to support it on the Duet 2 series. The second is that if you use per-axis input shapers, then the print head will not longer follow exactly the path specified in the GCode. This generally doesn't matter for travel moves, but does for printing moves. This may be what the Klipper documentation refers to as "smoothing" when more complex input shapers are used.
                wescundefined CNCModellerundefined CCS86undefined 3 Replies Last reply Reply Quote 0
                • wescundefined
                  wesc @dc42
                  @dc42 if ram is a constraint, then that's an acceptable reason for duet2. But, i'd prefer if some other features were limited (like the LPC port does) to free up ram to support it.
                  If there isn't 2 axis input shaping in rrf3, I will await the klipper port to duet3. Duet3 mini port has been completed.
                  Input shaping is THE killer feature. And 2 axis is essential for it to work well.
                    @wesc said in Independent input shapers per axis:
                    On bed slingers, maybe.
                      CNCModeller @dc42
                      @dc42 said in Independent input shapers per axis:
                      Would it be possible to filter both frequencies on both axes to keep them synchronised for printing moves?
                      Wanhao D4S: Duet2
                      K40 Laser, Duet2
                      Wanhao D5S
                      • elmoretundefined
                        elmoret
                        Just chiming in to say that input shaping is the single most requested feature/reason people use Klipper over RRF/Duet3D products in my experience.
                          dc42 administrators @CNCModeller
                          @cncmodeller said in Independent input shapers per axis:
                          It may be theoretically possible, but I haven't found any papers about how to do it. However, I have now added support for custom input shapers to the code,;so anyone who can calculate the required impulse amplitudes and timings will be able to set them, subject to the maximum number of impulses supported.
                          I haven't found any information on the MZV input shaping supported by Klipper either.
                          CNCModellerundefined 1 Reply Last reply Reply Quote 0
                            CNCModeller @dc42
                            In my uneducated mind, could you not apply the shaping to the demand twice in series, take the output from the first shaping and feed it into the second?
                            I'm sure I'm talking 8ollocks... but I had to ask.
                            Plus I guess the processing overhead would be significant even if it were possible.
                            Feel free to tell me it doesn't work like that and that I'm a total numpty... 🙂
                            Wanhao D4S: Duet2
                            K40 Laser, Duet2
                            Wanhao D5S
                              No, unless the higher frequency was at least 2 to 3 times the lower frequency, so that each individual step taken by the shaper for the lower frequency could itself be shaped to cancel the higher frequency.
                              However, if a sequence of amplitudes and times that cancel the two frequencies and damping factors concerned can be calculated offline just once, then they can be fed into the RRF input shaper and the run-time cost of implementing it should not be excessive.
                              CNCModellerundefined GeneRisiundefined 2 Replies Last reply Reply Quote 0
                                CNCModeller @dc42
                                @dc42 thanks for the education... please don't take this as meddling, I just would really like to understand the practicalities of the technology. I'm not sure I'd be able to get my head around the research like yourself.
                                I'm thinking that frequency difference might be valid in special cases such as for bed slingers with a very heavy bed.
                                When I get round to measure my polar radius arm and bed frequencies I'll let you know what I find.
                                Really interesting, great work BTW. Much respect.
                                Wanhao D4S: Duet2
                                K40 Laser, Duet2
                                Wanhao D5S
                                • CCS86undefined
                                  CCS86 @dc42
                                  You could argue, that because of the resonance / ringing, the unaltered input isn't allowing the nozzle to exactly follow the path, and that the shaped input's intentional path "deviations" actually allow more precise tracking of the nozzle to the path, no?
                                  dc42undefined 1 Reply Last reply Reply Quote 2
                                    dc42 administrators @CCS86
                                    @ccs86 said in Independent input shapers per axis:
                                    Maybe.
                                    • Diamondbackundefined
                                      Diamondback
                                      @dc42 This one maybe?
                                      https://www.researchgate.net/publication/224606974_Input_shaping_for_nonlinear_systems
                                      • GeneRisiundefined
                                        GeneRisi @dc42
                                        @dc42 Would the "offline" calculation solution work on both axes on Duet2 boards, or are the RAM limitations still an issue?
                                          dc42 administrators @GeneRisi
                                          @generisi said in Independent input shapers per axis:
                                          If we can use a single shaper to handle two frequencies, that is likely to be usable on Duet 2.
