    all duex heaters shorted...
    1.8k
      Was the laptop on battery or wall power?
      matt3oundefined 1 Reply Last reply Reply Quote 0
      • matt3oundefined
        matt3o @Phaedrux
        @phaedrux battery, but that's the only thing that I did before the problem started (even though not right away).
          Well if you were on battery on the laptop there would be no path to ground through USB, so probably not a ground loop.
          Can you post some photos of the board in case we can spot any burnt components?
          • matt3oundefined
            matt3o @Phaedrux
            @phaedrux sure, thanks!
            • matt3oundefined
              matt3o @matt3o
              sorry for bumping this, I would just like to understand given the symptoms if there could be anything else dead on the board apart from the heaters... should I bin the duex?
              • jens55undefined
                jens55 @matt3o
                @matt3o way too early to bin the board and if you don't find out what is going on you don't learn anything.
                • matt3oundefined
                  matt3o @jens55
                  @jens55 thanks 😄 but I don't think I have the equipment (or the skill) to desolder and solder that kind of SMD components. I can do a diode, resistor, capacitor, mosfet...
                  If it's really the 74HCT02 I don't think I can really make it
                  • jens55undefined
                    jens55 @matt3o
                    @matt3o, there are people on here who offer 'best effort' repair services for people in your exact position. I am hoping that one of these people will pop up and offer to help.
                    Did you indicate your approximate location? It is only feasible if shipping costs are reasonable.
                    • matt3oundefined
                      matt3o @jens55
                      well let's see if someone can help find the problem, visually the 74HCT02 seems totally fine and the USB connection actually works... so could be something else. I'm located in Italy, btw
                        I can't see anything in the photos, but they are a tad dim. There may not be any visible damage either.
                        You might inquire here if you don't know of anyone local that can do SMD repair.
                        https://forum.duet3d.com/topic/13875/community-repairs
                        If you disconnect everything from the Duex except VIN do the heaters still enable immediately?
                        • matt3oundefined
                          matt3o @Phaedrux
                          @phaedrux said in all duex heaters shorted...:
                          damn! that was a good idea, unfortunately the heaters are still enabled (just to be clear, only the heater that is configured in the config is enabled... the LED turns on immediately)
                          • jens55undefined
                            jens55 @matt3o
                            @matt3o, hold on a minute .... the only thing that you have going to the board is Vin and presumably ground and the only heater that powers up is the one configured in the config file ???? Something is fishy in Italy ....
                            This is without the ribbon cable connected between the Duet and the Duex? It should not care what is in the config file! If any heater port powers up with only Vin and ground connected then there is a hardware fault with that heater port. If only one powers up than that would seem to suggest only one defective heater output and not all of them. You should be able to configure a different (free) heater port and be off to the races .....
                            • matt3oundefined
                              matt3o @jens55
                              @jens55 I disconnected everything except the ribbon and power.
                              any heater I configure goes full throttle as soon as I give power
                              • jens55undefined
                                jens55 @matt3o
                                Based on that, I would say that the issue is firmware related and not hardware related. I am not very good with config files but you could post your config.g and somebody who knows their stuff might be able to see something that isn't right.
                                  Is it all heaters or only the configured heater?
                                  What happens when the ribbon is disconnected as well? If it's a heater mosfet that has failed closed circuit it would enable the heaters automatically.
                                  If it's only your configured heater than perhaps the configuration is not correct. Perhaps the pin has been inverted so that it's on by default.
                                  Please post your config.
                                  • matt3oundefined
                                    matt3o @Phaedrux
                                    I checked with a multimeter and all heaters are shorted (at the same time). I thought it was just the one configured because it's the only one that lights the LED. I tried all the heaters anyway and they all behave the same except the 2 on the duet
                                    I'm pretty sure it's not the config because as soon as I set the heater to one on the duet2 (not the duex) everything works and the only thing that changes is the heater name. I'll try to disconnect the ribbon and also post the config just in case
                                    • jens55undefined
                                      jens55 @matt3o
                                      @matt3o, I am not sure if I am looking at the right schematic but what I am seeing is that the LED is connected directly to the output pin. If the output is switched low then the LED will light up. That seems at odds with the report of only one light lighting up.
                                      Could you explain how you measure the fact that the output is shorted?
                                      • matt3oundefined
                                        matt3o
                                        this is all very weird and erratic.
                                        so first time it happened I checked the heaters with a multimeter and all of them were shorted (I just check resistance @jens55 ).
                                        I tried to disconnect the ribbon cable as @Phaedrux suggested and everything's fine, of course the duet doesn't com with the duex but the heaters are all open (off).
                                        I reconnected the ribbon (with printer off of course) and now the heaters are all open (off) except for the one that is configured that goes in full blast as soon as I give power. In fact the heater LED turns on right away.
                                        If I set the heater to any one on the duet2 everything works as expected.
                                        • jens55undefined
                                          jens55 @matt3o
                                          @matt3o, I don't know what else to suggest. From my end it sounds as if the board is fine and the issue is in the config file but as you say, it works if configured to run the heaters on the Duet.
                                          Sorry ....
                                          • matt3oundefined
                                            matt3o @jens55
                                            @jens55 thanks for your help anyway, really appreciated it. I'll do some more testing but I'm out of ideas
                                            engikeneerundefined 1 Reply Last reply Reply Quote 0
