    WiFi Unreliable
    114
    7.0k
    • DessiVerseundefined
      DessiVerse @jay_s_uk
      @jay_s_uk just got it installed. Doesn't appear to be improved though.
        DessiVerse
        Here's an updated M122
        Send: M122
        Recv: === Diagnostics ===
        Recv: RepRapFirmware for Duet 3 Mini 5+ version 3.3beta3 (2021-04-22 13:48:16) running on Duet 3 Mini5plus WiFi (standalone mode)
        Recv: Board ID: 7HDQX-V296U-D65J0-40KM8-MK03Z-R91J2
        Recv: Used output buffers: 1 of 40 (11 max)
        Recv: === RTOS ===
        Recv: Static ram: 101772
        Recv: Dynamic ram: 106336 of which 12 recycled
        Recv: Never used RAM 35584, free system stack 157 words
        Recv: Tasks: NETWORK(ready,19.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(notifyWait,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,78.2%,426) IDLE(ready,0.4%,19) AIN(delaying,0.8%,273), total 100.0%
        Recv: Owned mutexes: USB(MAIN)
        Recv: === Platform ===
        Recv: Last reset 00:02:18 ago, cause: power up
        Recv: Last software reset at 2021-04-28 12:14, reason: HardFault bfarValid precise, GCodes spinning, available RAM 35584, slot 2
        Recv: Software reset code 0x0063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x00000044 SP 0x200036a8 Task MAIN Freestk 771 ok
        Recv: Stack: 00000000 2000374c 00000571 00000000 00000000 0007be25 000836d8 610f0200 2001d580 00000000 00000000 00088e39 00000000 00000000 00000000 ffffffff 369dc3a0 2001d580 20002a40 2001d37c 20003730 200037d8 200037d6 00088f33 00000001 200202e8 200180d8
        Recv: Error status: 0x00
        Recv: Aux0 errors 0,0,0
        Recv: Aux1 errors 0,0,0
        Recv: MCU revision 3, ADC conversions started 138334, completed 138334, timed out 0, errs 0
        Recv: Step timer max interval 1490
        Recv: MCU temperature: min 23.8, current 29.7, max 29.7
        Recv: Supply voltage: min 23.9, current 24.0, max 24.0, under voltage events: 0, over voltage events: 0, power good: yes
        Recv: Heap OK, handles allocated/used 0/0, heap memory allocated/used/recyclable 0/0/0, gc cycles 0
        Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
        Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 7247, writes 10, timeouts 0, DMA errors 0
        Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
        Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7247, writes 9, timeouts 0, DMA errors 0
        Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 7248, writes 9, timeouts 0, DMA errors 0
        Recv: Driver 5: position 0, assumed not present
        Recv: Driver 6: position 0, assumed not present
        Recv: Date/time: 2021-04-28 13:32:52
        Recv: Cache data hit count 320404896
        Recv: Slowest loop: 1051.41ms; fastest: 0.12ms
        Recv: === Storage ===
        Recv: Free file entries: 9
        Recv: SD card 0 detected, interface speed: 22.5MBytes/sec
        Recv: SD card longest read time 3.9ms, write time 0.0ms, max retries 0
        Recv: === Move ===
        Recv: DMs created 83, maxWait 0ms, bed compensation in use: none, comp offset 0.000
        Recv: === MainDDARing ===
        Recv: Scheduled moves 0, completed moves 0, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
        Recv: === AuxDDARing ===
        Recv: === Heat ===
        Recv: Bed heaters = 0 -1, chamberHeaters = -1 -1
        Recv: === GCodes ===
        Recv: Segments left: 0
        Recv: Movement lock held by null
        Recv: HTTP is idle in state(s) 0
        Recv: Telnet is idle in state(s) 0
        Recv: File is idle in state(s) 0
        Recv: USB is ready with "M122" in state(s) 0
        Recv: Aux is idle in state(s) 0
        Recv: Trigger is idle in state(s) 0
        Recv: Queue is idle in state(s) 0
        Recv: LCD is idle in state(s) 0
        Recv: SBC is idle in state(s) 0
        Recv: Daemon is idle in state(s) 0
        Recv: Aux2 is idle in state(s) 0
        Recv: Autopause is idle in state(s) 0
        Recv: Code queue is empty.
