Motor doesn't move
@phaedrux I want to use the expansion board of my duet 2 ethernet with 2.05 firmware. When I try to generate the config code, the expansion board page shows "No expansion board configured".
@zfeng
you see on the right top two buttons if you click on it the dueX will be added -
@siam For duet 2 ethernet with 2.05 firmware, should I choose Duex2 or 5?
@zfeng it depends on which duet expansions board you have
@siam I want to use this portion of the board.
@zfeng then you need an expansions board
If you want to add additional hardware via the expansion port your best bet would be to add a Duex2/5 or an expansion breakout board if a Duex is overkill for what you need.
The expansion port only outputs low voltage signaling and can't drive hardware directly.
https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
@phaedrux How many steps per revolution if using Duet 2? I'm using x16 microstepping, is this correct?
@zfeng said in Motor doesn't move:
There's not enough context to know what you're asking here.
@phaedrux I'm trying to set the config.g file through the config tool. In the Motors tab, I need to set the Microstepping (interpolation) parameter. Please advise how to set that number. Thanks!
@zfeng You should use x16 microstepping. The steps per mm is going to depend on the motor being 0.9 or 1.8 degree per step and whatever mechanical system you have the motors connected to. If you click on the steps per mm box it should open a calculator to help you figure it out.
