    all duex heaters shorted...
    1.7k
    • jens55undefined
      jens55 @matt3o
      @matt3o way too early to bin the board and if you don't find out what is going on you don't learn anything.
      matt3oundefined 1 Reply Last reply Reply Quote 0
      • matt3oundefined
        matt3o @jens55
        @jens55 thanks 😄 but I don't think I have the equipment (or the skill) to desolder and solder that kind of SMD components. I can do a diode, resistor, capacitor, mosfet...
        If it's really the 74HCT02 I don't think I can really make it
        • jens55undefined
          jens55 @matt3o
          @matt3o, there are people on here who offer 'best effort' repair services for people in your exact position. I am hoping that one of these people will pop up and offer to help.
          Did you indicate your approximate location? It is only feasible if shipping costs are reasonable.
          • matt3oundefined
            matt3o @jens55
            well let's see if someone can help find the problem, visually the 74HCT02 seems totally fine and the USB connection actually works... so could be something else. I'm located in Italy, btw
              I can't see anything in the photos, but they are a tad dim. There may not be any visible damage either.
              You might inquire here if you don't know of anyone local that can do SMD repair.
              https://forum.duet3d.com/topic/13875/community-repairs
              If you disconnect everything from the Duex except VIN do the heaters still enable immediately?
              • matt3oundefined
                matt3o @Phaedrux
                @phaedrux said in all duex heaters shorted...:
                damn! that was a good idea, unfortunately the heaters are still enabled (just to be clear, only the heater that is configured in the config is enabled... the LED turns on immediately)
                • jens55undefined
                  jens55 @matt3o
                  @matt3o, hold on a minute .... the only thing that you have going to the board is Vin and presumably ground and the only heater that powers up is the one configured in the config file ???? Something is fishy in Italy ....
                  This is without the ribbon cable connected between the Duet and the Duex? It should not care what is in the config file! If any heater port powers up with only Vin and ground connected then there is a hardware fault with that heater port. If only one powers up than that would seem to suggest only one defective heater output and not all of them. You should be able to configure a different (free) heater port and be off to the races .....
                  • matt3oundefined
                    matt3o @jens55
                    @jens55 I disconnected everything except the ribbon and power.
                    any heater I configure goes full throttle as soon as I give power
                    • jens55undefined
                      jens55 @matt3o
                      Based on that, I would say that the issue is firmware related and not hardware related. I am not very good with config files but you could post your config.g and somebody who knows their stuff might be able to see something that isn't right.
                        Is it all heaters or only the configured heater?
                        What happens when the ribbon is disconnected as well? If it's a heater mosfet that has failed closed circuit it would enable the heaters automatically.
                        If it's only your configured heater than perhaps the configuration is not correct. Perhaps the pin has been inverted so that it's on by default.
                        Please post your config.
                        • matt3oundefined
                          matt3o @Phaedrux
                          I checked with a multimeter and all heaters are shorted (at the same time). I thought it was just the one configured because it's the only one that lights the LED. I tried all the heaters anyway and they all behave the same except the 2 on the duet
                          I'm pretty sure it's not the config because as soon as I set the heater to one on the duet2 (not the duex) everything works and the only thing that changes is the heater name. I'll try to disconnect the ribbon and also post the config just in case
                          • jens55undefined
                            jens55 @matt3o
                            @matt3o, I am not sure if I am looking at the right schematic but what I am seeing is that the LED is connected directly to the output pin. If the output is switched low then the LED will light up. That seems at odds with the report of only one light lighting up.
                            Could you explain how you measure the fact that the output is shorted?
                            • matt3oundefined
                              matt3o
                              this is all very weird and erratic.
                              so first time it happened I checked the heaters with a multimeter and all of them were shorted (I just check resistance @jens55 ).
                              I tried to disconnect the ribbon cable as @Phaedrux suggested and everything's fine, of course the duet doesn't com with the duex but the heaters are all open (off).
                              I reconnected the ribbon (with printer off of course) and now the heaters are all open (off) except for the one that is configured that goes in full blast as soon as I give power. In fact the heater LED turns on right away.
                              If I set the heater to any one on the duet2 everything works as expected.
                              • jens55undefined
                                jens55 @matt3o
                                @matt3o, I don't know what else to suggest. From my end it sounds as if the board is fine and the issue is in the config file but as you say, it works if configured to run the heaters on the Duet.
                                Sorry ....
                                • matt3oundefined
                                  matt3o @jens55
                                  @jens55 thanks for your help anyway, really appreciated it. I'll do some more testing but I'm out of ideas
                                  engikeneerundefined 1 Reply Last reply Reply Quote 0
                                  • engikeneerundefined
                                    engikeneer @matt3o
                                    @matt3o what happens if you take the sd card out of the Duet, then power it all up? That way you know the config is not doing anything.
                                    Are the outputs shorted when you don't power on the Duet & Duex? I wonder if the resistance measurement is interfering with things...
                                    Also, what happens if you actually connect a heater to each of the outputs? Do they get hot or does the board blow fuse? Guessing it will already be blowing the fuse if it's actually shorted on the board.
                                    i3 clone with a bunch of mods
                                      • matt3oundefined
                                        matt3o @Phaedrux
                                        @phaedrux sure thing
                                        G90                                                       ; send absolute coordinates...