        Recv: === CAN ===
        Recv: Messages queued 1244, send timeouts 1241, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 16)
        Recv: Last cancelled message type 4514 dest 127
        Recv: === Network ===
        Recv: Slowest loop: 1993.74ms; fastest: 0.00ms
        Recv: Responder states: HTTP(0) HTTP(2) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
        Recv: HTTP sessions: 1 of 8
        Recv: - WiFi -
        Recv: Network state is active
        Recv: WiFi module is connected to access point
        Recv: Failed messages: pending 0, notready 0, noresp 0
        Recv: WiFi firmware version 1.26
        Recv: WiFi MAC address f0:08:d1:02:ec:f2
        Recv: WiFi Vcc 3.33, reset reason Power up
        Recv: WiFi flash size 2097152, free heap 14336
        Recv: WiFi IP address 10.0.0.201
        Recv: WiFi signal strength -37dBm, mode 802.11n, reconnections 0, sleep mode modem
        Recv: Clock register 00002002
        Recv: Socket states: 0 2 0 0 0 0 0 0
        Recv: ok
        SIamundefined 1 Reply Last reply Reply Quote 0
        • SIamundefined
          SIam @DessiVerse
          @dessiverse this looks good so far now the Wi-Fi has a software version and now test if this problem persists
          Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
          Duet WiFi 1.02 or later + DueX5
          RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
          Duet WiFi Server: 1.26
          Duet Web Control 3.4.0beta4 (2021-09-27)
            DessiVerse
            @SIam, I'm trying to upload a gcode to test the speed and it seems like it keeps slowing down. So the same issue I was having previously. I'd like to note I don't have this issue in SBC mode.
            EDIT: It now slowed down to 1.8 KIB/s. Here is the current M122:
            Send: M122
            Recv: Used output buffers: 2 of 40 (17 max)
            Recv: === RTOS ===
            Recv: Never used RAM 35584, free system stack 146 words
            Recv: Tasks: NETWORK(ready,15.8%,150) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,82.6%,372) IDLE(ready,0.0%,19) AIN(delaying,0.8%,273), total 100.0%
            Recv: Owned mutexes: WiFi(NETWORK) USB(MAIN)
            Recv: Last reset 00:08:20 ago, cause: power up
            Recv: MCU revision 3, ADC conversions started 501054, completed 501052, timed out 0, errs 0
            Recv: Step timer max interval 1489
            Recv: MCU temperature: min 29.7, current 32.8, max 32.8
            Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
            Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 19090, writes 0, timeouts 0, DMA errors 0
            Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19091, writes 0, timeouts 0, DMA errors 0
            Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
            Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 19090, writes 0, timeouts 0, DMA errors 0
            Recv: Date/time: 2021-04-28 13:38:55
            Recv: Cache data hit count 1012800891
            Recv: Slowest loop: 12.17ms; fastest: 0.12ms
            Recv: SD card longest read time 4.2ms, write time 3.9ms, max retries 0
            Recv: === Move ===
            Recv: === Heat ===
            Recv: === CAN ===
            Recv: Messages queued 3265, send timeouts 3265, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
            Recv: Last cancelled message type 30 dest 127
            Recv: Slowest loop: 200.02ms; fastest: 0.06ms
            Recv: Responder states: HTTP(3) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
            Recv: - WiFi -
            Recv: Failed messages: pending 0, notready 0, noresp 1
            Recv: WiFi flash size 2097152, free heap 20640
            Recv: WiFi signal strength -36dBm, mode 802.11n, reconnections 0, sleep mode modem
            Recv: ok
            Send: M105
            Recv: ok T:20.1 /0.0 T0:20.1 /0.0 B:22.5 /0.0
              jay_s_uk @DessiVerse
              @dessiverse what sd card are you using? Brand and model?
              DessiVerseundefined 2 Replies Last reply Reply Quote 0
                @jay_s_uk san disk edge, 8gb
                  @jay_s_uk I just tried using my SanDisk Extreme Pro to see if it was an issue with that and it doesn't seem to be the case. I use that micro sd with my high fps camera so read and writes are never an issue.
                    @dessiverse the 8gb one appears to only be a class 4. A class 10 may be better. I suggest trying another as card if you have one.
                      @dessiverse what speeds were you seeing with the extreme?
                      DessiVerseundefined 1 Reply Last reply Reply Quote 0
                        same as before, and dropping since i took that screenshot. it's now down to 6 KIB/s.
