    Motor doesn't move
    930
    • zfengundefined
      zfeng @Phaedrux
      @phaedrux The hot end and fan use digital signal so I cannot wire them directly to the hot end and fan connecters. I think I should wire them to the expansion board instead. When I generate the config file, on the expansion boards page, it says no expansion board configured.
      Another question I have is, what is the xyz movement unit in the Duet web control? I need to adjust the step size according to the screw. Thank you!
        Phaedrux Moderator @zfeng
        @zfeng said in Motor doesn't move:
        Can you provide more detail about what you're trying to control?
        The unit is millimeters. To adjust how many steps per mm are used you need to adjust the M92 command in config.g or define it in the config tool for the motor.
        zfengundefined 1 Reply Last reply Reply Quote 0
        • zfengundefined
          zfeng @Phaedrux
          @phaedrux I want to use the expansion board of my duet 2 ethernet with 2.05 firmware. When I try to generate the config code, the expansion board page shows "No expansion board configured".
          SIamundefined 1 Reply Last reply Reply Quote 0
          • SIamundefined
            SIam @zfeng
            @zfeng
            you see on the right top two buttons if you click on it the dueX will be added
            Hypercube-Evolution-Hybrid, Piezo Orion, Orbiter
            Duet WiFi 1.02 or later + DueX5
            RepRapFirmware for Duet 2 WiFi/Ethernet 3.4.0beta4 (2021-09-27 11:30:36)
            Duet WiFi Server: 1.26
            Duet Web Control 3.4.0beta4 (2021-09-27)
            • zfengundefined
              zfeng @SIam
              @siam For duet 2 ethernet with 2.05 firmware, should I choose Duex2 or 5?
              • SIamundefined
                SIam @zfeng
                @zfeng it depends on which duet expansions board you have
                • zfengundefined
                  zfeng @SIam
                  @siam I want to use this portion of the board.
                  • SIamundefined
                    SIam @zfeng
                    @zfeng then you need an expansions board
                      If you want to add additional hardware via the expansion port your best bet would be to add a Duex2/5 or an expansion breakout board if a Duex is overkill for what you need.
                      The expansion port only outputs low voltage signaling and can't drive hardware directly.
                      https://duet3d.dozuki.com/Wiki/Duet_Expansion_Breakout_Board
                      https://www.duet3d.com/Expansion_Breakout
                      • zfengundefined
                        zfeng @Phaedrux
                        @phaedrux How many steps per revolution if using Duet 2? I'm using x16 microstepping, is this correct?
                          There's not enough context to know what you're asking here.
                          • zfengundefined
                            zfeng @Phaedrux
                            @phaedrux I'm trying to set the config.g file through the config tool. In the Motors tab, I need to set the Microstepping (interpolation) parameter. Please advise how to set that number. Thanks!
                              @zfeng You should use x16 microstepping. The steps per mm is going to depend on the motor being 0.9 or 1.8 degree per step and whatever mechanical system you have the motors connected to. If you click on the steps per mm box it should open a calculator to help you figure it out.