                                        M83                                                       ; ...but relative extruder moves
                                        M550 P"Agony"                                            ; set printer name
                                        M552 S1                                                   ; enable network
                                        M586 P0 S1                                                ; enable HTTP
                                        M586 P1 S0                                                ; disable FTP
                                        M586 P2 S0                                                ; disable Telnet
                                        M569 P2 S1                                                ; X1 (Z stepper)
                                        M569 P1 S0                                                ; X2 (Y stepper)
                                        M569 P0 S0                                                ; Y1 (X stepper)
                                        M569 P3 S1                                                ; Y2 (E0 stepper)
                                        M569 P4 S1                                                ; Z1 (E1 stepper)
                                        M569 P5 S1                                                ; Z2 (E2 stepper DEX)
                                        M569 P6 S1                                                ; Z3 (E3 stepper DEX)
                                        M569 P7 S1                                                ; Extruder1 (E4 stepper DEX)
                                        M584 X2:1 Y0:3 Z4:5:6 E7                                  ; set drive mapping
                                        M906 X1300 Y1300 Z1300 E500 I40                           ; set motor currents (mA) and motor idle factor in per cent
                                        M350 X16 Y16 Z16 E16 I1                                   ; configure microstepping with interpolation
                                        M92 X160.00 Y160.00 Z1600.00 E698                         ; set steps per mm
                                        M84 S30                                                   ; Set idle timeout
                                        M566 X900.00 Y900.00 Z60.00 E120.00                       ; set maximum instantaneous speed changes (mm/min)
                                        M203 X30000.00 Y30000.00 Z600.00 E7200.00                 ; set maximum speeds (mm/min)
                                        M201 X6000.00 Y6000.00 Z20.00 E600.00                     ; set accelerations (mm/s^2)
                                        M208 X0 Y0 Z0 S1                                          ; set axis minima
                                        M208 X380 Y385 Z350 S0                                    ; set axis maxima
                                        ; Leadscrews position
                                        M671 X368.5:-21.5:173.5 Y341.85:341.85:1.85 S20
                                        M574 X2 S1 P"xstop"                                       ; configure active-high endstop for high end on X via pin xstop
                                        M574 Y1 S1 P"ystop"                                       ; configure active-high endstop for low end on Y via pin ystop
                                        M574 Z1 S2                                                ; configure Z-probe endstop for low end on Z
                                        M558 P5 C"^zstop" H5 F120 T6000 A3                        ; set Z probe type to switch and the dive height + speeds
                                        G31 P500 X-5.85 Y33 Z3.85                                 ; set Z probe trigger value, offset and trigger height
                                        M557 X20:370 Y20:370 S50                                  ; define mesh grid
                                        M308 S0 P"bedtemp" Y"thermistor" T100000 B4138            ; configure sensor 0 as thermistor on pin bedtemp
                                        M950 H0 C"bedheat" T0 Q10                                 ; create bed heater output on bedheat and map it to sensor 0
                                        M307 H0 B0 R0.724 C695.9 D3.76 S0.80                      ; auto-tune
                                        M140 H0                                                   ; map heated bed to heater 0
                                        M143 H0 S120                                              ; set temperature limit for heater 0 to 120C
                                        M308 S1 P"e4temp" Y"thermistor" T500000 B4723 C1.19622e-7 ; configure sensor 1 as thermistor on pin e0temp
                                        M950 H1 C"e0heat" T1                                      ; create nozzle heater output on e0heat and map it to sensor 1
                                        M307 H1 B0 R2.573 C190.5:106.0 D4.28 S1.00                ; auto-tune
                                        M143 H1 S350                                              ; set temperature limit
                                        M950 F0 C"duex.fan3" Q500                                  ; create fan 0 on pin fan0 and set its frequency
                                        M106 P0 S0 H-1                                            ; set fan 0 value. Thermostatic control is turned off
                                        M950 F1 C"duex.fan4" Q500                                      ; create fan 1 on pin fan1 and set its frequency
                                        M106 P1 S1 H1 T45                                         ; set fan 1 value. Thermostatic control is turned on
                                        M563 P0 S"Mosquito" D0 H1 F0                               ; define tool 0
                                        G10 P0 X0 Y0 Z0                                           ; set tool 0 axis offsets
                                        G10 P0 R0 S0                                              ; set initial tool 0 active and standby temperatures to 0C
                                        ; Closing
                                        M593 F48 ; input shaper
                                        T0                                             ; select tool
                                        it's configured with the heater on the duet2, all I have to do to make it fail is to use any duex heater name like (duex.e2heat)
                                          https://duet3d.dozuki.com/Wiki/RepRapFirmware_3_overview#Section_Pin_names_for_Duet_2_WiFi_Ethernet
                                          Notice how the Duex heater pins are inverted in the listing.
                                          exp.heater3, exp.8, !duex.e2heat, !duex.pwm1
                                          exp.heater4, exp.13, !duex.e3heat, !duex.pwm2
                                          exp.heater5, exp.18, !duex.e4heat, !duex.pwm3
                                          exp.heater6, exp.23, !duex.e5heat, !duex.pwm4
                                          exp.heater7, exp.31, !duex.e6heat, !duex.pwm5
                                          So try using: !duex.e2heat
                                          • jens55undefined
                                            jens55 @Phaedrux
                                            You mean to say duex.e2heat (no bang) ?