                          @dessiverse can you grab an M122 output while its uploading with the slower speed?
                            @jay_s_uk
                            Send: M122
                            Recv: Used output buffers: 1 of 40 (17 max)
                            Recv: === RTOS ===
                            Recv: Never used RAM 35584, free system stack 154 words
                            Recv: Tasks: NETWORK(ready,14.8%,221) HEAT(delaying,0.0%,318) Move(notifyWait,0.1%,188) CanReceiv(notifyWait,0.0%,943) CanSender(notifyWait,0.0%,371) CanClock(delaying,0.0%,341) TMC(notifyWait,0.7%,115) MAIN(running,83.6%,374) IDLE(ready,0.0%,19) AIN(delaying,0.8%,273), total 100.0%
                            Recv: Last reset 00:04:46 ago, cause: power up
                            Recv: MCU revision 3, ADC conversions started 286329, completed 286328, timed out 0, errs 0
                            Recv: Step timer max interval 752
                            Recv: MCU temperature: min 26.6, current 30.6, max 30.6
                            Recv: Driver 0: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 10585, writes 0, timeouts 0, DMA errors 0
                            Recv: Driver 1: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 10, reads 10585, writes 0, timeouts 0, DMA errors 0
                            Recv: Driver 2: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                            Recv: Driver 3: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                            Recv: Driver 4: position 0, standstill, SG min/max 0/0, read errors 0, write errors 0, ifcnt 9, reads 10585, writes 0, timeouts 0, DMA errors 0
                            Recv: Date/time: 2021-04-28 14:54:39
                            Recv: Cache data hit count 551034519
                            Recv: Slowest loop: 4.92ms; fastest: 0.12ms
                            Recv: Free file entries: 10
                            Recv: SD card longest read time 0.7ms, write time 0.0ms, max retries 0
                            Recv: === Move ===
                            Recv: === Heat ===
                            Recv: Heater 1 is on, I-accum = 0.0
                            Recv: === CAN ===
                            Recv: Messages queued 1810, send timeouts 1810, received 0, lost 0, longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 17 (min 17)
                            Recv: Slowest loop: 200.87ms; fastest: 0.00ms
                            Recv: Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0), 0 sessions
                            Recv: - WiFi -
                            Recv: WiFi flash size 2097152, free heap 20976
                            Recv: Socket states: 0 0 0 0 0 0 0 0
                            Recv: ok
                              jay_s_uk
                              Maybe one for one of the duet team to comment on?
                              @Phaedrux
                                @jay_s_uk I'm not sure. I am kind of running out of patience with this though if I'm being honest. I was running it in SBC mode for a while because of the speeds, but, I can't use Octoprint with that so I can't use a camera ¯_(ツ)_/¯
                                  @dessiverse you know you can run things like motion with the SBC setup for camera usage.
                                  We have some info here https://teamgloomy.github.io/camera.html
                                    DessiVerse
                                    @jay_s_uk I wouldn’t be able to run monitoring software like spaghetti detective though. So I wanted to try to get just the duet working so I can plug my pi into it for octopi. But, I still would need to access the duet panel now and then if I wanna edit any of the files.
                                      @dessiverse there are also some features of the firmware that are only available when printing from the sd card (i.e. not streamed from octoprint).
                                      You can see them here https://duet3d.dozuki.com/Wiki/Firmware_Overview?revisionid=HEAD#Section_Printing_over_USB_connection_Octoprint_Cura_Simplify3D_Etc
                                        @jay_s_uk I'm aware of those. I normally print on the SD Card over Octoprint anyway, but I can't communicate with the sdcard using Octoprint with this board. Which is back to why I need WiFi working so I can upload to the SD card via the duet dashboard.
                                          DessiVerse
                                          SBC mode is no longer working. I assume that's due to the beta firmware that was installed. Can someone please help with this? My printer is now entirely unusable.
                                          Screen Shot 2021-04-28 at 6.07.15 PM.png Screen Shot 2021-04-28 at 6.07.00 PM.png
                                            To use the beta firmware on the duet and SBC mode the SBC would need to be updated to the beta as well.
                                            So either return the Duet back to 3.2.2 to match the version installed on the pi, or add the unstable repository to the pi and then update again.
                                            See here for more details on adding the unstable branch.
                                            https://duet3d.dozuki.com/Wiki/Getting_Started_With_Duet_3#Section_Software_Installation
